Question about Jeep 1998 Grand Cherokee Laredo
I cant remove the ignition switch thats missing key from the key cylinder
    Top Expert:
  • Jeep Master
  • 74,199 Answers
Check this link for details.
Posted on Jan 21, 2013
I replaced my ignition cylinder lock and switch in my 1993 Jeep Grand Cherokee limited 5.2 Liter V-8 and when I reassembled it and started it my power windows and V.I.C. don't work? Help please
replaced my ignition cylinder Anon, Check your fuses, also after changing ignition, google search if you have to do a relearn procedure.
Mar 31, 2016 | Jeep Cars & Trucks
Trying to get the ignition tumbler unit out of a 1993 Ford Taurus at the junkyard. worked at it most of two days but no luck yet so I must be missing something having never tried this before.
Ignition Lock Cylinder REMOVAL & INSTALLATION Functional Lock The following procedure applies to vehicles that have functional lock cylinders. Such cylinders either have a key available or known key numbers from which a key can be made.
  1. Disconnect the negative battery cable.
  2. Turn the lock cylinder key to the RUN position.
  3. Using a 1?8 in. (3mm) diameter wire pin or a small drift, depress the lock cylinder retaining pin through the access hole in the upper steering column shroud (under the ignition lock cylinder) while pulling out on the lock cylinder. Remove the lock cylinder from the column. Fig. 1: Using the key, turn the ignition lock cylinder to the RUN position, then depress the retaining pin using a wire pin or small drift 86878085.gif
    To install:
  4. Install the lock cylinder by turning it to the RUN position and depressing the retaining pin. Insert the lock cylinder into its housing. Make sure the cylinder is fully seated and aligned in the interlocking washer before turning the key to the OFF position. This will permit the cylinder retaining pin to extend into the cylinder housing.
  5. Rotate the lock cylinder using the lock cylinder key, to ensure correct mechanical operation in all positions.
  6. Connect the negative battery cable.
Non-Functional Lock The following procedure applies to vehicles in which the ignition lock is inoperative and the lock cylinder cannot be rotated due to a lost or broken key, unknown key number or a lock cylinder cap that has been damaged and/or broken to the extent that the lock cylinder cannot be rotated. 1986-90 VEHICLES
  2. Remove the steering wheel. For details, please refer to the procedure located earlier in this section.
  3. Remove the two trim shroud halves after removing the three attaching screws.
  4. Disengage the electrical connector from the key warning switch.
  5. Using a 1?8 in. (3mm) diameter drill, carefully drill out the retaining pin, being careful not to drill deeper than 1?2 in. (13mm).
  6. Place a suitable chisel at the base of the ignition lock cylinder cap, then, using a suitable hammer, strike the chisel with sharp blows to break the cap away from the lock cylinder.
  7. Using a 3?8 in. (10mm) diameter drill, carefully drill down the middle of the ignition key slot approximately 1 3?4 in. (44mm) until the lock cylinder breaks loose from its breakaway base. Remove the lock cylinder and drill shavings from the lock cylinder housing.
  8. Remove the retainer, washer, ignition switch and actuator. Thoroughly clean all the drill shavings from the casting.
  9. Inspect the lock cylinder housing for damage from the removal operation. To install:
  10. Replace the lock cylinder housing if it was damaged.
  11. Install the actuator and ignition switch.
  12. Install the trim and electrical parts.
  13. Install a new ignition lock cylinder.
  14. Install the steering wheel. For details, please refer to the procedure located earlier in this section.
  15. Connect the negative battery cable.
  16. Check the lock cylinder operation.
1991-95 VEHICLES
  3. Using locking pliers, twist the cylinder cap until it separates from the lock cylinder.
  4. Using a 3?8 in. (10mm) diameter drill bit, drill down the middle of the ignition lock key slot approximately 1 3?4 in. (44mm) until the lock cylinder releases from its breakaway base. Remove the lock cylinder and drill shavings from the lock cylinder housing.
