Question about AMD Multimedia Computer with Athlon64 3000+ (2.0GHz)Processor (AMD64256BMDDR80GBHD) Motherboard
Long delays the first time ANYTHING is tried
This is driving me crazy. I have a Windows XP Pro computer where any time you do ANYTHING the first time there is an outrageously long delay for each step. For example: open a program (very long delay) click load (long delay) select a file (long delay) press print (long dealy) select a printer (long delay) press print (long delay) THEN after that all these steps will be quick and normal with little to no noticable delay until the computer is re-booted. I've seen "loading" windows I've never seen before for simple steps that are usually instant. It does not matter what you do... every part of every step has a long delay the first time it's done. I installed a new much faster MB, video, memory and did a repair-install of Windows XP but the problem did not change!! The computer is used only for printing from Corel Draw and not connected to the internet or a network but I have scanned for viruses anyway. Any ideas? I really do not want to re-install Windows from scratch and re-set up all my setting, programs and drivers.
  • Ben Jordan Jul 18, 2007
    I think it is bad HD not a slow HD. I ran a drive integrity test on it last night and it never completed the "quick 90 second test". After 15-20 minutes I shut it off. Before that I thought it was a windows setting or driver problem.
    The delays I was talking about were not 5-15 seconds to load a major program... but for those little things you never have to wait for on an old 486.. like displaying the list of available printers or analyzing a drawing consisting of one small square.
    Definitely a bad drive. No read errors! Just slow as death. I copied everything I needed over to the replacement but it would sometimes take 2-4 minutes to copy 500k. Never seen anything like it.
  • 624 Answers
Your symptoms sound like a slow hard drive. The first time you run Word or some other program the PC has to read the file from the hard drive into memory. You have enough RAM so that the program is still stored there till the next time you run the same program. When you run it again RAM is much faster so you experience the increased speed. This is fairly typical behavior for a PC; in fact one of the big industry discussions right now is how Vista with its huge operating system is really going to strain the limits of traditional hard drives. While Word can take anywhere from 5 to 15 seconds to load on a typical PC Corel Draw is a much larger program and takes considerably longer. Things that could affect your hard drive speed: - It could just be an older hard drive. Generally the smaller the hard drive the older and slower it is. If you hard drive is smaller than 20 GB then an upgrade will boost your speed - Your drive may not be configured to work as efficiently as it could. If you?re using IDE hard drives make sure the channel is running DMA not PIO. - Your drive could be heavily fragmented. I?m generally not a big fan of defragging since the results are seldom worth it. In you case you may get enough of a boost to make a difference. Make sure you have a backup just in case something goes awry. - Drive interface, IDE is the slowest, next is EIDE and the fastest is Serial ATA or SATA which is replacing IDE/EIDE on newer motherboards.
Posted on Jul 18, 2007
  • tomj23 Jul 18, 2007
    I would have expected read error messages from a failing drive. Any way if that is the case I looks like you're in for a re-installation after all. Good luck and let us know if you have any other questions.
I have an ATI Radeon x1600 Pro 512 Mb. I am installing into a computer that I am reformatting and installing windows xp. When I get to the windows install screen it begins to examine the PC hardware...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
don
Feb 12, 2011 | ATI RADEON X1600 Pro 512MB AGP Graphic...
ACDSee 7.0 Device Detector stalls Windows startup
try uninstalling and reinstalling on a diffrent drive.... if youhave one
Mar 04, 2010 | ACDSystems ACD Systems 7.0 Powerpack for...
Error msg
try to format the drive
Feb 25, 2010 | Western Digital Computers & Internet
I had to reload XP Pro, and someone loaded that
Try system restore. To do this go to Start->All programs-> Accessories->System Tools-> System Restore.
Choose a date to restore your computer settings before the change you made.
Jan 20, 2010 | Microsoft Windows XP Professional
Unrecognized partition
You need to unlocked that one
Use partion magic software to partition your drive.You can dowload it for free.
Apr 09, 2009 | Computers & Internet
Hanging on detection of drive when installing Windows XP
Installing Windows XP on a SATA hard drive is not a straight-forward task as Windows XP does not recognize the SATA drive. In order to install operating systems such as Windows XP on SATA drives, the latest SATA drivers are required.Download SATA drivers for the motherboard from the website and integrate them with the XP installation CD using software such as nLite. SATA drivers can also be installed as third party drivers; you will be prompted during the installation process. Without proper SATA drivers, installing Windows XP on a SATA hard drive is not possible as SATA mode would have to be disabled in the BIOS to continue with the installation.
Installing Windows XP on a Serial ATA hard drive is not an easy task, because the system does not recognize SATA drivers at startup. Windows XP Pro SP2 fares a little better with SATA drivers, but here is what can be done in cases where the driver is not recognized.
Mar 31, 2017 | Excelstor Technology J880 Hard Drive
Windows xp home does not boot
Replace the HDD.
You don't want your precious data on that drive.
Nov 08, 2008 | Maxtor Hard Drive
Pioneer dvr unable to read dvds
You might want to try and reinstall Windows XP. I you are using Vista then buy xp pro oem on newegg and install. Windows accumulates junk over time and deteriorates slowly known as the "Windows Half Life Cycle". Basically after a period of time you only get half of what you got when your computer was new.
Sep 07, 2008 | Computers & Internet
After formatting computer hard drive with windows xp pro. came up with bios error and it would not turn on, it keeps flashing
Plese try this simple tips before doing anything.
Just open the motherboar cmos battery and wait until about 5 - 10 minutes before reinsert it again.
br.
Aug 06, 2008 | Computers & Internet
Seagate freedesktop agent 500gb, not detected on windows xp
I am facing the same same problem with my freeagent 750. It work some time, but most of the time it shows u in My Computer, but cannot enter. Couple of time if you run "chkdsk <Drive Letter>:/R" re-scans the entire hard disk and then it shows up. But that too stopped working now :-) Still hanging around for a resolution.
Nov 12, 2007 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
AMD Multimedia Computer with Athlon64 3000+ (2.0GHz)Processor (AMD64256BMDDR80GBHD) Motherboard Logo
78 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Computer Links
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
