Question about Dryers
Dryer runs for a little while and then shuts off an all the lights blink. Can't keep it running for longer than 10 minutes
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
Maybe it's the heater element how long have u had the dryer and do u clean the lent screen out alot if NOT then it could be shutting off because the heater is burned up
Posted on Jan 21, 2013
Master_Tech
  • 770 Answers
SOURCE: Whirlpool Duet dryer error code
E1=Thermistor open
post your email and i will send you the steps to fix and check it too much to type here
Posted on Aug 05, 2008
  • 61 Answers
SOURCE: dryer makes squeaking noise ,then dryer shuts off. mdl.#CYG4000AWW
Hello, sounds like the rear drum rollers are in need of replacement which is causing the motor to get hot and cut out on the thermal cut out. It can be tricky to service if you not handy. Good Luck
Posted on Dec 26, 2008
SOURCE: Kenmore 80 series dryer stoping after running for 10 to 15 minute
Start any cycle. Dryer runs for 10 to 15 minutes, then stops before cycle is complete. Start again, stops again in 10 to 15 minutes.
Posted on Jan 26, 2009
dragonsthatk
  • 547 Answers
SOURCE: FRIGIDAIRE AFFINITY ELECTRIC DRYER NOT STOPPED HEATING
eleiment
Posted on Feb 18, 2009
  • 125 Answers
SOURCE: my whirlpool dryer keeps shutting off
make sure the vent pipe (and the lint trap) is clear and not plugged with lint
Posted on Aug 24, 2009
My Maytag Bravos dryer is shutting off after running 10-20 minutes. Will not restart for an hour. Feels very warm
Have you considered calling a repairman .. sounds like you have a thermal overload malfunction .
Mar 16, 2016 | Maytag Dryers
WHY IS MY LG GAS DRYER NOT ADVANCING TO COOL DOWN CYCLE?
If its a newer dryer, they have moisture sensors that determine if it should shut down early or stay on longer if needed. Let it run the extra time and see what happens. If it keeps doing it, then the sensor is defective.
Feb 21, 2016 | LG Dryers
How do I make my Frigidaire Affinity dryer stop beeping and run?
Have you checked the lint has been cleaned off filter and water reservoir emptied.?
Dec 09, 2014 | Frigidaire Dryers
I took my dryer apart and found a staple on cushion of barrel. I did not remover circuit board and may have damaged something. When torn dryer on the timmer light shimmers and will only dry for 30 mi
sounds like u may have a motor winding going bad will usually run 20-30 minutes then shut off and if u run agin right away it will run 10-15 minutes and shut off agin. run an hour later and u will get 30 minutes or so agin? or u may have bad venting causing an over heating prob
Oct 28, 2014 | Maytag MDE2400AYW Neptune Electric Dryer
The dryer starts then after about 10-15 minutes it stops and all of the buttons are blinking.
how long b4 u can start it agin?
Dryer runs then shuts down wont start up for an hour:
Bad motor windings
Jun 02, 2014 | Frigidaire GLEQ2152ES Electric Dryer
Dryer runs for 10 mins and shuts off.
Your dryer motor has a thermal overload built in to it. If your symptom is shutting down allow to cool and it works again for a few minutes the shuts down again.
http://www.on-timeappliance.com/dryerrepair.html
Mar 28, 2012 | Frigidaire Dryers
Bosch WTMC3500UC gas dryer runs but does not heat
my dryer does not put out lint, rather thru the front.
Aug 22, 2009 | Bosch Dryers
Dryer will only run for 10 minutes at a time
Hi, this is heat related. the timer module on this unit is overheating, in return, it is shutting down due to the heat generated but the faulty timer circuits. you will need to replace the timer device asap.
May 27, 2009 | Kenmore 73952 Gas Dryer
Dryers Logo
104 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
