Question about Dell Dimension 4500S PC Desktop
I have a Dell Dimesion 4500s. A black screen comes up with this Strike th eF1 key to continue, F2 to run the setup utility. I have gone thru the steps over and over again and afraid that I might do so
Have went through alot of the steps but nothing also freezes when the blue screen comes up Stop: 0x0000008e (0xc0000005, 0xF84c6F3E,0xF80B1778,0x00000000).
    Scholar:
  • 58 Answers
According to the issue you've got, the following tips may be available to you.1.An efficiency troubleshooting step on hardware is to start your computer with the minimum hardware necessary to run the operating system. If your computer starts successfully it proves that one of the removed hardware devices was the cause of the STOP message. Otherwise move to the next solution.
2.Boot your computer in Safe Mode by pressing F8 at startup. Then go to My Computer and right-click on Disk C to select Properties from the dropdown menu. From the Tools tab, perform an error check and disk cleaning. 3.If the about two solutions doesn't work, the last one I can suggest to you is to create a bootable disk. It is the most quick and effective way for you to solve the problem. You just need to download a software can burn your CD/usb into a bootable one and then boot your computer from it. Run the software to fix the issue after that. There are few free software for you to use, so if you want to take this solution money is indispensable. Windows Boot Genius owns a better cost/performance among other kinds of software I've used. It may be a good choice for you if you have money to pay.
By the way,reinstall your operating system can also help you out if nothing important stores in it.
source:http://www.reset-password.net/black-screen-of-death-and-blue-screen-of-death.html
Posted on Jan 21, 2013
sandrew
  • 2961 Answers
SOURCE: Plug & Play Configuration Error
this may not be your ethernet card that is causing the fault, it is probably a flat cmos battery (CR2032) disc shaped battery normally close to the memory slots. This will need to be replaced, it's a simple job, just remove side panel of tower and flip the battery out and replace, probably cost $3.00. You will then be prompted on the next boot up to press f2 to set the date and time and then save and exit again for a reboot
Posted on May 29, 2007
  • 166 Answers
SOURCE: pc won't boot
Any leaking brown stuff means blown capacitors- DELL (along with other manufacturers) were sold some "fake" capacitors and they didn't have all the correct ingredients to perform like they should. After about 2-3 years of use they started to break. DELL was replacing them mobos for awhile, even after the warranty ran out, but that deal is probably over. I know because I was able to replace several of them - out of warranty.
As far as your hard drive goes, Do you have an IBM Deskstar, also a.k.a as DeathStar? If it says it can't find the hard drive and you did not change the cables or mess with the jumpers and you have checked that the cables did not come loose from the motherboard and drive, then you most likely have a dead drive. You can always try to recover from the recovery console using CHKDSK. I have recovered a few drives this way. If you do recover then get your files off immediately.
Posted on Mar 09, 2009
MPetro302
  • 298 Answers
SOURCE: dell dimensions 3100
sounds like your floppy drive is failing, you could get it replaced or simply turn it off via the BIOS.
to turn it off simply hit the F2 key. On the first screen usually it will list your Hard Drives, CD ROMs', and the Floppy. scroll down to the floppy and hit enter ot the corresponding key form the bios's legend at the bottom or right hand side of the screen untill you see disable.
Next you can navigate to Save & exit or hit F10 to do the same. G/L.
Posted on Apr 16, 2009
callonafo
  • 174 Answers
SOURCE: No boot device available - strike F1 to retry
it is hard drive or HDD is damaged or corrupted, i will advice you to buy and upgrade to a new one and then install back the OS, I mean that you need to install back the operating system. Firstly open up the system and remove the old and damaged HDD "hard drive" then put the new one in after you might have purchased, you can get a new HDD from just about any computer stores. After you have put in the new HDD, then reboot your system and put the opearating system CD into the CD drive to start the installation of the OS, follow the instructions carefully. But make sure you get the correct component for the CPU.
If this is difficult for you to do, kindly get a computer engineer or technician to help you out. Thanks
Posted on Oct 18, 2009
SOURCE: strike F1 to continue, F2 to run the setup utility
Got to BIOS by pressing F2,check or any floppy setting and disable it even in boot order setup.This will solve your problem otherwise replace the lithium CMOS battery.
As you have reset the BIOS setting to it's default setting.Floppy drive is enable by default whether your system have a physical floppy drive or not.
Posted on Dec 24, 2009
Error code: 1000-0143
I would suspect hdd errors and replace the drive.
Sep 06, 2014 | Dell Computers & Internet
Floppy diskette seek failure strike the F1 key to
it's not a major problem.go to bios screen by pressing F2 and DEL in keyboard at startup you will enter bios screen there you can change the boot device properties.change the first device to hard disk and second to CD or DVD ROM drive.it will solve your problem
Aug 29, 2014 | Computers & Internet
How do i setup utility on dell laptop d610
If you have a hard drive issue, you need a new hard drive and then download the OS from windows, linux or whomsoever, then the drivers from Dell.
Dec 29, 2013 | Dell Latitude C600 Notebook
Heloo sir i have a problem with my dell 170l when i start it it shows ''strike F1 to continue, F2 to run the setup utility'' when i click f1 it show ''f1 to retry boot,f2 for setup utility'' plz help me...
Hit F2,look in setup to see if the hard drive is recognized and check that the date and time are correct.
Then hit esc key. it will ask if you want to save changes, click yes. It should boot and probably ask you to hit F1 or F2 again., unless there is a problem with the CMOS battery, which may need to be replaced.
If you hit F1 to continue, it will boot, but your time and date will be off.
Dec 17, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 4700 desktop. Turn computer on, go...
try to disconnect, stretch the master cable of Hard drive and then connect it.
May 20, 2010 | Dell Dimension 4700 PC Desktop
Strike F1 to continue, F2 to run the setup utility
Dec 24, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Strike F1 key to continue, F2 to run the setup utility
Please let me know what is the make and the model of the pc that you are using.. Also, go to the bios, under boot menu, make sure that you have hard drive as the first boot option.. For further queries please get in touch..
May 28, 2009 | Computers & Internet
Dell Dimension 4500S PC Desktop Logo
35 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
