Question about GRACO INC GMAX II 5900 Airless Paint Sprayer Gas powered with gun & hose
How to replace packing on a 5900 graco
Replacing packing how to get ball out
  • 885 Answers
There are two balls in your paint sprayer: One is in the piston and can be removed after you take the piston valve out to get the piston packings off. Be careful of the smooth surfaces of the piston where it contacts the packings. The other is in the intake valve (foot) and held in place by the ball guide or cage. The cage can get stuck because paint gets between it and the foot. DO NOT put something in the back of the foot and try to pound the ball and cage out. The cage is hard steel, read brittle and the tabs on the cage can/will break off. I usually clean out the foot as best I can then use needle nose pliers in the holes in the top of the cage and twist it back and forth until it gets free enough to come out. Clean all surfaces and it'll go in much easier than it came out.
Posted on Jan 23, 2013
My graco GM5000 wont prime or build up pressure replaced transducer but still no pressure
The check valve is a ball valve that gets dirty and rusty over time and sticks usually due to the usage of water based paints and storage with water in the machine and lines. I run mineral spirits through the machine if I am storing the machine for longer than a few weeks. This helps to reduce rust and makes it easier to prime when I use the machine again. If I have the ball valve sticking on my machine I will tap the valve to try and get the ball to loosen but usually I have to disassemble the valve and clean it throughly cause I don't like to tap the valve too much and cause damage to it.
Oct 08, 2016 | GRACO INC 390 Stand Airless Paint Sprayer
I have Graco Gmax 5900 Airless paint sprayer Gas Powered with gun & hose. It is spraying alright but started making a loud kinda of a grinding noise when spraying. Any ideas on what problem may be,...
As I have only just seen your question, maybe you have fixed the problem? If not, this GMax sprayer has an electric clutch to control when it is pumping or not, so there could be 2 sources of the problem: The first is that when the clutch is closed, some part is touching something inside the housing. The other possibility is that one of the bearings has gone dry or a gear has a damaged tooth.
If its not fixed, the drive assembly needs to be opened up and the parts cheked
Jun 01, 2014 | GRACO INC GMAX II 5900 Airless Paint...
Graco x9 won't hold pressure
If it comes up to pressure but won't hold it when the motor stops, you have either damaged packings or a bad check ball-to-seat seal. If it's the check ball(s) not seating properly a real good cleaning should take care of it. If it's the packings the only remedy is to replace them.
Aug 11, 2012 | GRACO INC Magnum Pro X9 Electric Airless...
Graco magnum paint sprayer won't prime
Airless won't prime- I always start trouble shooting an Airless that won't build/hold pressure look at sump hose inlet filter (the hose that goes into the paint if its got paint debris on it clean off filter and pour the paint thru a strainer bag into a clean 5 gal bucket-also remove the filter housing on the spayer and clean and flush and replace filter and housing- the shaft or the metal sleave has two ball bearings called "check balls" that maybe stuck turn on sprayer and put a piece of wood on shaft and give it a few good taps this will knock the check balls loose if after all this fails then you need to have new packings put in becuase the old ones are worn this is pretty easy to see because the rod the compresses the paint will have signs of paint on it indicating that the packings are worn.. Note keep rod and other moving parts oiled ith graco throat seal and finally Graco sprayers with the X on them are there (Graco) home owner line of sprayers that sell at home depot they are rated for only a certain amount of Gal per year keep it in good condition and cleaned store with coro-check inside of the pump when you are done using it.....
May 27, 2012 | GRACO INC 232745 Magnum XR-7 3/4-HP...
I got a graco pack-n-play from a friend. It was never used because the mattress was missing. It was brand new but manufactured in 1998. Graco does not carry replacements that far back. The dimensions are...
I don't think that the dimensions of the pack-n-play have changed since '98. I would see if you can order 'any' mattress from Graco or find one second-hand. There are sheets available for them at WalMart, and other retailers, I'm sure, so that may ease your mind if you're going with one that's second-hand.
Sep 29, 2009 | Baby Gear
Bassinett mattress for Graco Pack n Play
You may be lucky with Mamas and Papas, I know that they do make travel cot mattresses, but am unsure if they will make the size you require. I would suggest that you measure the internal dimensions and contact them,
I hope this helps.
Sep 20, 2009 | Baby Gear
Graco pack n play
I know this question was asked last year, but I thought I'd answer for those having this come up on a Google search. I was missing the Bars that go to the bassinet part of my pack n play, as well as the changing table attachment. I called Graco to order replacement parts. They looked up my Model and Serial number for me. They stated they had the metal bars, but not the changing table attachment. My Pack n play was purchased brand new in 2008. Here is thier number 800-345-4109
Mar 11, 2009 | Baby Gear
NEED A BATTERY PACK FOR A BEARCAT UBC 220 XTL
The battery pack is available at Community Communications in NJ. Phone number is 973-831-5900.
Dec 30, 2008 | Uniden BC248CLT Base Scanner
GRACO INC GMAX II 5900 Airless Paint Sprayer Gas powered with gun & hose Logo
147 people viewed this question
Top GRACO INC Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a GRACO INC Air Tool and Compressor Expert? Answer questions, earn points and help others
