Question about ViewSonic VE710b 17" Flat Panel LCD Monitor
After working perfect it just went dim
Not much more to say then it looks really dim but you can still see the screen... anyway to fix this thanks
  • 3 Answers
See the existing topic 'monitor_barely_readable_dark_but_display'.
Posted on Jan 29, 2009
Tv went black no sound either. TV only five years old,is there anything i can do? Thanks James
Cannot offer solution but my mine has also gone bad.  At first a black shadow appeared on the left side of the screen.  Took it to the authorized service center.  they kept it a few days, said nothing could be done.  Used it anyway for the next 5 years when suddenly it went black (or sometimes blue) after working perfectly for the first 5 minutes. A sharp rap next to the right speaker fixed it a few times, but no more.  Good luck.
Jul 18, 2011 | Maxent MX5020 50 in. Plasma Television
My ipod touch works perfectly however i i turned it of once and the screen went blank almost completely. i could hardly even see it under a realy bright light. how can i fix this? or is it unfixable, do i...
After many years of developing for the iphone, I've come across this problem many times.
  1. If your ipod is stuck on this really dim lighting and connect be used, just leave it alone till it runs out of battery on its own.
  2. When the ipod is completely dead, just recharge fully.
  3. After the ipod is charged, proceed to turning it on.
  4. If the light is still dim, go to settings and set the brightness.
  1. If your ipod is usable but you cannot change the brightness, reset the entire ipod manually (hold the on-off button for a few seconds).
  2. When ipod is shutdown, hold the on-off switch again and wait till it reboots.
  3. Then go to settings and change the brightness to your liking.
If you require further assistance, please feel free to reply to this post. Also please don't forget to rate me if I have helped.
Thank you for using FixYa.
Feb 17, 2011 | Video Game Consoles & Games
Dimming of viewsonic 42" LCD
Change power supply capactors. you will see two capactors that have the tops bubbled out,change them and unit will work great.
Apr 14, 2010 | ViewSonic N2750w 27 in. HD-Ready LCD...
My ipods brightness doesnt work is very dim when i turn the brightness up or down nothing happens the screen just stays very dim all the time i restored the ipod and still the same
Well as you probably figure, you're back light has probably crapped out. However I would reset it by holding both the menu and center buttons at the same time until you see an apple appear on the screen. If the back light does not come on then, try the settings one more time. If there is still no backlight at this point; I would go ahead and connect it to your computer and restore it using itunes. Sadly if you still cannot resolve your issue at this point you will probably want to call apple tech support about it at 1-800-APL-CARE (1-800-275-2273) If your still under warranty they should cover all expenses on the repair or replacement. (Just don't admit to any kind of accidental damage)
Apr 21, 2009 | Apple iPod touch
Lcd screen leaked/broke by itself???
Yeah i bought the phone and 2 months later the screen went all funny. the phone shop said it was my fault and it would cost 80 euro to fix:o.....
I am going to buy a replacement screen on ebay and my dad is going to replace mine for me .... My friend had the same problem with a different make of a samsung and she bought a new screen and installed it and it works perfectly :)
hope this helps yuh guys :D
Nov 15, 2008 | Samsung J700 Cellular Phone
Screen went dim. very faint immage still in in good light. i bought a screen on ebay, the seller said it worked, i hooked it up, it does not work same as my old screen. Could the problem be the inverter?...
it might be the inverter but with out knowing if it is a flat screen or a reguler monitor i will not be able to tell you . you might have to take it to a computer place near you but for now my suggestion is to plug your old one back in for now intell you get the other on looked at
hope this works for you
Aug 19, 2008 | Computers & Internet
The lights on the instrument panels as well as the radio flash at intermittent intervals. There seems to be no rhyme or reason as to when this happens (i.e. hot or cold car, bumps or no bumps, turns or no...
I had intermittent instrument light problem that went dark for months, until today. :o) I read somewhere that it could be the dimmer switch and didn't think that was my problem as the dimmer worked (dimmed the radio and transmission indicator light) and playing with it never seemed to help with the problem. I did find it odd that dimmer was not completely linear, as it would get brighter up to a certain point and get slightly dimmer with the last little bit of travel.
Today, I took the instrument cluster apart to fix a broken clock, sticking gas & voltage gauges, and to explore the instrument light problem. I took apart the dimmer switch, and to my surprise (was expecting a simple POT), it was a very complicated PCB with some IC's, resistors, transistors, etc. I thought, "all this just to dim the light???" Anyway, I found the POT (potentiometer) and gave a few squirts of WD-40 and found it turning smoother. After putting it back together, the instrument light came back and the dimmer is now perfectly linear. Apparently, less than perfect POT causes some sort of funny logic through the network of IC's and transistors and can cause the instrument light to go on or off randomly at certain intervals.
Anyway, I'm so happy to have the light back along with a working clock and not having to punch the instrument cluster to see how much fuel I have. Not really a posting type, but wanted to help someone else out there with a similar problem with same cause.
1989 740 Turbo
Jul 29, 2008 | Volvo 960 Cars & Trucks
Monitor isn't working
just replacing the fuse should help. There are two of them on the inverter board. depending on which one is blown will give you 2 different issues. One will cause the screen to flash content perfectly for two seconds and then drop out. the other will be really dark if can see any picture at all,
Feb 10, 2008 | ViewSonic VX900 19" LCD Monitor
ViewSonic VE710b 17" Flat Panel LCD Monitor Logo
145 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