  5. Remove the retainer, washer, ignition switch and actuator. Thoroughly clean all drill shavings and other foreign materials from the casting.
  6. Inspect the lock cylinder housing for damage from the removal operation. If the housing is damaged, it must be replaced. To install:
  7. Replace the lock cylinder housing, if damaged.
  8. Install the actuator and ignition switch.
  9. Install the trim and electrical parts.
  10. Install the ignition lock cylinder.
  11. Install the steering wheel.
  12. Connect the negative battery cable, then check the lock cylinder operation.
Nov 05, 2010 | 1993 Ford Taurus
Ignition
the actuator inside the sterring column that the lock cylinder turns is boken, this is a very complex job and is not for the home tech without a factory service manual.
Apr 21, 2010 | 1996 Ford Taurus
I have 1999 lexus ls470 -- same problem -- ignition switch
Its usually NOT the lock cylinder on the 470s, its usually the housing. The cylinder is on the dash and points towards the engine. Behind the plastic dash panel (once removed) you will see it in fact sticks in an aluminum tube that goes down 2 or 3 inches, then makes 2 turns, left to attatch to the steering column, and right to attatch to the actual ignition switch. The gear and rod assembly that the cylinder attatches to that allows it to rotate the switch usually shatters in the middle and the key starts freewheeling because there is no longer any attatchment to any of the gears or springs or click points that youd usually feel as the rotational resistance. UNFORTUNATELY this is not a 5 minute job (If it was, cars would be a breeze to steal!). Youll need at least a lock cylinder housing (dealer stock em, they break all the tyme), and IF your cylinder is undamaged, change the housing (it bolts to the steering column and extends from column towards center console area where the ignition SWITCH is actually located). If your cylinder is damaged or the housing is so shredded you cant remove the lock cylinder by normal means...then youll also need the cylinder...and it will have to be recoded to the vehicle so the anti theft will allow the new keys/cylinder to start the car. If your old cylinder and keys are intact, then transfer them to the new housing and car wont even know it happened and should start up and work as normal. Some can be removed intact, some cant...depends on how yours broke.
Aug 24, 2009 | 2000 Lexus LX470
96 ford windstar ignition probs
the ignition switch is the electrical part behind the lock cylinder where the key goes in.
Ignition Switch Lock Cylinder
Lock Cylinder Functional
Removal
  1. The following procedure applies to vehicles that have a functional ignition switch lock cylinder (11582) and keys. If the key numbers are known, the correct key can be made. Disconnect the battery ground cable (14301). For additional information, refer to Section 14-01 .
  1. Turn the ignition switch lock cylinder to the RUN position.
  1. Place a 3.17-mm (1/8-inch) diameter wire pin or small drift punch in the hole in the steering column shroud under the ignition switch lock cylinder. Depress the retaining pin while pulling out on the ignition switch lock cylinder to remove it from the housing of the steering column.
Installation
  1. Install the ignition switch lock cylinder by turning it to the RUN position and depressing the retaining pin. Insert the ignition switch lock cylinder into the steering column housing. Make sure the ignition switch lock cylinder is fully seated and aligned in the interlocking washer before turning the key to the OFF position. This will permit the retaining pin of the ignition switch lock cylinder to extend into the hole of the steering column.
  1. Using the key, rotate the ignition switch lock cylinder to make sure of correct mechanical operation in all positions.
  1. Connect the battery ground cable.
Ignition Switch Removal
  1. Disconnect battery ground cable (14301). Refer to Section 14-01 .
  1. Remove the upper steering column shroud (3530) by removing the four or five self-tapping screws. Remove key release lever (3F527) (if equipped).
  1. Remove lower steering column shroud.
  1. Disconnect the ignition switch electrical connector.
  1. Rotate ignition switch lock cylinder (11582) to the RUN position.
  1. Remove the two screws retaining ignition switch (11572).
  1. Disengage the ignition switch from the actuator.
Item Part Number Description 1 11572 Ignition Switch 2 — Ignition Switch Lock Cylinder Housing 3 — Slot in Lock/Column Assembly A — (Part of 11572) Pin B — Alignment Mark
Installation
NOTE: A new replacement ignition switch assembly will be set in the RUN position as received.
