Question about Car Audio & Video
I have a alpine IVE-w535hd DVD sound is playing but no picture. I have ground out park brake wire still no pic. Anyone help me out ? Trying to get pic while driving for my kids.
simplemitch
  • 752 Answers
SOURCE: Parking Brake wire on Jensen VM9311TS
It may need to see a Positive....not a ground (the brake wire rests at ground and goes positive when the pedal is pressed). but to answer your question, the brake wire for your car is Light Green and is at the brake switch above the pedal.
Posted on Sep 20, 2007
SOURCE: blue screen will not go away
These methods have worked on a variety of Dual DVD systems (mainly XDVD8181, also XDVD710), unsuprisingly, since Dual stated to me that most installations have the same codes. WARNING! It is usually ILLEGAL and most of all UNSAFE to drive while watching video. I only watch video while parked, and I suggest you do the same. This is for demonstration purposes only, if you use these codes, you do so at your own risk. STEP ONE. Ground the E-Brake wire. No matter which method you use, you must ground the brake detection wire. I suggest you tap it into the ground wire on your wiring harness (ensures a good ground). 1. FACTORY RESET METHOD (Temporary) (This isn't the most effective, but it is the easiest to try, so it's worth a shot since it apparently works on some units.) ** Go to the Menu ** Get to the Settings Menu ** Select to Reset to Factory Settings. Credit: DKA Have recently heard complaints of this method not being permanent, as this is needed everytime they want to watch a DVD. Also, radio and screen angle presets are lost. ---------------- 2. AUDIO CD METHOD (Permanent) ** Insert Audio CD ** Press PLAY ** Press STOP twice on remote ** Enter 26604 on remote ** Press ENTER ** Take out Audio CD and Insert a DVD Credit: Myself via a DUAL Tech ---------------- 3. DVD METHOD (Permanent) ** Insert a DVD ** Let it play until you hear sound ** Press STOP twice on remote ** Enter 26604 ** Press ENTER Credit: Adam P. The blue warning screen should immediately go away after pressing the last digit of "26604." Still press ENTER as a precaution.
Posted on Oct 01, 2007
  • 3 Answers
SOURCE: Dvd won`t work correctly
http://forum.ecoustics.com/bbs/messages/4/278797.html
Posted on Nov 15, 2007
SOURCE: jvc exad model kd-avx2
You'll have to connect the wire "parking brake" at the back of the JVC to your ground wire (black)!
Posted on Oct 30, 2008
dj x
  • 61 Answers
SOURCE: watch a dvd while driving pioneer AVH-P4000 DVD
Hi Dave
No ....go to a hardware store buy a toggle switch than get a single speaker wire (small wire) attach it to the red wire on the back of your pioneer deck (make sure to leave the red wire in back of deck as well) and attach it to the power on the toggle switch do the same with the black wire (ground wire) the black wire will go into the toggle switch under the power wire. finally install the parking break wire from the pioneer unit to the last slot on toggle switch and this should do the trick if not swap the ground spot for the brake spot on toggle switch >>>> MAKE SURE THE TOGGEL SWITCH HAS 3 HOOK UPS to do this correctly (your system will provide sound with the toggle switch off (Blue Screen) but when toggle switch is on you get video while driving) good luck
Posted on Mar 04, 2009
IVE-W535HD
i have the same issue. if i find out later today ill respond back on here. calling best buy "geek squad"
Feb 24, 2013 | Alpine IVE-W535HD - 6.1" In-Dash Video...
How to install my Alpine in my 2001 525I BMW also how to by-pass the wires that allow the DVD to work without the e-brake on.
to install it you need to buy a dash kit for your car from walmart or amazon.com then you buy for your model and car the wire adapter kit. plain and simple from there. colored wires connected together easy as plug and play. to by pass the e-brake you need to buy a relay.
here is something i wrote up awhile ago for a buddy to bypass his after he took pictures of his model back.
On the back on the unit there should be an additional wire labeled as the "Parking Brake" or something to that effect. Law implies that this should be spliced into the Parking Brake wire (which is essentially a constant hot which becomes a ground when engaged). So the obvious thing here is to simply ground the Parking Brake wire on the back of the radio. This can be done just splicing it into the black wire on the radio harness.
found another solution from ehow for you
http://www.ehow.com/how_4482151_ebrake-screen-dash-dvd-player.html
let me know if this helps
Mar 20, 2011 | Alpine INA-W900BT Car Video Player
IVA-D106 Car DVD Player: no picture on screen while dvd is playing...
Im guessing that if you can hear sound but have no picture and this is newly installed that your unit is wired to your parking brake as a safety feature. You need to disconnect it and connect the wire to the radio ground to bypass it.
May 18, 2010 | Alpine IVA-D106 Car DVD Player
What color wire do i hook the pink wire to
Pink wire is generally the parking brake safety. If you dont want the dvd player to play video while in drive wire it to the ground on your parking brake sensor wire. If you do want it to play video while your driving, wire it directly back to the ground wire on your stereo.
May 15, 2010 | Alpine IVA-D300 Car DVD Player
Dvd plays but it turn blue whit no pic
Yes, your parking brake safety wire has been run the correct way, so it will only play when you are in park. If that is the case, you must disconnect the pink parking brake wire from the parking brake ground, and connect it to the radio units main ground wire. This will tell it that it is always in park. Caution, they put the wire there for a reason, very distracting to have a movie playing in the front seat.
May 17, 2010 | Dual XDVD8180 Car Video Player
Need help bypassin parkin brake wire
you need to hook up the foot brake like it said but hook up a switch on the parking brake wire to ground do not hook it up to parking brake just a switch ground one side ant togle it while your foot is on the brake once the screen is on leave the switch in that position you will have to do this every time you turn the car off but you can see the screen while driving
Mar 21, 2009 | Alpine CVA-1004 Car DVD Player
Dvd player not working
you just need to hook up the foot brake wire (yellow and black) and hook up the parking brake wire (yellow and blue (looks green) ) set the parking brake then press and release the foot brake and your dvd picture will play
Mar 12, 2009 | Alpine IVA-D300 Car DVD Player
Parking brake
Parking Brake Lead (Yellow/Blue) Connect this lead to the power supply side of the parking brake switch to transmit the parking brake status signals to the IVA-D310.
Mar 04, 2008 | Alpine IVA-D310 Car DVD Player
How do i bypass the parking brake switch in order for my video to play
you need 2 toggle switches . yello/blue wire to switch - switch to ground.
yellow/black wire to switch- switch to red ing. wire. turn this switch on and pulse the other(yellow,blue) 3 times and leave on, then turn the other switch off and then you can ride and watch dvd. just did it this morn. QTRHRS
Feb 24, 2008 | Alpine IVA-D310 Car DVD Player
Parking brake
ground the pink wire that will allow player to play video
Feb 04, 2008 | Car Audio & Video
Car Audio & Video Logo
277 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
