My Samsung 1740 printer makes a big noise when I try to print a page and goes to "error" mode automatically. If I open the cartridge cover (without taking out the cartridge), the noise stops. Please h
The cartridge is pretty new and the printer was working fine till last week. I just move to a different corner in the same room and the strange noise started.
  • 60 Answers
May be your cartidge penium is broken or printer internal penium broken.
Posted on Jan 21, 2013
  • 18 Answers
SOURCE: Printing problem in hP laserjet 1020
just inspect your printer's front cover.there r two plastic stick which is attached with the printer cover.this two stick hit the two particular point.
1.power switch conector(left side corner)
2. scanner sensor conector(right side middle)
i think your left side stick may be broke try it.
Posted on Feb 20, 2008
SOURCE: Lexmark E232 photoconductor
Make sure to install the new photoconductor 1st.
1) Power off the printer using the switch in the back.
2) Open the front cover.
3) Press and hold the Continue button (Big silver button with Diamond shape symbol) and power the printer On (turn the switch back to ON).
4) When you see the last light i.e. error light on solid, release the Continue button and close the front cover.
5) When you close the cover you will see all the top 3 lights on solid.
6) Press the cancel button with X symbol for 4 times very slowly till you see toner low light (i.e. second light from top) on solid.
7) Press the continue button and wait until you see the light sequence.
8) Press the cancel button and wait until you see the light sequence.
9) Finally power off the printer using the switch in the back (IMPORTANT= wait 1 minute) and power it back on to exit the configuration mode.
Posted on Feb 09, 2009
  • 49 Answers
SOURCE: Two dell 1720dn printers with two different problems.
Call Dell and get the drum count reset instructions. They should tell people this info...but neglect to. :P
Posted on Feb 27, 2009
SOURCE: Auto cutter does not cut automatically
TM 220a and TM 220b should come with auto cutters
You have to unscrew the metal tab under the printer, you will find two sets of DIP switches. upper one is DWS 1 and the lower one is DWS 2. On DWS 2 you need to have jumper #2 ON. this enables or activates the auto cutter on printers. Good luck...
Posted on Jul 04, 2009
supertech6
  • 513 Answers
SOURCE: Brother DPC-165C has 'Init Unable AF' error
Yup. I suspect the head has been removed from the unit. There are adjustments on some printers. It was assembled wrong. The grating noise is likely the auto cleaner. If it cannot go 'home' the unit will not initialize. Possibly the head detect sensor is broken or covered. If the head will not home (moves out and back more than once or slams home hard), 'Init Unable AF'. You may be able to order a service manual from Brother for this. A repair shop can order the manual as well. (I suspect you need a new print head as well. You might want to replace the printer) see tips on bubblejet printers.
Posted on Mar 20, 2010
I keep getting " fit printer head " message when it is fitted and I have 2 new cartridges of colour and black and it worked fine last week
Hi Pete,
Ideally it should not give this error however there are few steps that can fix the issue.
I would like to direct you to a link that will be helpful for you in many ways to resolve most of your printer issues.
Click on this link -> Link
Regards,
Sean
Sep 16, 2012 | Canon PIXMA iP2000 InkJet Printer
I have an Lexmark x3350 and bought a new black ink cartridge a couple weeks ago. I was working fine till now, printer screen is showing Left cartridge incorrect. I unplugged everything, tried ...
Turn off the Printer and Unplug it from the Power Supply.
Remove the Cartridges from the Printer!!!!!
On the Backside of the Cartridge you would see a Copper Stripe, Wipe the Copper Stripe using a Paper Towel!
Reinsert the Cartridges and Restart the Printer.
Good Luck!!!
Sep 22, 2011 | Lexmark X3350 All-In-One InkJet Printer
Will not print. Moved computer from one room to another. Was printing fine before moving. Says that the ink cartridge is in the wrong place. Almost new cartridges. I have removed them replaced them....
Try to wipe the cartridge nozzles with a slightly moistened soft cloth to clean it from dirt and possible clogs. If that doesn't help, try to insert a different known working cartridge to determine if the other is faulty.
Jun 20, 2011 | Lexmark All-in-One Printer with PictBridge
Printer is blinking. I installed a new ink
Sounds like your cartridge may be unseated or it is really incompatible. You do not state clearly that you have printed successfully with this cartridge before.
Oct 12, 2009 | Dell 810 All-In-One InkJet Printer
Lexmark E350d printer - replacement cartridge will not work
Seen/heard this before on Lexmark E350.
First place to look is the cartridge.
One side has a plastic gear which is a push-fit onto the end of the Developer Roller.
The D shape (hole with a 'flat') can lose the flat, or the gear can fracture (usually from one or the corners of the 'flat').
If this is it, the cartridge is faulty.
Mar 08, 2009 | Lexmark E350d Laser Printer
Pixma MP780 Can't turn on
To move the print cartridge without power to the printer: Grab it with your hand and slide to the middle. It may offer slight resistance and while not an expert, I doubt damage will be caused.
Feb 03, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Strange noise
dear cindy726
your printer is having a hardware failure.please sent it for serviced
Apr 07, 2008 | Epson C64 InkJet Printer
27 people viewed this question
k24674
jasbo
jasbo
