Question about Cycling
Raise handlebar stem on a K2 Attack Mountain bike
    Problem Solver:
  • 18 Answers
You can't tell without looking to see what is on the bike but if it is a thread-less stem you can try taking handlebar off an then take stem off head tube and turn it a 180 degrees, the two are connecting the opposite things. that should raise the angle of the stem and bring handlebar up. that is a free solution.
Posted on Jan 25, 2013
al_kupchella
  • 843 Answers
SOURCE: How can I raise handlebars on a 26 in. Mountain
You need an Allen wrench (a.k.a. hex key) to fit the bolt head right in the middle of the handle bars. Loosen this bolt just 2 or 3 turns then tap the head with a soft hammer or block of wood and a hammer. Then pull the handle bar stem up (and all of the way out so you can see how the wedge-shaped nut at the bottom of the stem works). Look for a mark on the stem telling you how high you can safely raise the bars (you have to leave enough of the stem inside the tube so that it will be strong.) Put it back in and tighten it up. If you found this helpful, please vote. Good luck
Posted on Jun 24, 2010
goalie39
  • 469 Answers
SOURCE: how do i heighten the handlebars on a carrera mountain bike?
Loosen the bolt on the top of the handlebar stem few turns, then tap it with a hammer, this should knock loose the plug and the bars should move,
Posted on Apr 15, 2009
  • 193 Answers
SOURCE: 20'' Mongoose BMX - How can i adjust handlebar height?
You need to unscrew the circular nut like thing on the stem all the way off and pull up hard on the bars and it should come up, try spraying some lucricant on the stem to loosen it if needed.
Posted on Jun 20, 2009
  • 6 Answers
SOURCE: I cannot adjust the height of the handlebars on the 20" Mongoose
some bikes u cant only the seats can adjuct
Posted on Jul 20, 2009
  • 128 Answers
SOURCE: loose handlebars on a Mongoose XR-75 mountain bike
Check the splines on the handle bar. Just loosen the "clamp" and slide the bar over to one side enough so you can tell if the are stripped or not. If they are then replace the bar, if not then reassemble and try to put a littlle extra torque on the bolt.
I have noticed with the 2 of these bikes that I have that the bars do not like to stay tight for long, they tend to work thier way loose about every other time we use them. I just keep tightening them untill the splines strip, then pick up a new bar.
Contact Mongoose for parts info at: www.Mongoose.com under "about" click ask mongoose.
Good luck.
Posted on Apr 05, 2010
Raise handlebars on mountain bicycle
This will depend on what sort of stem you have. Most mountain bikes these days use a clamping style stem that simply grips the steerer tube on the fork. Some will have limited adjustment in that they may have a stack of 2 or 3 spacers that you can place either over the stem or below the stem. This does not give much adjustment. On my wife's bike the stem is actually adjustable similair to this: MEC 110mm Adjustable Stem Mountain Equipment Co op
and might be a good option for this bike.
Sep 18, 2014 | Huffy Granite 26 Women's Mountain Bike
How do you raise the handlebars?
unfortunately, your bike uses a threadless stem. meaning you cannot raise it, you must replace it with an adjustable one, or get a stem with a steeper angle.
Oct 28, 2012 | Jeep Comanche 29er Mountain Bike
Adjust handlebar height on Schwinn Varsity
I'm answering 7 years later. I have a Schwinn Varsity 2500 Bike made probably in 2015. The Schwinn Varsity Bike is not set up the same way as a traditional bike. I loosened the center compression bolt and the two side stem clamp bolts and it came loose where I can adjust it up or down but, there's nothing to tighten the slack up below. I did some research. My original post here was to add or remove a spacer. I think you can remove a spacer to lower but, I don't think the stem is long enough to add another one. I've seen they sell an extension that you can add-on to make the handle bars higher.
Jun 25, 2012 | Schwinn Cycling
How to raise handlebars on a polaris ranger mountain bike
http://www.sheldonbrown.com/handsup.html
A major limitation is the steerer tube length. No matter how many times you cut a steerer tube it won't get longer.
Getting Riser Bars or simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. If you LIKE the handlebars, the stem is the best and least-invasive option as most new ones come with front loaders (detachable front caps) that allow replacement without stripping components off one side of the handlebar. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
A reputable Bicycle Shop would have fit the bike to you before you took it home.
Aug 13, 2011 | Polaris Ranger Boy's 24Inch Mountain Bike
How do we raise the handle bars on the k2 zed 24
The only way to do this is to get new stem with the bigger angle degree. If not sure, get the adjustable stem.
Apr 26, 2011 | K2 Zed 24 Boys' FrontSuspension Mountain...
Can I raise the handlebars? I can raise the saddle but the handlebars seem fixed?
Getting Riser Bars or simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. If you LIKE the handlebars, the stem is the best option as most new ones come with front loaders (detachable front caps) that allow replacement without stripping components off one side of the handlebar. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
Apr 11, 2011 | Fuji Nevada 50 Mountain Bike Performance...
How do you hire the handle bars on a giant mountain bike
Hello. You will need an adjustable wrench. Then look at the center of the handlebars and you will see a bolt and a nut. Usually the nut is on the underside. Loosen the nut, raise the handle bars and retighten the nut. J.
Jun 01, 2010 | Giant Boulder Se Mountain Bike 19"...
How do you raise the handlebar of a Schwinn Ridge AL 26" bike? I want to add a child carrier and I need to raise the handlebar to make it fit.
The handlebars stem is an Aheadset-style and as such has spacers below it to set its height. Once the steerer tube is cut to fit the combination of stem and spacers there's no going UP, only down. Stems can be replaced with different rises and lengths. Maybe that would help. A Bicycle Shop would have everything you need and the know-how to decide if you can mount the child carrer.
May 27, 2010 | Schwinn Ridge Al 26" Men'sboy's Mountain...
Raising the handlebars
You will need a 6mm allen key to loosen ( turn anti clock wise) the handlebar stem bolt which when you sit on the bike and look down its just under yer nose :)
Please make sure when you raise the handlebars that as it lifts up there is a marking on the side of the handle bar "stem" with markings like this """"" if you see these you need to lower it down so you cannot see these.
Feb 28, 2010 | Pacific International Pacific Evolution...
Cycling Logo
288 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
