A few months ago, i had a error code on it (i don't remember the code) it had something to do with the magnet which I fixed thanks to a previous solution to someone else's problem on your site. The rinse compartment wasn't fully draining back then before getting the error code and pushing the magnet back into its place. To my amazement, it not only allow my washer to start back up but it would completly drain the rinse. Now, it is back to not draining fully (full of water) but the magnet is in its place. Do you have a solution for me again? Thanks, Rinsed Out.
It is a common fault that the drain fails to work in
most machines in a period of time and is the most problematic fault in a
washing machine. In all occasions it is important that your observation is most
important and so is vital to the identification /rectification and solution. If
you have noticed that water has leaked then as the drain hose pump/valve and
fittings are located on the underside of the machine it is important that you
look for possible leaks here. In some cases the drain hose would be clogged at
the drain end to outlet of the house and so there will be back flushing
resulting in overflow to the outside. Also the drain pump/valve can be clogged.
Now remove the drain hose clamps and remove the drain pump/valve, clean the
drain pump/valve, use back flushing to clear off all dirt. Now test using power
to see if this works and can be simulated. When refitting, the hose must be tightened
properly. If the pump/valve does not work even with power then it must be
replaced. If there is intermittent power
to the drain valve/pump then the program controller unit is a suspect. Cleaning a pump:
http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp Finally the washer must be placed with a tilt- use a
spirit level- so that all water will drain to the outlet port and thereby there
is no residual water remaining. Replacing the pump on a Bosch machine, please check
this link for tips:
SOURCE: Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
SOURCE: Frigidaire front load washer (LTF600ES1) Error E20
holla, Im not showing a E20 code on the tech sheet. There is a E21. Water not draining fast enough. Try holding the start/pause and cancel key together for 3 seconds. The door lock, wash, rinse and final spin leds should light. Any error codes should be displayed when holding those keys. If you see a different error code, post it. If not, I would suspect a clogged pump...Catriver.
SOURCE: E10 error
The error code chart indicates that this could be a water flow problem, too low of a drain hose height. Check for clean filters of the inlet water line. Check that the drain host was assembled as per the manual's instructions. In any case your machine is still under warranty and you can ask for Frigidaire's assistance. Good luck!
SOURCE: Won't drain...
on the pump there is a lint filter it is either in the drain hose coming from the tub or there is a slot on the pump that screws off.you have to take the front lower panel off to get to the pump after you take the junk out unplug washer for 60 seconds to reset computer. let me know what you find
SOURCE: Error Code E23
Hello welcome to Fixya
E23 means
The drain pump relay on the control board has failed.
Fix: Replace control board or wire!
you can see schematics and diagrams at the site below, and order parts from them if you want.
Or call service!
http://www.pcappliancerepair.com/model-display.php
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
