Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
Remove lower spray arm from whirlpool quiet partner iii
My dishwasher is not cleaning, and the soap dispenser clogs up, and gets residue on the dishes. I have looked at some DIY sites, and everyone tells me to remove the lower spray arm. I can't get it off! There's a plastic screw in the middle of the assembly that I do not seem to be able to move, it just spins and spins.
4 Suggested Answers
SOURCE: dishwasher is not getting dishes clean. Water is
follow this link:
http://www.fixya.com/support/t2390397-dishwasher_acts_up
that guy gave me some good advice!
Posted on Jun 30, 2009
  • 52 Answers
SOURCE: We have the Whirlpool Gold quiet partner III
Make sure your water is hot, at least 120deg f. Also, use least amount of soap you can get away with. Usually around 2 tablespoons for soft water. Use powdered soap not gel. Gel leaves a tiny residue each load and will clog up plumbing in dw after 4,5,or 6 years. Rinse agent such as Jet Dry is highly recommended.
Try the "Tang" trick. Orange Tang drink mix is mildly acidic. With an empty dishwasher, start and fill, then normal drain. On second fill, add a full jar of Tang then let the dishwasher run for a few minutes. Crack the door to stop the dishwasher and let it sit for several hours or overnight. Then close the door, push start and let the dw run through the remaining cycle. This will sometimes clean out the crud in the water lines.
Hope this helps! Ken
Posted on Jan 06, 2010
  • 64 Answers
SOURCE: how do i remove the upper spray arm on a whirlpool
There is a screw at bottom of arm. Try turning arm before taking screw out. I believe water pressure turns the arm, so if the arm doe not tur while machine is working then you either have a blockage from pump to arm or pump not working properly.
Posted on Aug 15, 2010
I have the Whirlpool Quiet Partner III. It was installed new in July 2007. It is/was used on a regular-basis once a week. Dishwasher was running normally until 5-22-11. Now at end of a full cycle,...
Make sure your water temperature is hot enough to dissolve the soap. Generally, the water temp. should be 140 degrees. Run some hot water at the tap before you turn on the dishwasher. This will assure that hot water is in the dishwasher as soon as you start it. Be certain that there aren't any large pieces in front of the dispenser tray. Sometimes casserole dishes, frying pans or baking pans can block the door and prevent it from opening.
Also, the sprayer arms might be clogged with bone fragments, peelings, bits of paper, etc. If this is the case, you'll need to remove the sprayer arm, flush and then check the jets. If you see "stuff" in the jets, they can be remove with tweezers.
Finally, make sure the upper sprayer arm hose is securely seated with the tube in the back of the dishwasher that carries the water up to the sprayer arm hose. If these two are not seated correctly, the water will not travel into the sprayer arm hose, the sprayer arm will not turn and your dishes will not get clean! I hope this helps. If it does, please come back to Fixya and rate my advice.
Jun 11, 2011 | Whirlpool Dishwashers
When running my Whirlpool Quiet Partner II, the soap cubes do not dissolve. 99% of the time, they just drop down to the bottom of the dishwasher or onto the silverware bin. I tried liquid detergent, and...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Apr 18, 2011 | Whirlpool 24 in. GU3200XTP Built-in...
The soap latch on my Whirlpool Quiet Partner III won't latch....
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Apr 02, 2011 | Whirlpool Dishwashers
Our quiet partner iii dishwasher is not working. It is not gettting dishes cleaned soap left on dishes
Our whirlpool gold quiet partner iii dishwasher is not working well . It is not gettting dishes cleaned soap left on dishes on top primarily
May 16, 2010 | Dishwashers
We have the Whirlpool Gold quiet partner III dishwasher and lately have noticed residue on the dishes after the cleaning cycle is complete. Where is the trap to clean?
Jan 06, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher is not getting dishes clean. Water is
follow this link:
Jun 09, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Not cleaning properly
Our Whirlpool Quiet Wash plus is 20+ years old and was on its way out the door because of erratic white residue, spotting, and film.  Nothing worked: vinegar, different soaps, more soap, less soap. Today I opened it up and started digging behind covers and checking the insides - multiple places were clogged with a soap/mineral film - ugly! I sprayed the insides with Restore 4 (a tile cleaner) and scraped and brushed and broke loose the hidden deposits. The only thing I didn't open was the sump pump - but now know how to do so. (thanks FixYa) Then I added about a 1/2 quart of vinegar and ran it full hot on the heavy wash cycle, added more vinegar between each cycle and let it dry.  It looks super inside - the gunk is gone.  I am now washing a load of glasses and am hoping for the best!
Feb 26, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Gold Quiet Partner IV issue with soap dispenser
This happened to me as well. I think I solved the problem. It started when I first lowered the top rack. In doing so, the door doesn't open all the way. It also won't open all the way if your cutlery rack is in the front and you've put large utensils like a spatula. Consequently, detergent dried under the latch and it wouldn't firmly catch. For months I put up with it never emptying completely. The other day I took a tooth brush and very hot water and cleaned under the latch. After, I could feel a difference in the way the latch operated (with greater pop on opening). So far its been doing fine. Hope this helps.
Denise
Dec 05, 2008 | Whirlpool 24 in. GU1500XTLS Stainless...
Whirlpool Quiet GU2300XTLS2
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
Remove lower spray arm and rear water supply tube to upper spray arm. Remove torx screws that secure the sump cover. Remove the rounded cover on the left side to expose the chopper assembly. Inspect for breakage of blockage. There may be an additional plastic screen to remove first.
Jun 13, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
161 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
