Question about Yamaha RX-V473 A/V Receiver Black
No hdmi sound from yamaha v473 receiver - Yamaha RX-V473 A/V Receiver Black
Ajkill
  • 2035 Answers
SOURCE: Strange Flicker with HDMI components
Reset the yamaha player to factory sttings and check if the issue still exists ,unplug all the cables and replug the cables if the issues still exists its the problem with the Yamaha receiver, please get it changed as its a new player................................
Posted on Jun 10, 2008
mlapres
  • 757 Answers
SOURCE: how to hook up a xbox 360 console to my yamaha 6130 receiver
You will need an additional HDMI cord...you can get them without getting ripped off by purchasing at bluejeanscable.com.
Connect your HDMI out from the xbox to the receiver. Connect the additional HDMI cable to the "out" HDMI connection on the receiver and connect the other end of it to your TV.
Posted on May 08, 2009
smarthome2
  • 1114 Answers
SOURCE: no sound from cable via V665 receiver
Can't pass HDMI thru this or any other receiver with version 1.1,1.2,1.2a,or 1.2b. HDMI is riddled with issues! it's not Yamaha, it's HDMI. The current version 1.3b is working "so far" If your receiver is still under warranty, Yamaha will update the software and hardware at N/C. If it's out of warranty, Run HDMI directly from source to TV and Audio to your receiver via optical or digital coaxial. For more info than you can process, google "HDMI forums" and there are over 73,000 posts/sites/etc. If you need further info, post a comment and I will be glad to help.
Posted on Aug 23, 2009
  • 9 Answers
SOURCE: i have a yamaha htr 6130 trying to run a ps3 via
The HTR 6130 only HDMI passthrought VIDEO, no sound. If u want sound u need to connect sound cables: rca, optical, etc.
Posted on Sep 09, 2009
smarthome2
  • 1114 Answers
SOURCE: Yamaha Receiver RX-V463
Do not use HDMI thru your receiver. Go directly from the Cable box to the TV. Connect coaxial digital or optical to your receiver. Your receiver uses HDMI version 1.1 or 1.2, which is riddled with issues. If you want to read about them, Google HDMI Problems and you can read for hours. Long of the short of it is; Don't pass HDMI thru your receiver, use the receiver for audio only. Hope this answers the question. Sorry for the bad news! I'm in the industry and have been dealing with these issues for a couple years now.
Posted on Dec 16, 2009
My yamaha rx-v473 wont turn on
disconnect all wires from behind unit, speakers, input, and then try to power it up ,
if problem persist then try to tighten screws on back panel of the unit,
may sound silly but if amp board does not have good ground connection it can do that , go in protect mode .
happened to me ...
Jan 26, 2013 | Yamaha RX-V473 A/V Receiver Black
No front display on my yamaha RX V473 only red light
Does the power relay click when you press the power button? It may be the main transformer has gone bad.
Jan 17, 2013 | Yamaha Audio Players & Recorders
Yamaha rx v473 system cuts off periodically - check speaker wires message comes on
You have a short in a speaker or speaker wire, or you are over-driving a speaker.
Jan 14, 2013 | Yamaha Audio Players & Recorders
Yamaha rx v473 cuts off
disconnect all speakers, turn it on. If it stays on, connect one pair of speakers at a time and when it shuts off, that speaker is the problem. There may be a short in the wire or the speaker may be bad. If you get that far, try connecting the bad speaker with another speakers wires.
Jan 14, 2013 | Yamaha RX-V473 A/V Receiver Black
Optical input shutdown receivers
If they shutdown it is because they are getting to hot, Keep the vollume down to a cival leval,
Nov 28, 2012 | Yamaha Rx-v473 5.1-channel 3d Network Home...
My Rx-V473 won't turn on
It couldn't start after an update. I found how to fix it on the product page : http://download.yamaha.com/search/detail/?language=en&site=europe.yamaha.com&asset_id=58063&category_id=16446&product_id=1643029&1375038490
Receiver doesn't power up after the update.
Error message appeared when confirming the firmware version.
Recovery method using USB method:
1. Unplug the AC power cable from wall outlet.
2. Insert the USB thumb drive which has the firmware data stored inside, into the USB port located on the front panel.
3. Press and hold the INFO key and keep it pressed while you plug the AC power cable back into the wall outlet again.
" USB UPDATE " will appear on the front display. Then, release the INFO key.
4. The update will start automatically.
5. When " UPDATE SUCCESS " appears on the display, firmware update is completed.
Power off the receiver and remove the USB thumb drive.
6. Confirm updated firmware version.
Oct 18, 2012 | Yamaha RX-V473 A/V Receiver Black
No sound from cable via V665 receiver
Aug 22, 2009 | Yamaha RX-V463 Receiver
How to hook up a xbox 360 console to my yamaha 6130 receiver
Apr 01, 2009 | Yamaha HTR-6130 Receiver
I have a Yamaha Rx-v363 receiver using HDMI jacks but I am not getting any sound through my surround sound only my tv speakers. I have a digital audio optical cable running from the receiver to the blue...
this sounds strange, but is true. you need to run your digital audio optical cable from your tv to your receiver (after, of course, connecting tv/receiver via hdmi). so, hdmi from blue ray to rec - hdmi from rec to tv - then optical from tv back to rec. it's round about, but that is how yamaha says (and the only way it works) to do it.
Jan 02, 2009 | Yamaha RX-V363 Receiver
Yamaha RX-V473 A/V Receiver Black Logo
325 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
