Question about Maytag Atlantis MDG7400AW Gas Dryer
Maytag atlantis gas dryer not heating up
Dryer does not heat up. I have taken vent out and screen out and cleaned out all lint and still no heat.
  • Kelea Fields Jan 21, 2013
    Does anyone know the part number of the coils for this dryer? I can't seem to figure it out..
    Sergeant:
    Champion:
  • 249 Answers
I thank you need a new Heating Element Assembly part # Y308612 here is a image of the Heating Element Assembly
Posted on Jan 21, 2013
  • 22 Answers
SOURCE: MAYTAG ATLANTIS GAS DRYER # MDG7600 aww
sounds like you need an igniter
Posted on Aug 22, 2008
SOURCE: Maytag Atlantis dryer no heat
The heating element and thermostat are located behind the front panel of the dryer. you will need to remove the door, then the retaining screws. the heater / element is located on the left side as you are facing the front of the dryer and has to sheet meta screws (upper back top / and front bottom) which will need to be removed. the unit has several colored wires for the thermostat and switch. remove these (remember which goes where) and the enitre unit will come out easily.
Posted on Jan 08, 2009
SOURCE: Maytag dryer does not maintain heat and clothes smell
Save yourself the repair call and replace the gas coils. They're a $30 part and it takes all of five minutes. Works like a charm.
Posted on Oct 08, 2008
Washer_tech
  • 164 Answers
SOURCE: I HAVE A MAYTAG ATLANTIS GAS DRYER STOPS HEATING ABOUT 5 MINUTES IN
the flame going out is normal. the heat cycles on and off as called for by the thermostat. If the heat doesn't come back on i would start by changing the gas coils.
Posted on Nov 04, 2008
Healeyman
  • 1198 Answers
SOURCE: maytag atlantis gas dryer, will start, heat up but then no heat
Try running it with the vent disconnected and feel the air coming out of the dryer. It should have good flow. If it dries good, your pipe may be clogged.
Posted on Apr 28, 2009
I have a Maytag gas dryer MDG7658AWW. It heats but timer won't advance in any setting. I have taken the screws out of the moisture sensor and cleaned it both front and back and removed any lint from...
You either have an issue with your cycling thermostat, or the gas valve solenoids. I could get into a very lengthy explanation as to what to do to diagnose, but for what these two items will probably cost you to buy, I would change both.
Oct 15, 2013 | Maytag Atlantis MDG7400AW Gas Dryer
MDG850 Gas Dryer: will not get hot
Well if your dryer tumbles, but there is no heat then you may please check out the following -
1. First of all you can check out for proper air flow - Check the vent for proper air flow by placing your hand over the exterior vent while the dryer is running. You should feel a strong flow of air. If not then check the lint trap. It is located either on top of the dryer or possibly just inside the door. Remove any lint that has built up in the lint trap. Cleaning the lint trap should be done regularly, even as often as after every load. Do not operate the dryer without a lint trap in place.
2. Secondly you can check out the Ignitor - gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes.
Post comments for further help or information.....
Good Luck!!
Thanks for using FixYa!!
Sep 09, 2010 | Maytag Atlantis MDG8400AW Gas Dryer
Dryer will start to heat but will stop heating after a while but will tumble. Why would it stop heating?
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Aug 17, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer produces heat, but clothes don't dry
Sounds like the vent has a lint build up inside of it. A moister sensor detects any lint build up and keeps the heat in check. The dryer will produce very little heat this was. Clean the entire venting tubing and it shall run better for you
Jul 08, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Tumbler turns, but no heat. gas line is open and looks good... what might be the problem?
Upon starting the dryer you should hear the clicking noise of the spark ignitor. If heard that is fine. Next remove all exhaust vent tubing and clean out thoroughly. The moister sensor detects any lint build up and will put the heat burner into a check mode untill the lint build up is removed. It was designed to prevent fires to start. If cleaned and still does not produce any heat replace that moister sensor
Jun 19, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
GE Dryer has gas smell inside.
i would not play with this problem , the lines and the seals in the dryer must be checked .. by a proffesional ... hope u dont get a spark , get this checked imediatley
Sep 26, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis gas dryer, will start, heat up but then no heat
Mar 29, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag gas dryer doesn't dry properly
SOUNDS LIKE A RESTRICTION IN THE VENT. CHECK AIR FLOW WHERE VENT EXITS HOUSE. IF IT IS NOT STRONG, INSPECT VENT LINE BEHIND DRYER. IS IT CRUSHED OR CLOGGED WITH LINT? THIS WILL CAUSE DRYER TO SHORT CYCLE. IF VENT IS NOT CLOGGED, CHECK AIR FLOW AT BACK OF DRYER WITH VENT DISCONNECTED. IS AIR FLOW STRONG? OF NOT, PROBLEM IS WITH BLOWER.
Jan 27, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Oct 08, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Atlantis MDG7600AWW Not Heating
the gas coils have a problem. as the dryer heats p the coils on the gas valve are failing causing the dryer not to heat. replace the coils and you should have no problem
Oct 22, 2007 | Dryers
Maytag Atlantis MDG7400AW Gas Dryer Logo
820 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
