Question about Diamondback Cycling
How do i remove headset
How do i remove the headset from a diamond back topanga mountain bike? Is it screwed in or press fit? If screwed in, is it a right or left hand thread?
    Problem Solver:
  • 18 Answers
Loosen bolts on side of stem then take bolt all the way out of top. slide it up and make sure you take each washer or spacer off but keep them in order it came bike so you can put them back together.its not pressed in or threaded it should say a-headset on it so the tube the stem is attached to is the top of fork. tap that fork with rubber mallet and it should fall straight down off bike.
Posted on Jan 25, 2013
4 Suggested Answers
  • 34 Answers
SOURCE: cannot get my left hand gear to shift
see mine did that but i used 2 hand and turned really hard if that dont work it could be rusted
Posted on Aug 22, 2009
sisadsl
  • 1508 Answers
SOURCE: is the shaft that holds the clutch in right hand
it is probably right hand thread, but will have a lock tab to stop it coming undone.
Posted on Apr 08, 2010
dunnbiker
  • 8546 Answers
SOURCE: got a diamond back mountain bike frame both crank
You need a bigger hammer or the right tool.
http://www.parktool.com/blog/repair-help/categories/crank-service
Posted on May 22, 2011
R005507956
do u have the SEnumber or the model number?
Jun 02, 2014 | Diamondback Topanga 26 Men's...
Tip
Bike Headset Installation
Hi I found this Bike Headset Installation guide while searching in Google, it really helped me and I hope it will help others here at Fixya:
  • Make sure the frame has been reamed and faced, otherwise you will have trouble installing the headset, or the headset won't last very long. If you aren't sure, take the bike to a bike shop.
  • Seat the crown race on the fork crown. This requires a crown race slide punch. Pound the crown race down until it sits flat on the fork crown.
  • Clamp the frame into the repair stand.
  • Lightly grease both ends of the headtube and place the headset cups into the ends of the head tube.
  • Slide the cup press through the head tube. Install the lower half of the press.
  • Turn the handle on the top of the cup press clockwise while holding the bottom of the press with a wrench. Work slowly and carefully, making sure the cups press evenly into the frame. Be sure to tighten the cups firmly into the frame, but do not over tighten.
  • Remove the cup press.
  • Grease the bearing and install the fork. For information on how to adjust the headset, see related eHow "Adjust a Bike Headset."
Good luck
Daniel
on Oct 30, 2008 | Marzocchi 2008 XC 700 ATA Mountain Bike...
I have a women's Schwinn Ridge AL mountain bike and to install the handle bar, I have to remove the top cap but it wouldnt screw off or pop out. How is this supposed to be done?
That cap never needs to be removed. It is simply for adjusting the preload on the headset bearings while the other bolts on the stem secure that adjustment.
Hit the search engines with "threadless headset adjustment" for many explanatory videos.
Jun 22, 2011 | Schwinn Ridge Al 26" Men'sboy's Mountain...
Ow do the cassettes conect to the back wheel screw on or push ?
Cassettes fit on a spline with a lock nut to keep them there, the spline is also the ratchet.
Older bikes had a ratchet/sprocket assembly which screwed onto a threaded hub
May 25, 2011 | Shimano Hg40 1134t Mountain Bike 8speed...
I have the Shimano Rapidfire Plus shifter on my Topanga bicycle and it started to not shift it just has free play! I try to shift it and it just moves free and once and awhile it will shift. Will I have...
It may be fixable.Try to clean it and then tighten the cable that is on the rear of the shifter assembly.Then make sure the controller is tight and clean.If it still wont work check to make sure the mounting bracket is not bent.The mounting bracket may also have an adjuster on it.
May 11, 2011 | Diamondback Topanga 26 Men's...
What type of mountain bike are they?
There are six main types of mountain bikes. These include: comfort, hybrid, hardtail, single speed, full suspension and freeride. One of these types of bikes will fit your style and riding needs. Talk with a bike salesperson to determine which one will work best for you.
