Question about Frigidaire PLD4375RFC Dishwasher
Frigidaire PLD4375RFC Dishwasher makes a lot of noise when washig
My dishwasher has started to make a lot of noise when washing and the dishes are not as clean as they used to be.
  • 7 Answers
SOURCE: dishwasher not washing
By chance have you cleaned the spray arm out lately? There could be something blogging the water from getting into the arm. In most dishwashers, the arm only spins because water pressure makes it spin.
Miss Midget
Posted on Nov 02, 2007
kram26
  • 544 Answers
SOURCE: My dishwasher is not washing dishes on the top rack...
HI,
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary . If the motor gear is broken, replace the sump and motor assembly . Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
thanks,
Posted on Mar 18, 2009
  • 555 Answers
SOURCE: Our Frigidaire Ultra Quiet II dishwasher loud buzzing noise- wash
No longer "ultra quiet" huh?
A sound during certain cycles indicates a broken part. By the information provided sounds like a pump may be the problem. You may need to contact a service tech about this issue. If the appliance still under warranty, the service should be provided for free.
Every time when you hear noises (other than the normal ones) in the appliance, it indicates there is something wrong and it will worsen over time, so as soon you hear something is not ok, get assistance.
Posted on Aug 30, 2009
SOURCE: Frigidaire dishwasher model GLD2445RFCO is making noise
I have the same problem with my dishwasher. If you remove the kick plate while it is running, There is an electric motor underneath. If you push up and pull forward on the electric motor, the noise will stop. I used a block to prop it up and the noise stopped. You may want to try it.
Posted on Feb 05, 2010
heatman101
  • 43501 Answers
SOURCE: Fridigaire FDB510LCS3 Dishwasher not washing dishes
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
asdsrtns
Posted on Sep 29, 2010
Incomplete cleaning
check out www.dishwasherfilter.com because there system filters your water before entering the dishwasher. I am sure it will solve your problem and its guaranteed or your money back.
Mar 30, 2013 | Frigidaire PLD4375RFC Dishwasher
Dishes are not getting clean
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter.
Mar 21, 2011 | Frigidaire PLD4375RFC Dishwasher
Upper spray arm came detached
take a good look ,there are two lugs ,from underneath you should see the male /female simply attach and twist .adrian,,,
Jul 10, 2010 | Frigidaire PLD4375RFC Dishwasher
Dish washer gets to hot in pot scrubber mode
did it distort the spray arm? A lot of times if it's the spray arm that melted it's possible that it was jammed while trying to heat the water and the heat from the element would warp it.
Mar 24, 2010 | Frigidaire PLD4375RFC Dishwasher
Jan 08, 2010 | Frigidaire GLD2445RFC Stainless Steel...
Frigidaire pld4375rfc2 dishwasher
don't buy this manufactors products the are not weel made!
Aug 26, 2009 | Frigidaire PLD4375RFC Dishwasher
Dish water tray full of dirty water, does not
It sounds like a plugged discharge line, close to the disposer. With the power off to the disposer and the dishwasher, remove the dishwasher drain line ate the disposer drain. Careful, there will be water there, most likely, so have a pan or buchet to catch the water. Pass a wire back up into the drain line from the dishwasher as far as you can towards the high point of the drain line. Remove the wire and pass it into the disposer (sink) drain, making sure that the piping is unplugged. Reassemble and try.
Regards, --W/D--
Jul 14, 2009 | Frigidaire PLD4375RFC Dishwasher
Frigdaire Quiet II - Dishes in upper portion are not coming clean
My dishes are not all clean when done washing. Also it doesn,t sound like the not a lot of pressure when washing like it did when it was newer.
Jun 30, 2009 | Frigidaire PLD4375RFC Dishwasher
Frigidaire PLD4375RFC Dishwasher Logo
50 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
