Question about Nikon Coolpix 880 Digital Camera
Coolpix 880 aperture stuck in closed postition
Looking into the lens there a appears to be a small black button or rear cap filling the hole where the aperture should be.
    Genius:
  • 1,019 Answers
Hello Norm, On a digital camera you should see something that looks like a fish eye, If this appears cloudy looking than it is bad. It is called the CCD unit and will require replacement by a repair shop.
Posted on Jan 25, 2013
  •  Norman A Bolduc
    Norman A Bolduc Jan 27, 2013
    Hi Russell, Thanks for the reply. The "eye" or "button" looks more like a part of the canera lens system rather than cloudy. I have found a repair shop to look at, but not the time as they keep unusual daytime hours and I have to work. I will however be taking it in soon..
  • 23 Answers
SOURCE: Nikon Coolpix S5 lens cover won't open
Hi Debscan, My 1.4 year old S5 developed the same problem and after checking out various websites I get the impression that it is a common one to these cameras. I found that if I put the camera on a level table and then turn it on (and off) 3 times the lens cover would open further with each try. On the third turn-on the lens cover would drop fully with a definite "Click" and the camera would work. The next time I shut it off, the lens would not close properly, but the same "Third times the charm" routine would always work. This may only delay the inevidable final crash of the camera, but it might get you a few more pictures out of it.
Posted on May 25, 2008
PAPA-RAZI
  • 37 Answers
SOURCE: coolpix lens opens retracts opens then closes again and lens error appears
Hello
When you turn the camera on the lens comes out and has parameters when extending to focus, if the lens does not open fully it sees a problem and then closes.
there are tiny plastic gears inside and may have chipped or a piece of sand got in causing the lens to jamb. "very fragile"
one solution is to ask a camera repair shop how much a lens mechanism would be to replace. (if cost is more than 1/2 of what you paid dont bother)
another solution is to have someone sell your camera on an auction site for parts, to make some money towards another camera purchase
Posted on Sep 02, 2008
SOURCE: I was using a Coolpix L20 when the lens stuck open
I have a coolpix l20 the lens is stuck Iam looking for a repair manual? Would like to fix it my-self
Posted on Feb 06, 2010
  • 11967 Answers
SOURCE: camera's lens is stuck
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 23, 2010
  • 1382 Answers
SOURCE: nikon coolpix s60 lens error? the lens won't
Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to auto focus while the lens is extending, hopefully seating the lens barrel guide pins in their slots. Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Thank you!
Posted on Aug 17, 2010
Testimonial: "thanks!!!!!"
My Coolpix L320 was working fine, then all of a sudden got stuck with the lens zoomed all the way out and a message on the screen that says, "Turn the camera off, remove the lens cap, and turn the cam
after changing the battery and gently push back on the lens it should automatically close if not then check around it it must be something stuck in between it
Jan 18, 2015 | Nikon Coolpix L320 Black Digital Camera...
Flashing err on nikon n50
Hi Jennifer,
Not too sure what that is, but first thing I would check is that you lens is set to its smallest aperture, such as f/22. Many times that err message means the lens is not closed down all the way. After closing the lens down the camera dials will set the aperture. Also, on many Nikon D type lens, not the G type, there is a small push pull button to lock the lens as it smallest opening.
Cordially,
Mar 06, 2013 | Nikon N65 35mm SLR Camera
I was looking for right size of filter (or protector for lens) for my Nikon Coolpix P90. It's so complicated. what can u advice me? Thanks in advance
Look on the fron of the lens, it should say something like Auto Nikkor 24-50 f3.5/5.6 ( or similar) that is the mamximum aperture at different zoom levels. besides that it may say something like 37mm either on side of lens near front or on front itself. If you have the lens cap, look inside the lens cap, the size is usually marked there and your camera uses the same size screww on filters.
Nov 15, 2010 | Nikon COOLPIX P90 Digital Camera
When I press the on/off button to open my camera a message appears stating 'Lens error' and the lens automatically opens and closes a couple of times before closing so I cannot take any photographs. How...
Hi!
Most likely the focus is stuck. Could be sand or some dirt inside focus gears. They're very small for these lens which are used in many Nikon, Olympus, Casio and other cameras so even one small piece of sand can block the focus system. The only way to fix it to take the camera and lens apart and clean it.
Sorry for the bad news. I repair cameras every day and you can trust me - I know what I'm talking about.
Tom
Sep 23, 2009 | Nikon Coolpix S210 Digital Camera
I was using a Coolpix L20 when the lens stuck open and I got a Lens Error. The lens won't close and the camera won't work. Please advise.
Aug 19, 2009 | Nikon Cameras
Black screen
Hi
Your lens is aperture is most likely stuck closed and the lens needs to be replaced. If you can see menus but can take only solid black photos then it is either the CCD or the aperture; most likely the aperture.
We have never been able to repair a stuck aperture, we always have to replace the lens on the camera. A CCD can be replaced, but you need a CCD to use and they are only sold as part of the entire lens assembly.
There are online places that will do it for a decent price and there are others that overcharge by way too much.
I know this because I OWN ONE that charges a reasonable price to do the repair! (Google 'darntoothysam')
Just let us know if we can help! Good luck from
Darntoothysam com
Thomas
Jul 15, 2008 | Canon PowerShot SD850 IS Digital Camera
Camera lens will not close
Hi:
Sometimes you can try to get it unstuck by looking at the lens at is is. Then determine if it appears to be at a slight angle, if so, it may be that you can force the lens in the opposite direction. This may not work, and may damage the lens further, however, since it is not working, trying may be just what is needed.
I have had some success by forcing the lens in the opposite direction as it is turned on with pressure of my fingers pushing it. It has not always worked, but I have two which worked just fine... one was a 7.1mpxl nikon and the other was a 8mpxl Canon.
They both were off track, and jumped back by a little force.
If the lens was hit or dropped, then damage can be more than can be fixed. What can happen is that the small track parts can be broken, then there is no way to get it back on track.
Also, dirt or sand can do a number on these small parts. It is amazing how these extremely small pieces of sand can jam a lens, but I have seen it happen.
Take a hint and keep the camera away from sand and water, or risk trouble.
Jun 11, 2008 | Nikon COOLPIX L3 Digital Camera
Error message on D40
The guy at the camera store is probably right. The aperture is controlled by a small leg that juts out from the lens mount. This leg/lever moves up and down to open the aperture. It could be stuck or broken. Try holding the lens (small end pointing towards your face) and peer into the lens as if you were taking a picture. Find the aperture guide (a small rectangular lever) and slide it up and down. You should see the aperture blades open and close. If they do, the camera is malfunctioning and in need of repair (warranty?).
Jan 17, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Camera will take pictures but they are all black.
Your CCD is damaged, OR your aperture is stuck closed in your lens. Turn on the camera, have the lens extended and look into it, do you see a small circle at the bottom that looks like an opening? If not your aperture is stuck and you need a new lens. If its open, your CCD is bad and needs to be replaced. www.darntoothysam.com
Nov 30, 2006 | Canon PowerShot SD300 / IXUS 40 Digital...
Nikon Coolpix 880 Digital Camera Logo
Top Nikon Cameras Experts
Greg Cann
Greg Cann
Are you a Nikon Camera Expert? Answer questions, earn points and help others
