Question about Denon AVR-2805
Att u-verse remote wont control volume - Denon AVR-2805
How do I program an AT&T u-verse remote to an ONKYO RC-866M remote
The RC-866M is the remote. What you need to do is add the codes for your Onkyo receiver into the ATT remote. There are 4 or 5 different Uverse remotes, but most can be reprogrammed by pressing the 'Menu' and 'OK' button together. First add your Onkyo codes to the ATT remote as an 'aux' device. After that is working, you can control the power and volume by adding the 'aux' device (Onkyo) to the power and volume buttons on the uverse remote.
These are all the different Onkyo Receiver codes:
Onkyo: 5002, 5018, 5073, 5074, 5075, 5076, 5077, 5078, 5079, 5080, 5081, 5082, 5084, 5085, 5086, 5087, 5130, 5131, 5140
This is how to reprogram the S10 style of Uverse remote:
http://www.att.com/support_media/images/pdf/uverse/standard_black_remote_control_uverse.pdf
Dec 22, 2014 | Onkyo Audio Players & Recorders
What codes do I use on the urc 9910 for att u-verse?
I don't think att u-verse existed when the 9910 were made so there probably isn't a code in the remote. And as far as I can tell the upgrade program for codes for new products is dead, dead, dead.
The only option I know is to use the JP1 connector under the battery door to program a new code. I just added several links to information on this to the tips & how to's section for this. If you are good with computers check them out. Scrool to the bottom of the link to find them. Good luck! Troubleshooting Support for One For All URC 9910 LCD Remote Control
Jul 07, 2014 | One For All URC-9910 LCD Remote Control
I need the Device code for the Maxell SSB-1 Soundbar to control the volume with my ATT U-Verse remote.
048,041,044 are the codes to check. If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
Oct 13, 2013 | Maxell 193002 ssb1 soundbar
Att uverse remote control code
You have this backwards. What you are seeking is the ATT remote code for your Panasonic projector. The codes are generated by the remote
Jun 25, 2013 | Panasonic Office Equipment & Supplies
Yamaha yas-101 uverse codes
I had the same problem with my U-verse s10-10 remote and a yamaha SR 300 soundbar. Here is how I got my volume control (but NOT power control) on the yamaha working:
First - always send volume control to the AUX button:
Press and hold AT&T key and OK for 1 second, release, look for 2 flashes.
Now press AUX button. The AUX button will show a long flash.
Second - Go through the manual programing steps listed in the guide for the AUX button (hold AUX and OK for 1 second, release; 2 flashes, punch in code). But instead of pressing the Power button to try to turn off your yamaha soundbar, press the volume up / down and Mute button. I think the code that worked for me was 4045 but I honestly don't remember.
The key is that you have to send the volume control to the AUX button first or it's all a wash.
Jun 26, 2012 | Yamaha YAS-101 Front Surround Sound Bar...
Emerson tv and at&t uverse
Try code 1465. On my Emerson LCD TV the only thing it won't do is turn the TV on -- all other functions are controlled by the AT&T U-Verse remote however.
Jan 21, 2009 | Emerson EWF2704 TV
Need Remote Code for LG LFD790 Home Theater
I NEED REMOTE CODE FOR LG LFD 790 FROM REMOTE GE
Dec 30, 2008 | LG LFD790 System
I have ATT U-Verse and the LG LFD790 Home Theater System. I can program the U-Verse remote to turn the LG on/off, but can not control volume from U-Verse remote. Do you have any codes I can try?
well you have the right code, but you have to get the volume options so you can control it. Hold down at&t and the ok button, then let them go. put in code 955 then press enter(bottom right) now you should be able to select whatever device and control that volume source
Need remote control code for ATT U-verse
Use the code search method. MANY TV's are branded from a few suppliers. Emerson has about 50 codes!
Mar 02, 2008 | Durabrand DWT1304 13" TV
Denon AVR-2805 Logo
69 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
