Just bought this unit off ebay prev owner says it it stuck in tx anyone have any ideas
SOURCE: my transceiver yaesu ft-one can't received/monitor and transmit
Thanks 4 your advice.
I left the radio w/o any batteries (the only battery is back up memory battery) in that time, and when I try the radio I used new batteries. The power supply for the radio is build in (uses 30 amperes switching power supply) and I have checked that the power supply is in a good condition. I suspect that PLL unit is not working so can't oscillation to generate frequencies.
The problem with sending the unit to the factory to be serviced is not worth (cost > benefit/ radio value).
Do you have another idea to help me? Please.. Thanks
SOURCE: how to tx and rx between t5920 and yaesu vx6r
The T5920 is user programmable. It appears your VX6R does not have a CODE turned on, if you can receive transmissions from the T5920, but not talke back. The T5920 has both a CODE and a Qt filter. The Qt filter must be set to zero to communicate with other brands of radios. And to turn off your CODE, you will need to set it to zero also. Here is a link to the user manual: http://www.giantintl.com/ContentManage/manuals/Moto/T59xx_User_Manual_E.pdf
