Question about Aprilaire 700 Humidifier
Fan running but no water flow
I have an Aprilaire 700 series with a manual humidistat. The humidifier fan is running - it is running all the time because I have the furnace fan on all the time - but there is no water flow to the unit. I can adjust the humidistat "up" and "down" and can here the "click" when the unit is supposed to cycle, but there is no water flowing. Even setting to "test/reset" doesn't do it.
I have looked at the orifice after the solenoid and it is fine as is the water inlet hose. Any ideas?
Thanks
    Problem Solver:
  • 17 Answers
The humidistat on this unit just acts as a set of dry contacts. with the humidifier plugged in, you should be able to touch the 2 brown wires by the water solenoid together and get the power fan to run and the water solenoid to enrgize. if you do this and water does not flow, you most likely have a bad water soenoid. it is either electrically bad, or just plugged with water deposits. sometimes you can pull it apart and clean it, sometimes you just have to replace the solenoid.
Posted on Jan 27, 2009
Aprilaire 760 keeps running
Is this a newly installed unit it sounds as if there's a wiring issue. Could you show a picture of the wiring terminals. If this is not a new install try turning of your furnace fan.
Nov 02, 2014 | Aprilaire 700 Humidifier
Solenoid valve
The humidistat could be defective.
Dec 04, 2013 | Aprilaire 700 Humidifier
2005 Aprilaire 700 humidifier. Replaced a non-working circuit board. Now, the humidifier works fine when the furnace is running. It starts and stops as it should based on humidistat setting. Problem: ...
It sounds like it is just miswired. The low voltage wiring off the humidistat should be on W and C on the circ. board at the furnace. If you have it on R and C then it will power it constantly regardless if the heat is running or not. W is only energized on a call for heat which is typically when you want that type of humidifier to run
Feb 02, 2013 | Aprilaire Humidifiers
I have a aprilaire 700 I just installed on return plenum. Have a problem with the wiring, the instruction say to connect the R&C wires from humidistat to the same on furnace power strip. Is the C
Depending on the age of your furnace you may have an aux terminal for a humidifier. If not, you should use the white wire (heat) coming from the homes thermostat to power up the humidistat and ultimately bring on the humidifier. This way it will only run when in heating mode.
Nov 16, 2012 | Aprilaire 700 Humidifier
When does the humidifier fan start? Does the water flow trigger it? Will the fan nt start if I turn off the water supply?
Humidifier should be powered from the furnace heating 24 volt terminals through a humidistat and then to your humidifier. The fan and the water solenoid on the unit should come on together. if the water is not turned on the fan should still run, unless the unit is not plugged in.
Nov 13, 2010 | Aprilaire 700 Humidifier
House is dry though it's quite cold outside and furnace is running. Aprilaire is turned up to 35 (I have a dial, not a digital panel). the water panel is completely dry (should it be?)
unless the humidty in your home is higher then 35%. if it is then the humidifier would not run. try turning it up higher and see if it comes on. Do you hear a click in the humidistat? as you turn up the dail when you hear the click is when the humidifier should come on. Also remember your furnace must be running for the humidifier to come on. if you hear the click and the humidifier fan comes on but no water, you may have a clogged inline filter located in the solinoid valve or a bad soliniod. all parts for your humifier can be purchased from www.aprilaire.com
Feb 05, 2010 | Aprilaire 700 Humidifier
My furnace is not turning on what would be the problem
if you mean your aprilaire humidifier isn't working then open the cover and remove the 4 screws on the fan motor mount inside and check for voltage at the transformer input 120 volts and output 25.5 volts a.c., then check the control board wherever you have it located on the furnace or upstairs and make sure yhe humidity level is set high enough to make the unit run(you will hear the water solenoid click on the furnace below the aprilaire unitwhere the water line is if its working correctly),then check the humidistat on the outside of the building as they can go bad
Dec 31, 2009 | Aprilaire 700 Humidifier
The 700 will not start for this season. I called
reason why I asked they sometimes have a problem sensing current and you may need to wind the wire twice instead of one pass. If you jump the wires at the humidistat and the unit turns on its either the stat or you may want to do a relative humidity check on the house to see where your at
Best regards,
Tinner
Dec 13, 2009 | Aprilaire 700 Humidifier
Aprilaire 700 Humidifier Logo
358 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
