Question about Schwinn 420 Elliptical Trainer
Resistance does not increase
I can increase the settings on the display but it does not change the physical tension.
    Top Expert:
  • Schwinn Master
  • 12,223 Answers
Please read the instruction and fix it. God bless you
Check your owner's manual for diagrams and definitions. You'll need this information when you put the elliptical back together. You'll also want definitions in case you need to call the customer support line for assistance.
Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced.Test with the magnet from a refrigerator, If the magnet attract and repulse, is o.k If not replace the magnet.Resistance does not increase - 1_21_2013_5_29_53_pm.gif
Posted on Jan 21, 2013
Needle breaking
unthread machine, lower presser foot rethread machine. turn tension to "0" should have only slight resistance on thread. increase tension and resistance should proportionally increase.
Mar 02, 2014 | Bernina 1008
Tip
Increase Physical memory of the system. Increasing Physical memory will increase...
Increasing Physical memory will increase the performance of the system.
1. Right click My Computer - Select Properties.
2. In property window Click on Advance tab --- Performance -- Settings.
3. In Performance Options window -----> Virtual Memory option Click Change button.
4. In Virtual memory window --- Select C drive --- Click on custom Size.
5. Change initial size to 2000MB & Maximum size to 4000MB -- Click on Set button.
6. Click OK and close all window. Restart system.
Regards
Achalesh Prem P
Vote for me
on Mar 05, 2010 | Computers & Internet
576i resistance not increasing precor
If the display stays at 1, then the UP button may be at fault, in which case you would need a new keypad.
Jan 02, 2014 | Precor EFX 546i Elliptical Version 4
Resistance
This could be caused by either a bad lower electronic board or the brake/generator. I am attaching a link to the service manual for you for further reference. http://www.sportsmith.net/images/product_support/precor/Service%20Manuals/Commercial%20EFX/Service%20Manual,%20C546i%20Self%20Powered%20EFX.pdf
Jun 27, 2013 | Precor EFX 546i Elliptical Version 4
Top stitch looks great, under stitch bunches. I have rethreaded, rebobbined, changed tension. same result. :(
Bunching of thread is 99% a top tension problem. Make sure you thread the top thread correctly. Thread the machine with the presser lever up. Test the tension by lowering the presser lever before threading the eye of the needle, by pulling the thread with your left hand and adjusting the tension with your right hand while slowly pulling downwards. There should be no resistance when the tension dial is on zero, and you should be able to feel more resistance when you increase the tension. Ideal tension is between 3 and 5. When your top tension is correct, your machine should operate correctly. If you feel no resistance with the presser foot down and the tension dial on 5, check the tension disks for fluff or broken thread. When you lift the presser foot, the tension disks should open and you would be able to remove any cotton or fluff. Good Luck
Aug 30, 2011 | Singer 4423 Sewing Machine
Weider Crossbow Platinum The weight resistance needs calibration 20 lbs feels like 100 lbs. How can I fix this?
ADJUSTING THE RESISTANCE When the resistance setting changes, the motor will be heard. To prevent damage to the motor, do not pull any of the cables while the resistance setting is changing. If a cable is pulled, the words RELEASE HANDLES AND READJUST RESISTANCE AS DESIRED may appear in the main display on the console.If this message is displayed repeatedly but no cable is being pulled, there may be too much tension on the Upper Cable . Adjust the tension as described below. To decrease the tension on the Upper Cable.turn the two 3/8” x 38mm Tension Screws twice,counterclockwise. Select the desired resistance setting.Repeat this step if necessary.CLEANING THE BAR GUIDES Over time, dust may build up on the Crossbar Guides , causing a squeaking noise as the resistance system is used. If this occurs, wipe off the Crossbar Guides with a damp cloth and a mild, non-abrasive detergent. Do not use solvents.
RECALIBRATING THE CONSOLE To recalibrate the Console , first plug in the resistance system . Plug the indicated end of the Transformer into the Back Mech Cover . Plug the other end of the Transformer into a 120-volt outlet. All indicators and displays on the console will flash once; the console will then be ready for use. The motor may be heard while the resistance system calibrates itself. Important: Always plug in the transformerwhen using the resistance system., press and hold the NEXT button and the MOTORIZED WEIGHT ADJUSTMENT + button for five seconds. When the buttons are released, a number will appear in the REPS display. Press the NEXT button again, then press the MOTORIZED WEIGHT ADJUSTMENT + button; this will start the recalibration process. This may take a few minutes as the motor moves between the lowest and highest resistance settings. When the motor finishes, unplug the transformer from the 120- volt outlet.The Console will be recalibrated. Use the resistance system as described in the CONSOLE
May 14, 2010 | Exercise & Fitness
We have a Nordictrack Futura 2200 and when we set the weight resistance it jumps back to 10lbs. no matter what we set it for it jumps back to 10lbs
When the resistance setting changes, the motor will be heard. To prevent damage to the motor, do not pull any of the cables while the resistance setting is changing. If the motor has difficulty adjusting the resistance level and no cable is being pulled, there may be too much tension on the Upper Cable (110). Adjust the tension as described below. To decrease the tension on the Upper Cable (110), turn the two 3/8” x 38mm Tension Screws (106) twice, counterclockwise. Select the desired resistance setting. Repeat this step if necessary.
Apr 24, 2010 | Nordic Track Nordictrack Futura 2200...
Change batteries in consol of elliptical, but still the resistance or tension does not change or increase
their maybe a loose connection between the upper display and function controls I would pull apart the upper display and check the connectors between the two boards
Feb 28, 2010 | Precor EFX 546i Elliptical Version 4
Increasing the resistance on a DP 400 Exercise bike
20 years old! wow vintage ha well it is actually connected my friend but ur bike is well a little oldy for more resistance u see as the bike gets older the wire to provide the tension losses its tension factor or rather its ability to provide tension like our tendons and ligaments so my friend either change the wire if u can or better change the bike lol
Jun 29, 2009 | Exercise & Fitness
Schwinn 420 Elliptical Trainer Logo
378 people viewed this question
Top Schwinn Exercise & Fitness Experts
Steve
David Payne
David Payne
Matt Olenzek
Matt Olenzek
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