  1. Adjust the ignition switch by sliding the carrier to the ignition switch RUN position.
  1. Check to make sure that the ignition switch lock cylinder is in the RUN position. The RUN position is achieved by rotating the ignition switch lock cylinder approximately 90 degrees from the LOCK position.
  1. Install the ignition switch into the actuator. It may be necessary to move the ignition switch slightly back and forth to align the ignition switch mounting holes with the lock cylinder housing threaded holes.
  1. Install retaining screws. Tighten to 5.6-7.9 Nm (50-69 lb-in).
  1. Connect electrical connector to ignition switch.
  1. Connect battery ground cable. Refer to Section 14-01 .
  1. Check ignition switch for proper function, including START and ACC positions. Also, make certain that the column is in the LOCK position.
  1. Install upper steering column shroud.
  1. Install the lower steering column shroud and key release lever (if equipped).
Feb 27, 2009 | 1996 Ford Windstar
Car was stolen broke the ignition
REMOVAL
  1. On models equipped with airbag, disarm airbag as described under MAINTENANCE PROCEDURES/AIRBAG SYSTEM DISARMING.
  2. On all models, disconnect battery ground cable.
  3. Remove ignition switch as described under STARTING AND CHARGING SYSTEMS/COMPONENT REPLACEMENT AND REPAIR PROCEDURES/IGNITION SWITCH.
  4. Remove key light case from lock body, if equipped.
  5. On 1989 Accord models, place ignition lock cylinder in the ACC position.
  6. On except 1989 Accord, place ignition lock in the I position.
  7. On all models, position suitable punch into hole on lock cylinder housing and depress pin, then remove lock cylinder from housing.
INSTALLATION
  1. On 1989 Accord models, install ignition lock cylinder as follows:
    1. Place ignition lock cylinder in the LOCK position.
    2. Rotate key until it is almost at the ACC position, then insert lock cylinder until pin contacts housing.
    3. Rotate key to ACC position, then push pin in and insert lock cylinder into housing until pin clicks into place.
  1. On except 1989 Accord, install ignition lock cylinder as follows:
    1. Place ignition lock cylinder in the O position.
    2. Rotate key until it is almost at the I position, then insert lock cylinder until pin contacts housing.
    3. Rotate key to I position, then push pin in and insert lock cylinder into housing until pin clicks into place.
  1. Install ignition switch and connect battery ground cable.
SRS wire harness is routed near the ignition switch.
CAUTION:
  • All SRS electrical wiring harnesses are covered with yellow outer insulation.
  • Before disconnecting the SRS wire harness, install the short connector on the airbag.
  • Replace the entire affected SRS harness assembly if it has an open circuit or damaged wiring.
IGNITION SWITCH
  1. Remove the steering wheel, then remove the steering column covers.
  2. Disconnect the 7-P connector from the under-dash fuse box.
  3. Insert the key and turn it to "0."
  4. Remove the 2 screws and replace the base of the switch.
Feb 13, 2009 | 1992 Honda Accord
Diagram on a pontiac grand prix
I have 07 Pontiac Grand Prix, the wrong key was inserted into the ignition the other day. Now when I try to use the correct key it will not insert completly in the ignition, goes in until last 1/4in of key. Im stuck, I bought the new lock cylinder but how do I get the old one out? I cant get the key to insert all the way so I cant get it to the "On" position, it will not turn at all. The key that was inserted in error is whole and nothing is missing it seems like there is something stuck. Any help would be appreciated...
Sep 09, 2008 | 2000 Pontiac Grand Prix
Jeep 1998 Grand Cherokee Laredo Logo
Top Jeep Toys Experts
Glenn Smart
Glenn Smart
 Brian Main
Brian Main
Are you a Jeep Toy Expert? Answer questions, earn points and help others
