Question about Philips 47PFL3603D LCD TV
My phillips 47pfl3603d/F7 shut off and won't come back on
I left the tv on while i ran out of the house for five minutes. When i returned the tv was off and wouldn't turn back on. Not sure what to do. Any help would be great
proton77
  • 1183 Answers
SOURCE: need code for comcast remote control
HI,
Could you kindly give the exact model of the comcast remote that you are using.
Thanks
Proton
Posted on Jan 03, 2009
jmgldsmth
  • 1889 Answers
SOURCE: TV keeps shutting down.
the power relay contacts are burned replace the relay
Posted on May 21, 2009
  • 336 Answers
SOURCE: i can't get my philips
You need to select the source of your home theater system. Press <SOURCE> on the home theater remote to switch between DVD, TUNER, and LINE modes. Select LINE, then you should now hear audio from your TV, Please make sure that your TV is not muted, just increase the volume until you hear audio on home theater. Also increase the volume of your home theater.
Regards,
Jeep Brainy
Posted on Jul 26, 2009
SOURCE: phillips tv 42pfl3603d/f7 when I turn on it makes
signal board
Posted on Jan 07, 2010
  • 17 Answers
SOURCE: Phillips 47PFL3603d-f7 blinks when turned on
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this
Posted on May 13, 2010
Is a 473603d/27 phillip power supply board compadible to a 473063d/f7 power supply board
More than likely the old board just a, or a few, blow, capacitor(s). It you have a soldering iron, you can replace them yourself for just a couple of dollars.
Just look for puffed-up little can-shaped thingies, unsolder them, and buy replacements for a buck or two down at Radio Shack, and you should be "good to go"!
Easy fix, and cheaper than a replacement board.
I would think the /f7 board would work, if it has the same connectors as the /27 power supply board.
Jul 26, 2014 | Philips 47PFL3603D LCD TV
PHILIPS 40PFL7705DV/F7 keeps shutting off
If it is a new TV and under warranty, return it. There is an internal fault and it needs to be serviced.
Oct 25, 2012 | Philips 40pfl7705dv/f7 40 Hz 120 Led Tv -...
Phillips 47pfl3603d blank screen with sound
if the Tv have back light the problem is t-con if not the problem is inverter
Jun 06, 2012 | Philips 47PFL3603D LCD TV
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Need to find out a part # for my philips 52PFL7403/f7 for the ir sensor
Join Date: Nov 2011 I have a Philips 47PFL3603D/F7 with the same problem. It was the IR sensor board causing the problem. You can search online to find the board, which almost everyone will most likely not have in stock, and cant be ordered. The part you need is this: 313926859181 IR Remote Sensor.
Models it will fit are as follows: Substitute Parts 313926859182
Known Models
MAGNAVOX 42MF438B/27
MAGNAVOX 42MF438B/F7
MAGNAVOX 52MF438B/27
MAGNAVOX 52MF438B/F7
PHILIPS 32PFL3403D/85
PHILIPS 42PFL3403D/27
PHILIPS 42PFL3403D/F7
PHILIPS 42PFL3603D/27
PHILIPS 42PFL3603D/F7
PHILIPS 47PFL3603D/27
PHILIPS 47PFL3603D/F7
PHILIPS 52PFL3603D/27
PHILIPS 52PFL3603D/F7
If you can find the board, great! A replacement board costs about $12.00. If you can't... we'll there is something you can try ; )
Either way, if you know it's the board, what's the harm in trying?
Remove the back from the TV. You can actually leave it on your stand to do this if you can spin it around to gain access to the back of it. Be sure to unplug everything first!!!
Looking at the back of the tv, the board will be located in the lower left side by the speaker. It will have 2 cables attached to it. Remove them, and take out the screw or two that holds it in place. There will be a plastic tab that keeps it in place also.
Take your fingernail and bend the tab back, and the board should come free. After that you should be holding the board in your hands. The side of the board with the connectors on it is the side you want to manipulate. There will be a tiny surface mounted capacitor beside one of the wire connection sockets. Take a utility knife and scrape it off/ you could use a soldering iron but it should come off very easy with a knife.
Plug it back in, and give it a try! If it works... great! If not, find a replacement board, and try that.
May 30, 2011 | Philips 52PFL7403D 52 in. LCD HDTV
I have a Phillips LCD tv model# 32pfl3505d/f7 after about an be it shuts off by itself. Can u help me please
Hello; there is some confusion with your model # and symptom ! A model# 32pfl3505d/f7 is a 32" LCD TV not a 27" After WHAT does it shut off? This seems very similar to a set I just repaired. My customer's set was a mode l# 32pfl3514d/f7, which may be same or similar to this one. Here is what happened ; The set would run for about an hour and shut off and come back on repeatedly. The problem was a bad digital board ( the one on the lower left side with all the jacks as you face the back of the set ). I found this $150 board on EBAY for $33. He still has about 30 of these boards. You probably have the same set and same problem. John
Dec 19, 2010 | Philips 27PT643R 27" TV
I am looking for all replacement fuses in for the 47" model, model # 47PFL3603D/F7
Best thing to do is contact a local tv shop, some fuses are specialized so its best to be sure you are getting the correct values. we sell them for a couple of dollars each.
Oct 30, 2010 | Philips 47PFL3603D LCD TV
May 29, 2009 | Philips 47PFL3603D LCD TV
Philips 47PFL3603D LCD TV Logo
133 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
