Question about HP Compaq Presario SR5450F Desktop PC
My SR5450F will not turn on
I press the start button but nothing happens. Button does not turn green and start,
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 20 Answers
Make sure your battery is charged. If it is, sorry about this lacking solution; little information was provided.
Posted on Jan 21, 2013
antiochpc
  • 1314 Answers
SOURCE: DC5100 want start up
You need to replace the power supply, a fairly common problem.
Posted on Jul 17, 2009
jtuckerj
  • 59 Answers
SOURCE: HP computer doesn't turn on
Your power supply is bad--you will need to replace. I suggest looking at tigerdiect for a replacement.
Posted on Dec 12, 2008
  • 16 Answers
SOURCE: PC won't power on.
Try removing the Ram and put it back in, then restart you computer. If you need help in removing the ram just ask me and I will talk you through it.
joe
Posted on Dec 17, 2007
SOURCE: Hav a pavilion a510n HP
I had a similar problem. Moved a 4-year-old desktop. Got the flashing light and no start. Quick fix is to unplug unit, open up case and unplug the large power connector on the motherboard. (On mine this is marked P1 and has a lock tab on one side that must be held in while unplugging.) Plug the 110-volt power and THEN plug the connector back into the motherboard. Button the case back up and all will be well until the next time you shut the power off to the computer.
The cause of this problem is likely that the battery on the motherboard is nearly dead. The flashing light is a warning to replace the battery. (It would have been nice if they would have put this into the user manual.) When you disconnect the power as described above, you interrupt the low-battery circuit. Replace the battery and all should be well.
Posted on Dec 02, 2008
niteshdude36
  • 50 Answers
SOURCE: HP 774y Does not turn on
No ,by the way this problem comes due to RAM.
chek your RAM.
Posted on Apr 04, 2009
The green start light is flashing and won't start again when pressed.
Cycle thru the wash settings. Do all the lights work for the different settings?
Nov 25, 2012 | Washing Machines
I can't turn on the Wii. The red light is always on and when I press the power button (or even the eject button) the blue light is flashing (Only when I press those buttons). I tried the solution of...
Try pressing the power button down and holding it for a few seconds and see if your WII comes back to life. When I first got my Wii I would hold down the button just long enough for it to turn green. This seems like a standby mode. To get my Wii to turn off completly I needed to hold down
the button until it turned red and when restarting the WII I held doen the button until the Wii started back up.
May 10, 2011 | Nintendo Wii Console
I have an Electrolux EWD1477. I have been away for four months and I'm having problems with it. I set to do the quickwash30 program and press start, you hear the clicks, it might put some water in then...
My EWD1477 was doing this a year ago and I fixed it. Then it started doing it again a month ago and I seem to have cleared it again.
Firstly, remove the drain hose from where it is inserted into a laundry sink hole to make sure it is not blocked or sealed in with sludge.
Secondly, make sure the machine is empty of water and clothes and then turn the machine to off with the Program Selector Dial. Then turn off the power at the socket and remove the power plug and leave for five minutes.
Step 1: put the plug back in and turn the power back on.
Step 2: turn the selector switch to the right (Whites/Intensive). The green light of the Start/Pause button should be flashing and the green lights on for Prewash/wash, Rinses and Spinning. Don't press any other buttons or change any other settings.
Step 3: press the Start/Pause button and wait for the machine to empty any excess water. Press it again immediately after you hear water flowing into the machine OR two audible clicks. The machine is now in pause mode with the green light of the Start/Pause button flashing. Only the green light on the Prewash/Wash button should be on. Leave it in pause mode for 30 minutes and then press the Start/Pause button to recommence the cycle.
Step 4: If the Start/Pause button begins flashing, water stops flowing into the machine and the three green lights mentioned above are back on, turn the Program Selector Dial back to off, wait 10 seconds, and repeat the process above.
Step 5: If when you then turn the Program Selector Dial to Whites/Intensive and hear the two audible clicks, immediately press the Start/Pause button to set the machine in pause mode. Wait 30 minutes. Then press the Start/Pause button to recommence the cycle.
Hopefully the cycle will run without a problem.
Mar 26, 2011 | Electrolux Washing Machines
Says to reset color ink tank. put a new one in and says same. reset many times nothing happens
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off .
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indocator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
Feb 21, 2011 | Canon PIXMA iP90 Mobile Printer
I have to get a printout... When I went to my IP2200, I found several pages jammed. I simply pulled them out and rebundled the paper and set them in the feed tray. I then pushed the resume button, which...
Hi. In such situations it is best to reset the printer.
This procedure resets canon iP1200 /iP1600 / iP2200 printers.
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal.
Jul 29, 2009 | Canon Office Equipment & Supplies
Waste ink absorber is almont full. How do i empty this
Hi
Try this to reset the error.
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Cheers
Jul 16, 2009 | Canon i80 InkJet Printer
Start button
The switch underneath the print button has gone bad.A skilled technician can replace the switch or the little circuit board itself.Many copier shops offer carry in service at a reduced rate.Good LucK
Mar 26, 2009 | Office Equipment & Supplies
Printer will not respond
Canon S330 Turn off printer
Press the Power button and the printer should turn off, if not, press the Power button once more.
Jul 22, 2008 | Canon S 330 InkJet Printer
HP Compaq Presario SR5450F Desktop PC Logo
44 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
