Does the door lock? Do you hear a buzzing sound when it tries to fill?
It is
possible that the machine does not start off the cycle because there are errors
due to feedback from the inputs. For the program to start up the main program
controller must initiate the INLET/MOTOR/DRAIN
pump/ valve to open up and allow each function to be driven starting from
the flow of water into the drum as also the drain valve to open to exit the
water at the point of the program cycle. If this does not happen then the
voltage at the valve/motor/pump must be checked or the fault relates to no
voltage from the controller. This means
the controller is a suspect. If the
water flows though the inlet then the flow pressure should be good, if not the
inlet valve is bad or there is dirt in the filter. Also check the flow at the
inlet of the water line. Once the water comes into the system the WATER LEVEL
SENSOR - normally a pressure switch- must activate at the preset/chosen level
to give the signal to the program controller to switch on the motor. What is
most important for the motor to start functioning is that the door switch must
be ON when the door is shut or this will be an error for starting the motor for
rinse and wash. Check this
link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
I'm assuming your washer is a Kenmore or Frigidaire front loading washer. E10 error code is an indication of a slow fill, took to long to fill, no fill or the fill water could be siphoning out the drain hose as it's filling with water.
Check to make sure that the drain hose is not stuck too far down the stand pipe and causing the water to siphon out. Check the cold and hot water supply to the washer for any restrictions. If you have a slow fill remove the hoses from the washer and check for restricted filter screens in the water inlet valve. Check for any restricted hose screens too.