Dec 16, 2010 | Cycling
How to remove front tire of a diamondback tonpanga comp
so ill assume this bike has it's stock parts. if that is so there is a lever on one side of the front axle. open it and spin it counter clockwise while holding the binding screw on the other side of the axle .then remove the wheel. reverse these directions to put it back on except you must leave the lever in the open position until it has a firm grab when closed this may take a couple of opens-closes -spins to get it right and never have the lever face forward when locked as they may be opened by bushes or branches .your disc may not function properly when your wheel is first replaced due to it sitting slightly ajar as the disc has very little clearance to work with so to fix this simply open the lever dont spin it just open it and seat the tire straight before tightening ok i hope this is helpful
Nov 21, 2010 | Diamondback Topanga 26 Men's...
Brakes are noisy and rub, how do you adjust them? tektrodisc brakes I think..
this is simple, all you need to do is to tighten the adjustment barrel to give the brake cable core slack. or if that dont work than losen the anchor bolt and give the cable a little more slack and re tighten the anchor bolt.
Oct 17, 2010 | Diamondback Topanga 26 Men's...
How do I pump a presta valve with the Blackburn Mountain Air Bike Pump 4 Bicycle
They should be designed to fit both styles of valve, but you need to reverse the seal.
you should be able to unscrew the end, remove the sealing rubber and a plastic fitting that pushes on the valve, replace them the opposite way around ,and they will fit the presta.
Aug 22, 2010 | Blackburn Mountain Air Mountain Bike Pump...
I cannot remove the plate to pute the other plate on
Here's a copy of the manual instructions...
Detail Sanding
Your tool is equipped with a teardrop base which allows you to use it on large flat surfaces
and tight spots or corners.
The pad tips may wear unevenly, depending on use. The pads are designed to allow you to
interchange and /or rotate the diamond tip.
Fitting Sanding Sheets ( Fig. 2)
• Detach the two diamond-shaped tips from the sanding sheet.
If this doesn't provide enough information, take a look at the pictures in the manual at the following link: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/589307-02,MS550GBMS550GH.pdf
If you still have difficulty getting the base off, write back and let me know specifically what the trouble is and I'll try to help you with it.
• Hold the tool with the sanding base facing upwards.
• Place the sanding sheet onto the sanding base.
The diamond-shaped tip can be reversed and replaced when worn.
• When the front part of the tip is worn, detach it from the sheet, reverse it and press it onto
the sanding base again.
• When the whole tip is worn, remove it from the sanding base and fit a new tip.
Tip of the Sanding Base ( Fig. 3)
When the sanding base tip is worn, it can be reversed or replaced.
• Remove the screw.
• Reverse or replace the worn part.
• Fit and tighten the screw.
Finger Attachment ( Fig. 4)
The finger attachment is used for fine detail sanding.
• Remove the screw.
• Remove the diamond-shaped tip holder from the sanding base.
• Fit the finger attachment onto the sanding base.
Contour Holder Attachment (Fig. 5)
• The contour sanding pieces are for sanding curved surfaces and grooves.
• Remove the screw.
sanding base.
• Fit the contour holder onto the sanding base.
Fitting and Removing a Contour Piece (Fig. 6 & 7)
• Choose the contour sanding piece profile most suitable for your application.
• Place one end of the contour sanding piece into the recess at
the front end of the profile holder.
• Push the other end of the contour sanding piece until it clicks
into place.
To remove the contour sanding piece, push it forward then pull the rear end out of
the profile holder (fig. 7).
Fitting a Sanding Sheet Onto a Contour Sanding Piece (Fig. 8)
• Align the sanding sheet with the contour sanding piece.
• Press the sanding sheet onto the contour sanding piece, making
sure that the sanding sheet follows the shape of the profile.
Mar 23, 2009 | Black & Decker MS550GB Mouse 5 Amp Detail...
Cycling Logo
96 people viewed this question
Top Diamondback Cycling Experts
Tony
Ed Hauk
Ed Hauk
Level 1 Expert
Are you a Diamondback Cycling Expert? Answer questions, earn points and help others
