Question about Maytag Washing Machines
How do you replace the front panel on a Maytag top loader washing machine?
I am guessing my machine is about 20 years old. There are two clips that loosely fit into slots on either side of the top of the panel that are used to attach the panel to the top part of the washing machine frame. There does not appear to be a way to attach the clips without having access to inside of the front panel, which seems to me impossible. And once you screw in the panel at the bottom, there is no way to get at the clips either to attach them. What am I missing?
    Sergeant:
  • 291 Answers
If these are the clips i'm thinking of set the panel in place then grab the bottom of panel and stand up so that the panel is parallel to the floor. Apply pressure as you lower the bottom back down. The clips should slip into the slots, but sometimes it takes a couple of tries. When it's good you will know then replace bottom screws.
If this doesn't seem right give me the model number (the one on the machine) and we'll figure out what is right.
Posted on Jan 21, 2013
Jimster
  • 240 Answers
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Posted on Sep 09, 2007
  • 209 Answers
SOURCE: front loader washing machine = black streaks on clothing
I am a recently retired engineer of 20 years once you have ruled out anything getting inside the machine by accident etc, like something in pockets or greasy overalls, then its likely to be the drum bearings, has the machine started to get noisy on the spin the drum bearings are covered by a rubber seal, this seal gets damaged or worn and water leaks into the bearings themselves washing out the grease back into the drum where the washing is, you could also notice slight water marks on the floor underneath the machine on the floor, take the back off and look for water marks coming from the drum outer casing behind the pulley, these marks will be brown and will originate from a small drain hole, if any of the above change the bearings before any real damage is done, either to the clothes or the machine, as repair can be expensive? sorry, hope i have helped you as to where to look at least,
Posted on Sep 19, 2007
Washer_tech
  • 164 Answers
SOURCE: Maytag washer leak
the stem kit, boot seal is worn and leaking. if not repaired soon the bearings on the tub and on the brake package will start to rust and sound like a train going by. After 15 years of service its probably time to replace. Call your local service company and get an estimate on replacement of the seals and weigh that against the cost of replacement of machine. hope this helps. please come back and rate my answer.
Posted on Dec 12, 2007
venexcsd
  • 1185 Answers
SOURCE: Drum came loose on Fridgedaire front loader on final spin cycle.
What was the point of posting this on the site?
The drum has broken loose from the support plate at the rear
You need a new drum and a support plate plus probably an outer shell.
A complaint to the manufacturer may get you a deal on a replacement
Posted on Jun 04, 2009
honeymokey
  • 3113 Answers
SOURCE: Replace Whirlpool M# LSQ9645KQ1 top loading washer lid switch
See http://www.youtube.com/watch?v=WLPGs2UMUJc to remove the case
Posted on Aug 03, 2009
What's the capacity of a Simpson 175 HD washing machine (approx 22 years old). What new top load should i buy? dials or push button?
about 6to7 kg.to b honest the machines i find that last the longest r kleenmaid top loaders,maytag top loader,whirpool top loaders,and miele front loaders, i would try to advoid electronic units.nothing will b as robust as your 175.
Apr 06, 2010 | Washing Machines
Maytag Atlantis top loader washing machine won't spin out water. it spins but the water doesn't go out. it's only about 5 years old. help please!!!
The drain hose is plugged or kinked or the drain pump is not working. Check and clear the drain hose from any debris that might be causing the water not to be pumped out. After checking and clearing the drain hose and the water is still not pumped out of the washer, check the pump to see if the impeller is good or the pump needs to be replaced. Access to the pump requires the top cover and the front panel to be removed. Disconnect power to the washer prior to servicing to avoid the risk of electric shock.
The top cover is attached to the front panel by two clips positioned at about 3 inches from the corners. Use a putty knife and insert the blade into the seam between the top cover and the front panel assembly at the position of the clips.
Push the putty knife blade against the clips, one side at a time while lifting the cover to disengage the clips. Lift the top cover off the front panel then remove the two screws securing the front panel to the upper front corner braces of the cabinet.
Lean the top edge of the front panel away from the cabinet and lift the panel to disengage its bottom from the base clips. Move the front panel away from the cabinet to access the pump.
Disconnect the pump inlet and outlet hoses from the pump then remove the three screws mounting the pump assembly to the base of the washer.
Slide the pump to the rear of the washer to disengage the belt from the pump pulley and pull the pump assembly out of the washer.
Clear the pump inlet and outlet hoses for any debris to ensure water is not blocked from being pumped out of the washer.
Check the impeller. Remove the four screws securing the pump housing to the pump base then lift the housing off the base. Clean the impeller and the pump housing; replace the pump assembly if the impeller is damaged.
To replace the pump, set the pump pulley into the base opening and put the belt on the pulley. Install the mounting screws while holding tension on the belt to keep it on the pulleys.
