Question about Aquacal HEAT WAVE H155 132,000 BTU -
My aquacal is frozen on LP how do I fix this - Aquacal HEAT WAVE H155 132,000 BTU -
How do i wire an aquacal 155 heat pump?
Contact a pool supply store or the manufacturer for manual.
Jun 03, 2014 | Aquacal Heat Pump Pool Heater 155
Leak in heatwave aquacal
replace aquacal exchange or where leaking
May 20, 2014 | Jandy LXI 300 PROPANE POOL HEATER -
LPS
Liters per Second.
Rod
US Parts Center
May 02, 2013 | Aquacal Super Quiet Electric Pool Heat...
Flo light stays on unit wont start
if you have backwashed filter(sand) and or cleaned your cartridge filters it probably the pressure switch. locate it and check connections...replacing it is fairly cheap and easy to do
May 05, 2011 | Aquacal HeatWave
What does HP5 mean on my heat pump?
please refer to page 51 of this manual. http://aquacal.com/heat-pump-information/support/manuals/pdf/man-AT_HW_SQ.pdf
This explains that it is either due to your pump not pushing enough water.
Or the pressure switch is clogged or failed.
Or the wiring has shorted.
Check to make sure the circulation pump is not clogged and flowing freely.
make sure the filter is clean and flowing freely.
if this does not fix the problem, replace the pressure switch.
refer to page 56 for pressure switch identification.
Nov 18, 2010 | Aquacal HEAT PUMP 120,000 BTU H135 -
AquaCal Model 120 AHDEBNC message on panel wont clear. Message is FLO. There is water flowing thru the heater and the filter is clean
If you have a by-pass, (This will be a pipe that runns in between the in and out pipes on the heater) The valve must be almost closed in order to get enough volume through the heater to get it to run.
Make sure that heater has enough time to respond to this adjustment. It will take up to five minutes to start.
Oct 27, 2010 | Aquacal HeatWave
HEAT PUMP SAYS WATER TEMP IS 99 DEGREES WHEN ITS 82 CAUSEING PUMP NOT TO TURN ON WHATS THE REMEDY NOT SURE ON BTUS MODEL NUMBER IS 120AHDEBNC AQUACAL kind of in a bind thanks
This is a bad temp sensor or an open by-pass. You would have to go to your book to find these though. I'm not sure where you would find them.
Oct 13, 2010 | Aquacal HEAT PUMP 120,000 BTU H135 -
I have a AquaCal Heatwave H125C-A Pool Heater. The Heater is working in that the power is going on and the air is blowing- although- the air is usually colder than the outside air and now it is only air...
Sounds like your compressor is not running. After your fan goes on in one to five minutes you should hear the compressor kick in. If it does this and then kicks out again it can be something as simple as water flow and you can adjust the valves to get more or less flow to keep it running. If not you probally need a repairman. It is ether your compressor or the capicators that start the compressor and this is all high voltage. Good luck.
Jan 25, 2010 | Aquacal HEAT PUMP 120,000 BTU H135 -
Aquacal HEAT WAVE H155 132,000 BTU - Logo
Top Aquacal Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you an Aquacal Pool and Spa Expert? Answer questions, earn points and help others
