Question about AcerPower FH - P4 631 3 GHz (S6463624) PC Desktop
I have an acerpower fh series and it keeps rebooting when it reaches the desktop. it does fine in safe mode. i have done a system restore and it didn't help. i have checked the fans to make sure they are working properly, checked the ram and not finding any problems with them. i work for a school and we have 8 of these acers and they are all doing this and it just started today. the first thing that came to mind was the av 2009 virus but i am not finding any sign of this on the machine.
  • CazG Jan 26, 2009
    Acer Power reboots just as described by kwillis abd the problem started today , 26th
  • kwillis Feb 06, 2009
    IT IS AN AVG ISSUE BUT IT IS ALSO AN ACER ISSUE. ACER HAS A COUPLE OF PROGRAMS LOADED THAT DON'T LIKE AVG. ACER E LOCK AND ACER EMPOWERING TECH. ONCE THOSE PROGRAMS ARE DELETED AVG WORKS FINE. I HAD ONE OF THE ACERS THAT AVG NEVER WORKED ON AND I USED AVIRA. HAVEN'T EVEN HAD THE REBOOT ISSUE WITH THIS ONE.
I'm a PC technician who worked on this exact problem today. Tried everything: ram tests, hard drive tests, looked for bad driver installs, tried everything I could think of and every diagnostic disc my company has. Our solution involved services that ran during normal mode, but not during safe mode. Which service you ask? AVG. We uninstalled it during safe mode, rebooted, and bam. It worked. It may have something to do with recent updates to AVG, but it only happened to this Acer. My Toshiba laptop and our company's Dell's are okay. Try uninstalling AVG: It may not be your particular solution, but it was ours for this comp.
Posted on Feb 06, 2009
  • 107 Answers
Try 2 go safe mode again. be sure you have an updated antivirus anti spyware n malware n pls turn off system restore if you can. you may have a virus on your pc. if this doesnt solve the problem you can remove the hardrive n try 2 scan it on another computer.
Posted on Jan 27, 2009
It turns into blue screen with white texts and from below, its says terminating (memory-something) and has a countdown... and reboots itself. computer: Compaq Presario PC SR5050NX
Its probably saying memory dump and the countdown. This is mostly encountered after some kinda change on the pc. It can be new hardware, software or just plain windows update. Lots of times it ends up being a corrupt driver. Try to boot in to safe mode and see doe sit still do same thing. if not than you know it is software related and you can do system restore. To boot in to safe mode on reboot keep on tapping key F8 and choose safe mode. Once in safe mode if it works go to start, all programs, accessories, system tools and choose system recovery. choose like a week back and click next and this will do a restore to when pc was working, fine. If you cant boot into safe mode it is possible it has issues with hardware and this should be checked out by a pc repair shop. Another option you can try if same mode dont work try to do same thing on boot keep on tapping key F8 and instead choosing safe mode try choosing Last Known Good Configuration. this is similar to restore. Hope this helps.
Apr 17, 2011 | Compaq Presario 2200 (292600-004) PC...
COMPUTER WAS TURNED OFF IMPROPERLY. TURN-ON WAS IN SAFE MODE NOW EVERYTHING IS LARGER AND BLURRED
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general
dpi normal size,larger size or custom settings
always click APPLY after making any changes
don
Feb 02, 2011 | Computers & Internet
Acer 9300, when I start up it last about 5 minutes before it is finished. When I reach windows acer says there is problem with your secure disk reboot your system. What can i do to solve this?
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Mar 09, 2010 | Acer Aspire 9300 Notebook
Repair XP on Acer F5 Series Towers
Go in to your computer in safe mode, use the restore feature to fix your problem
Dec 21, 2009 | Racer AcerPower F5 PC Desktop
Acerpowerfh keeps turning on and off rebooting why?
it does sound like a boot virus problem. you need to boot into system restore. to boot from the restore partition you need to switch on your pc and repeatedly press either F10, F11, Alt+F10, or Alt+F11. you do this until you see the system restore starts. you will be able to fix windows, or you can do a desturctive restore and restore your pc back to factory settings, but you'll loose your photos and anything saved on the hard drive.
Apr 22, 2009 | Racer AcerPower FH PC Desktop
I have a AcerPower FH P4 -- 100% CPU usage all the time prob...
Boot your PC into "Safe Mode" (tapping the F8 key on boot to get to the option) and run a full/complete Virus scan with Anti Virus with up to date virus definitions and see what that yields.
Feb 09, 2009 | AcerPower FH - P4 631 3 GHz (S6463624) PC...
System keeps rebooting
Ok, here may lie the problem, its probably an issue with one of the updates from MS.
Disconnect one of the PC's from the network, boot into safe mode and uninstall SP3 and the Video drivers.
After you have done that boot in normal mode to see if the system still restarts
Post back with the results please
Good luck
Jan 26, 2009 | AcerPower FH - P4 631 3 GHz (S6463624) PC...
System keeps rebooting when it gets to the desktop
The problem is actually with eLock2FSCTLDriver.sys. So if the eLock program is uninstalled in safe mode, as it is crashing out the network initialisation, then the system will reboot as normal. It has no interaction with the AVG program, and this is official from AVG, and is a problem between Acer eLock and MS updates. Jon.
My computer keeps rebooting
yes go into safe mode then go to a restore point ?
Feb 23, 2008 | IBM NetVista A40i (2251VAU) PC Desktop
AcerPower FH - P4 631 3 GHz (S6463624) PC Desktop Logo
441 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
