Question about Pelonis Heating & Cooling
Pelonis heater beeps too loud
Whenever pushing any buttons on heater it makes a loud beep
3 Suggested Answers
  • 3248 Answers
SOURCE: when my Pelonis Fan Force Heater , Fan start
Hi i would start with that first and see if it stops
Posted on Mar 04, 2010
SOURCE: Lasko heater beeps too LOUD
I was cleaning out my Lasko ceramic heater 6000, looking for instructions on how to do so, and came across your comment. After I opened it up and cleaned everything out (really easy, no instructions needed, it is all obvious) I started thinking about how much I hate that beep as well. So I decided as long as I had it opened to try to disable it.
Well, I could tell from plugging and unplugging that it was (unfortunately) mounted on the under side of the green circuit board. You will have to unscrew the circuit board completely (all wires still attached) and (carefully!) move it so you can flip it upside down to get to the other side. Note: there were 7 screws to remove and 1 was under the motor and really hard to get to. The motor looked WAY too complicated to remove so I got the screw started just a little with a precision screw driver and turned it the rest of the way with needle nose pliers.
Once the circuit board is off, the beeper is a little black circular thing (about 1/2 inch in diameter) with a little hole in the middle. It has a serial number on it and a "+" symbol. It looks like it is built in two pieces (upper and lower), so I tried to carefully remove the upper piece with needle nose pliers while leaving the lower piece connected to the circuit board. Well, the whole thing ripped out! I thought two things: 1) It will never beep again, and 2) I hope this didn't break a circuit causing the whole thing to fail.
Well, I put the circuit board back on ( I left off the one difficult screw, as 6 of 7 is more than sufficient to hold it on). Put the whole unit back together, and . . . . IT WORKS FINE!!!!!
Posted on Dec 10, 2010
Radio beeps after you release push to talk
Might be a low battery warning. Try swapping battery.
Mar 20, 2014 | Motorola CLS 1410 (4 Channels) 2-Way Radio
Pressing the CAPS LOCK or NUM LOCK there is a beep.
launch the Toggle Keys dialog box by holding down the Num Lock button for five seconds, and clicking Yes. Thereafter, a loud beep will sound through your computer's speakers whenever Caps Lock is turned on or off. (To turn Toggle Keys off, once again hold down your Num Lock button for five seconds.)
Nov 11, 2013 | Toshiba Satellite Computers & Internet
Frigidaire microwave has annoying beep, can it be turned off? model no. FFMV162LQA
Hold the 2 button and Stop button at the same time. To restore hold 2 button and Start button at the same time for 30 seconds.
Aug 19, 2012 | Kenmore 80809 Microwave Oven
My Dell Latitude D620 will randomly give off a beep sound when powered on
those windows sounds are adjustable
start
control panel
sounds icon
look for windows sound settings find the one that says beep and disable it
May 25, 2012 | Dell Computers & Internet
Beeping sound coming from control panel model#10656562400
Hi!
Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise, just open the freezer door and push any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause which can't be lubricated or repair instead required to be replaced.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 01, 2009 | Kenmore 56562 / 56564 / 565 / 6656569 Side...
Emerson Microwave oven and grill MWG9111SL
teashas_tasty_treats@yahooo.com
i have the same problem too! please help if you can.
Oct 25, 2008 | Microwave Ovens
Heating & Cooling Logo
177 people viewed this question
Top Pelonis Heating & Cooling Experts
Paul Carew
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Pelonis Heating and Cooling Expert? Answer questions, earn points and help others
