Question about Cameras
Why does Samsung WB150R reads DCF FULL ERROR when memory card is fitted
    Genius:
  • Cameras Master
  • 1,019 Answers
Hello, Is the memory card formatted by the camera ? Is the slide on the card set to protect ? Have you tried a different card ?
Posted on Jan 25, 2013
  • 13 Answers
SOURCE: CAMERA READS -CARD ERROR-AFTER INSERTING A NEW MEMORY CARD
First, make sure that the new memory card does not have the protect tab in the lock position. The new card must be unlocked and formatted before your camera will be able to use it. Also, make sure that the size card that you have purchased has not over shot the ability of your camera. I think that a 2 GB card is as large as you can use. Just because the card fits into the slot does not mean that the camera will address it!
Posted on Apr 23, 2008
drifterK
  • 4924 Answers
SOURCE: every time i turn on
remove the batteries and the card and insert them again ..If you have access in the menu ..perform a general reset to the factory settings ..or look for a reset hidden button if it has..
The thing to do is to format the card again using storage feature in the camera (choose card and under the options ..format )
be sure that you saved all files from the card ..cause formatting it will erase anything that might contain ..
If after reset and format still do not want to work proper..than the issue is something related with a physical bad contact ..(humidity ..or so ) ..and try to dry it out with a hair dryer but using the cold air..
this will eliminate any humidity ..and make it worked if this is the issue..
Remove card and batteries before drying it ..and blow the air in the slots where these should fit..
Posted on Dec 25, 2010
SOURCE: DCF Full Error
I have got a Samsung ES30 Digital camera .Everytime i turn it on it always says DCF Full Error ' which i have no idea means .Please help???
Posted on Dec 29, 2010
  • 37 Answers
SOURCE: My Samsung ES30 camera gives me the DCF Full Error
try to remove the memory card and then format the unit without memory card.,after formatting the unit.,reset it and then format the mmc to the pc.,after 10 seconds.,insert the mmc and then power on again.,
Posted on Feb 24, 2011
  • 37 Answers
SOURCE: When the Camera is turned
.try to format both...
remove the sd card on your unit,then insert that to the mmc reader then format it to your pc,,after formatted.,,
open your unit without sd card,,go to menu - setting - format -reset
after that insert it to your unit.,then take atleast 15 shots.,.then turn it off.,.,then open again for you to find out if this procedure will okey.,
Posted on Mar 04, 2011
I am unable to take photo because of DCF full Erros come often ES30
This is what the manual says:
File names do not match the DCF standard.
Transfer the files on the memory card to your
computer, and then format the card. (p. 76)
Format in the camera, not in a cardslot of your computer.
Lots of errors, can be solved by removing and reinserting the battery(ies)
Nov 02, 2013 | Samsung ES30 Digital Camera
My Samsung ES30 camera gives me the DCF Full error message.I tried other solutions ,such as formatting the memory cardd,I even tried a new memory card.Still the message comeup.Who know what to do?I am in...
The manual says: the files names does not match the DCF format. Transfer the files on the card to your computer and format the card.
You tried to format and it did not work. Sure the card is not locked? The lock switch should be up, so the card is unlocked an you must be able to format te card and you should be able to write files to the memory card.
Although the camera is compatible with SCHC I wonder if you did not put in a very big card. Perhaps your camera cant work with 8 or 16 GB. Is surely can't work with SDXC cards.
Did you try a normal SD card, and could you format that one?
Nov 02, 2013 | Samsung Cameras
When I turn on my camera, in the middle of the screen in a black box it says " DCF full error" what does this mean and how do I get it to go away? I have tried resetting my camera and formatting...
Hello
Thank you for using FIXYA!!!
OK, firstly let me state what exactly the error message you are receiving concludes to:
"The "DCF full error" occurs when you use memory card in your camera which is formatted in another camera. The error is the result of improper formatting of the memory card which leads to incompatibility of the card with the Samsung camera."
Now, i the resolution for this specific problem is to format the memory card in the Samsung camera.
I know you stated that you have already formatted the card, but you did not state if you formatted the card in your camera, or on your computer.
Try the above solution and let me know if the problem still persists.
Please do not hesitate to let me know if you have any further questions.
Kind regards
lock123
May 24, 2011 | Samsung S860 Digital Camera
When l take my SD card, it still says " DCF Full Error"
Hello and Welcome
The DCF error message with your Samsung camera nearly always occurs when you're using a memory card that was formatted with a different camera, and the file format structure is not compatible with your Samsung camera. You will have to format the card with the Samsung camera.However, make sure you download any photos to your computer first
Anymore help, I am here to help
Best of Luck
Concerned:
Uxair Shah
Mar 14, 2011 | Samsung ES30 Digital Camera
When I take my SD card out, it still says "DCF
well as long as it works when u put the sd card in then its all good right?
also
  1. DCF Full Error error message. The DCF error message with your Samsung camera nearly always occurs when you're using a memory card that was formatted with a different camera, and the file format structure is not compatible with your Samsung camera. You'll have to format the card with the Samsung camera. However, make sure you download any photos to your computer first.
Mar 07, 2011 | Samsung ES30 Digital Camera
DCF Full Error
DCF = Digital Camera Full
Usually, that just means you have taken a lot of pictures/videos and your memory card is full.
You should transfer them to a computer via USB or by taking the memory card out and putting it directly into a computer.
If you continue to have problems after emptying the memory card, you may have a faulty memory card.
If you suspect you have a faulty memory card, you might try a different one.
Always try to use a trusted memory card brand (I prefer Sandisk).
Good luck, I hope I was able to help
Feb 28, 2011 | Samsung S860 Digital Camera
My Samsung ES30 camera gives me the DCF Full Error message. I tried other solutions, such as formatting the memory card, I even tried a new memory card. I also tried drying the inside, with the batteries...
Jan 16, 2011 | Samsung Cameras
New 4G memory card states full have re-formatted but still shows full. Have tried a 2G card but that is ok to use any ideas please
Your new 4GB card is an SDHC card. The S700 works with MMC and SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to go with cards 2GB and smaller.
Jan 10, 2011 | Samsung Digimax S700 Digital Camera
Tl220
camera and or card memory is full?
change card or download photos to computer or other media and delete from the card in the camera to make space for new photos.
Oct 22, 2009 | Samsung L200 Digital Camera
DCF Full Error
Sep 25, 2008 | Samsung S860 Digital Camera
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