Connect the pump inlet and outlet hoses and secure it with the clamps.
Position the bottom of the front panel back into the base clips then secure the top to the upper front corner braces of the cabinet with the two securing screws.
Push the top cover down into position to the front panel to complete the procedure.
Note: For Maytag Atlantis MAV8000A, the pump assembly is part number 35-6465.
Mar 22, 2010 | Maytag Atlantis MAV8000
I have a top loader Maytag that is about 5 years old. It has mold that is visible around the top gasket - above the "barrel" How do I completely clean this machine of mold / mildew.
There is 2 clips to raise the top of the washer. You need a flat blade, like a putty knife or similar. while trying to lift the top at the seam, push the flat blade in at the right front corner it should pop up. Repeat for the left, this should let you get to the underside to clean around the gasket etc.
Sep 14, 2009 | Maytag Atlantis MAV6000 Top Load Washer
How do you get the front off the maytag mav8601aww?
If you have the top loader, there is 2 clips on the left and right wher the front panel joins the top section. Push a flat blade in one side while trying to lift the top at the seam, it should pop open. If you raise the top there is 2 screws top left and right of the front panel inside remove these and lift the front panel up and away.
Sep 05, 2009 | Maytag Atlantis MAV6000 Top Load Washer
There is a black tape that seems to be unraveling from my maytag atlantis. This tape is under the top rim of the basket. Any Ideas of what this is and if it needs to be replaced. My machine is 8 years old
Looks like this is the white plastic shield gasket:
You need to remove the front panel, loosen the top panel to be able to remove the plastic shield (it's just clipped on).
Once you have the shield removed, put gasket back in place so you are back in washing business.
Good Luck!
Aug 17, 2009 | Maytag Washing Machines
We have a Maytag Neptune washer Model # MAH4000 AWW it is leaking from the front at the bottom of door. Water pours out like a water fall when it wants to rinse. Any ideas?
TO ELLIESHIRK, I SEE YOU POSTED YOUR PROBLEM ON MAR. 19, 2009. I HAVE A MATAG NEPTUNE FRONT LOADER WASH MACHINE MODEL #MAH55FLBWW. I AM HAVING THE SAME PROBLEM WITH MY MACHINE LEAKING WATER OUT THE FRONT DOOR. MY WASH MACHINE SEAL LOOKS FINE. IF YOU HAVE FOUND A SOLUTION TO YOUR WASH MACHINE LEAK PROBLEM, PLEASE LET ME KNOW, OK. YOU MAY EMAIL ME AT: CJA931@FRONTIERNET.NET , MY WASH MACINE IS NOT VERY OLD EITHER 4-5 YEARS IM GUESSING, IT WAS LEFT WITH THE HOUSE I PURCHASED. THANK-YOU FOR YOUR HELP AND TIME. CONNIE
Mar 18, 2009 | Maytag Neptune MAH7500A Front Load Washer
We have a 17 year old Maytag Washer, Model LA 9700, that is leaking. It is not an outside hose. How do I get inside the machine to look at the internal hose? I can't see anything through the back side...
The front panel should come off your washer allowing you access to the interior cabinet. Along the seam where the top panel meets the front of the washer, there should be a couple of retaining clips. If you take a putty knife and push in, while lifting up on the top panel, the clips should release. Inspect the dispenser hoses, water inlet lines, drain pump, drain hoses, the hose connections to the wash tub and along the wash tub bottom where the tub seal is. If you go to searspartsdirect.com and type in your model number, there are some excellent exploded view drawings showing how your washer is assembled. I hope this helps you.
Aug 06, 2008 | Maytag Washing Machines
Maytag A212 clothes washer, leaking on fill up.
Possibly Injector / Vacuum break unit has gone bad (mine started spilling water lately, 20 years old). Get a 216201 to replace in your vacuum break, or better (if the machine is older) replace everything from the water valve with a kit: SUB 206680 (INJECTOR HOSE KIT).
Quite easy to get to. Just open front panel (remove two screws at bottom, lift bottom of panel away from machine and swing out. Spring clips at top should release easily. Then remove two bolts that hold top cover down and lift top. Water injector/vacuum break will be at the rear left of the machine. Costs about $40 for the kit. Or $5 for the small rubber part (but I am replacing everything that is pressurized on my machine since it is 20yrs old). -- Kevin
Jul 19, 2008 | Maytag Washing Machines
How to remove the front panel of a maytag washer model # MAV7200AW
If this is a top loader. Remove the two screws at the bottom. Pull out the panel from the bottom and the clips at top will release.
Jul 05, 2008 | Maytag Washing Machines
Newbie Question
Look carefully under the front panel. there is a clip on either underside of the front panel. Insert a putty knife or screw driver in the clips to release. Pull the panel upward until the top clips are released. This is one of the best machines Maytag ever made.
Jun 23, 2008 | Washing Machines
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
