Question about GE SpaceMaker Microwave Ovens
Microwave oven turns on when door is opened - SpaceMaker GE Microwave Ovens
  • GE Master
  • 17,130 Answers
Fault with the control board or the door switch.
Posted on Jan 22, 2013
MicrowaveSvc
  • 9098 Answers
SOURCE: the door sticks on my microwave oven
Usually this is due to loosened mounts inside the oven. The mounts hold the door switches and grab the door hooks when it the door is closed. The solution is to realign and tighten the mount screws inside. It's less liekly, but it could be a weak or worn door open lever inside. I only advise people to work on a microwave if they're fully informed and aware of the deadly hazards and necessary precautions.
Posted on Sep 15, 2006
MicrowaveSvc
  • 9098 Answers
SOURCE: turns on with door open
It's likely that it's only the fan and light coming on when the door is open. But even so, it's not normal, and it should be fixed. It's not a reset issue. It's likely a broken door switch mount caused by a door slam or by inferior material, or a defective door switch caused by opening the door while the oven is cooking instead of hitting the "STOP" key first. You can do a Google search for my text file "doorsw.txt" which will give safety info and help in checking the door switches. Also, the plastic pieces on which the door switches are mounted should be checked, as well as the door alignment. It's usually the upper door switch or mount that causes this, but occasioanlly it's a problem on the control circuit board. Post again if more help is needed.
Posted on Oct 25, 2006
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave Oven Problem
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. It's probably not actually heating with the door open, but better safe than sorry! If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383
Posted on Apr 10, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave oven runs with door open
This is usually caused by either a bad door switch, a loose door switch mount.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Apr 18, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave oven comes on when
It sounds like either a bad door switch or door switch mount, or a sticking relay on the control panel.
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can order Panasonic parts here.
Otherwise, I would recommend that you contact your nearest Panasonic-authorized servicer.
Posted on Aug 19, 2008
Turns on when door opened
There is an power interlock inside the oven that breaks the power connection to the magnetron when the door is open. Most likely, something is stopping the switch from opening.
Check for a small plastic probe on the door that may have broken off inside the oven keeping the circuit made. Otherwise, open the oven and see is some foreign object is keeping the connection made or if the interlock needs to be cleaned out so it can function.
Jul 11, 2015 | Samsung SMH1816S 1.8 Cu Ft Over The Range...
Why does my Kenmore model 721.63352300 turn on when door is opened ?
The most likely cause is a defective door switch, there are usually a few to protect critical area's of the microwave oven, if you have a digital meter I can walk you through the testing stage.
Sep 02, 2012 | Kenmore 63252 Microwave Oven
Timer changing but microwave is not turning on?
Hello :
It's a bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly .
WARNING : A microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. I strongly recommend you seek the assistance of an appliance repair technician when conducting any microwave oven repair .
good luck .
please rate !
Mar 30, 2010 | Magic Chef MCD1311ST Microwave Oven
Everything works on my microwave oven but it doesn't heat the food
Check the door safety interlock switches ...
Remove the cover and find the switches opposite the hinges. Check with a contunity meter.
If you open the door while the oven is cooking these switches arc. Enough arcing and they burn. When they are burned, they cannot tell the oven that the door is closed. When the oven thinks the door is open, it will not turn on the heat.
Oct 09, 2009 | Whirlpool GH4155XP Microwave Oven
this is dangerous; replace or adjust your door switches the interlock switches should only allow you to turn on the microwave when the door is closed
May 29, 2009 | Jenn-Air JMC8100 Microwave Oven
My Microwave flickers and buzzes
This problem normaly happens when the door is not closed properly for a long time and flashing and buzzing starts to give user a indication for same. Allthough it is not risky as microwave oven has safty door switches wich does not allow oven to operate while door is open. Take care and close the door properly before you leave kitchen..
Aug 02, 2007 | Kenmore 66469 / 66462 / 66464 Microwave...
Microwave Ovens Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
