Question about Pioneer AVH-P4400BH
How do I disconnect a blutooth on a pioneer AVH-p4400bh?
My niece came down and we connected her phone to make sure it worked. Now that she has left, I cannot connect any other devices or even get to the blutooth menu. How to reset?
ward_knutson
  • 64 Answers
SOURCE: pioneer AVH-P5700 instalation
You can find a wiring diagram for your 87 monte at http://www.modifiedlife.com/1987-chevrolet-monte-carlo-car-audio-wiring-schematic/ You can refer to the installation manual for your deck at http://akamaipix.crutchfield.com/Manuals/130/130AVHP570.PDF Since you are removing a shaft style radio and installing a DIN style you will need to perform extensive modifications to your dash. The Pioneer manual provides the dimensions.
Posted on Nov 25, 2008
  • 18 Answers
SOURCE: bypass ebrake with relay on a pioneer avh-p5700
Go to any auto parts store and purchase a four wire relay and wire it up as follows: The relay will have numbers written on the bottom for each pin. The wire from the parking brake from the H/U to 87. Ground to 85 and 30. Remote from the H/U to 86. This will give you an automatic bypass to the DVD lockout. If you want to just put a switch to do this manually you can also. Go to Radio Shack and buy a momentary push button switch, part number 275-1548. Take the green wire coming out of the unit. Strip the wire, and attach it to one of of the pins on the relay switch. It doesn't matter which one. Buy a standard 16 gauge wire from Radio Shack and connect it to the other pin on the switch, then connect the other end of it to a grounded connection on your vehicle. Now, when you play a DVD, the warning screen will come on. Just press the button on the switch and it will go away, since it tricks the receiver into thinking you have engaged the parking brake. Like someone said before, it is illegal in just about all states to have a dvd or other video playing if the driver can see it and the car is moving. This method is used because the lockout not only keeps you from seeing videos but also locks out some features which many feel have nothing to do with safety and they need it.
Posted on Jun 10, 2009
SOURCE: I HAVE A PIONEER AVH-P5100DVD AFTER CONNECTING ALL
make sure u have connected the fm tunner silver box if not thats your problem if u do not connect it it wont power thats really important.
Posted on Oct 08, 2009
  • 86 Answers
SOURCE: please help me enable the aux mode on the above
Have you tried going into the menu and searching for this function?Also some car stereo's have a sub menu when the radio is turned off or in stanby mode it usually can be reached by pushing your menu button and holding for a few seconds also again the power has to be in standby mode. if this works look through menu for your problem.
Posted on Nov 04, 2009
Testimonial: "Thank you, i will try ."
pctech1
  • 1940 Answers
SOURCE: help i need a wiring diagram for a pioneer
ftp://extra.abt.com/PDF_Files/avhp5700dvd_installation.pdf
This is the installation manual for the AVH-P5700DVD, including a wiring diagram for the wiring harness.
http://www.pac-audio.com/PACProductData/TR7/1_Instructions/tr-7_instructions_010505.pdf
This is the wiring diagram for the PAC TR-7 UNIVERSAL TRIGGER OUTPUT MODULE VIDEO BYPASS.
Posted on Jan 12, 2010
My Pioneer AVH-P1400dvd wont cut on after installing it
Did you make sure you connected the Blue wire to the pioneer its the remote to the car when the car is on the device will be on if you don't connect this wire the device will stay on
Dec 28, 2013 | Pioneer AVH-P1400DVD
HD radio stations are not coming in clear
see if there is a local/distant selector on your unit. It will make it so your radio will only let you find very strong stations, also check your antenna connection to make sure it is pushed all the way into the connector and is clean of corrosion or anything that could keep it from making good contact inside of the connection, you can use steel wool or scotchbrite pads on the surfaces to ensure a good connection.
May 04, 2013 | Pioneer AVH-P4400BH
I cannot hear the dialing or ring tone and the phone is paired to the radio correctly with full volume, what could it be?
You don't mention the year, make and model of the vehicle or, what exactly is installed with this headunit. However, I have seen this issue with certain installations concerning the cancellation of the front speakers during the phone operation( if an amp is connected and the front speakers are routed through the amp) and, when the installer fails to connect the remote turn on wire (blue /white) to the vehicle's amp turn on.
Feb 10, 2013 | Pioneer AVH-P4400BH
How do i empty bluetooth memory on a AVH-P2400BT
I'm having the same problem how do u clear blue tooth memory the erase button isn't lit up and can't click it
Nov 21, 2012 | Pioneer AVH-P2400BT - Bluetooth Enabled...
Avh-p4400bh
try changing the resolution of the album art pictures
Jun 11, 2012 | Pioneer AVH-P4000DVD Monitor
I wired up a pioneer avh-p4200dvd and now it won't
1. Disconnect the light green lead at power connector form ur Pioneer Player.
2. Connect above mentioned wire to direct fuse box with steady 12 V supply.
Feb 04, 2012 | 1990 Nissan 300ZX
Pioneer AVH-P4400BH Logo
26 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
