Question about Polaris Winter Sports
550 supersport won't start
Got spark and fuel
  • 29 Answers
SOURCE: 1981 550 suzuki one cyclinder is dead has spark an...
Check compression of cylinders, all should be close the same. Swap spark plugs and check if problem cylinder moved. If bike sits for long periods of time then most likely it will be a plugged carburetor.
Posted on Sep 22, 2010
  • 76 Answers
SOURCE: I have 1998 Escort
Sounds like it may be the spark plugs. If you have a spark maybe a fuel filter is clogged? Hope all goes well!
Posted on May 20, 2011
  • 2926 Answers
SOURCE: Car won't start. No fuel to injectors. No
It is most likey a defective crankshaft position sensor. Was the PCM checked for trouble codes?
Posted on Jun 08, 2011
  • 629 Answers
SOURCE: What size spark plug do
I don't believe your problem to be with your spark plug. Did you hit anything with your blade before this problem started? If so your problem is with your timing.
You will have to check your shear key. Remove the top cover to your engine and any attachments. Remove your flywheel, and you will see the shear key between the flywheel and the top of the engine crankshaft. If the shear key is even slightly dented replace it . This is what is causing your problem. You will be up and running soon. GOOD LUCK.
Posted on Jul 13, 2011
  • 94 Answers
SOURCE: 98 crv won't start
Check compression and timing belt. If belt is ok and you have compression, check to see if you have a pulse at the injectors. You use a device called a NOID light (basically a light bulb that plugs into the injector plug. Unplug the injectors one by one and plug the light in then crank the engine. Light should blink on and off if the system is working properly. If not check for a bad crank sensor, blown injector fuse and wiring harness. Hope this helps.
Posted on Nov 03, 2011
Ducati 900 supersports 1999 wont start
Hi, Anonymous and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
8. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
10. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2 and/or BAS).
11. Security alarm needs a reset.
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
ducati 900ss no spark
Bike Won Start Starter Relay No Click
Ducati 900 900SS Supersport 2001 Service Repair Manual Download Manuals...
Ducati OEM Parts Fiche Lookup and Online Ordering
Ducati Maintenance
Feb 08, 2013 | 1994 Ducati 916
Why won't 1981 suzuki gs 550 bike won't start after riding it and it's warmed up?
hi
glad i served a long time with wisco and used drag raced for them at one time
sounds to me that your ignition is to far retarded
which means the ignition will spark closer to (TDC)
top dead center
some people advanced the ignition 3 deg to stop the engine from smoking when they did away with 4 star fuel
and gave us unleaded fuel
doing this the performance is great and fast acceleration
but it also make the engine run hotter than normal
unless you have up jetted the carbs
and fitted a non standard exhaust system
the whole idea is get the fuel/air mixture in and out as fast as possible
if you still have points
take your points cover off and adjust your points baseplate
undo the three screws that hold it in place
and just move it about 3 deg towards the rear of the engine
or may be you have a electronic ignition fitted
if so do the same thing
and advance the ignition 3 deg
hope this works for you
ride safe
Sep 18, 2017 | 1982 Suzuki Gs 550 L
Hi everyone I have a 125 4 stroke ducar engine it won't start I don't know why can anybody help me the petrol goes thru and it had a spark I have no clue why it won't start
there are three things that engine needs to start fuel,spark and compression you stated that fuel and spark but what about compression if no compression could rings or valves!
Jun 02, 2012 | 2003 ATK 125 4-stroke
97 gmc jimmy cranks but won't start, have replaced everything possible but still won't start, most of the time the brake lights won't work, or the gauges goes crazy. I have changed relays,...
There are two basic reasons for not starting - no spark or no fuel, both of which are controlled by the ECM. You need to check error codes and these items - for the spark, test it at the cylinder 1 sparkplug; for the fuel check the pressure (if too high or low, problem!).
Aug 28, 2017 | 1997 GMC Jimmy
Poulan won't start
check for spark then try carb cleaner behind the air filter
Mar 31, 2012 | Poulan Pro PR550N22SH 22Inch Briggs ...
1997 mazda 626 won't start.
Are the plugs wet with fuel?
Check for spark. No spark? it may be the ignition module.
Plugs dry and spark present? No fuel?Spray a little starting fluid and see if it will run on that.
Then check pump fuses and for fuel pump noise.
Jun 01, 2017 | 1997 Mazda 626
Once in awhile it won't start , wait about 20 minutres and it starts........... 2005 chevy MC Supersport, Supercharghed
Your problem may be one of the following:
First check or just replace the fuel filter. Usually located under the car in front of the rear axle, drivers side.
Next, the fuel pump may be worn out. Usually they get loud or stop working (running).
Next, check the fuel pressure regulator. Usually located on the front fuel rail, drivers side.
Is the vacuum line attached? Not leaking or rotted?
Also, do you smell a strong fuel odor when it won't start? May be one or more stuck-open injectors, or the coil pack is bad.
Checking these in the order listed will more than likely fix your problem.
The clicking noise indicates the battery can no longer run the starter, which also means the fuel pump won't run either.
It could be a fuel issue. How old is the fuel filter? Can you hear the pump run for a few seconds when you turn the key on? Try turning the key to ON without trying to start engine three times waiting for the pump to stop running each time. Then try to start the engine. If it starts, Its a form of Vapor lock caused by the extreme heat we have had lately, and a weak fuel pump.
If none of this works, try a new fuel filter first. From there have someone check the fuel pressure regulator and then the pump. If you are in need of a new pump, take my word for it and spend the money to get one from a Dealer, and not from your favorite parts store. Most parts store parts are made in China and they are JUNK.
Aug 28, 2011 | 2005 Chevrolet Monte Carlo
Can't start my Ducati 800ss., Everything proceeds as normal when I insert key and turn it on with the exception of, I do not hear the humming of the fuel pump it kicks over but not start. I am getting...
Hi, Biag start with # 11 and the usual suspects are:
1. Fuel tank empty.
05 800ss wont start
92 Ducati 900ss Won start
Ducati Supersport 800 1000 Workshop Manual Repair Manual Service Manual...
Ducati Maintenance
May 15, 2011 | Ducati SS800 Motorcycles
Winter Sports Logo
44 people viewed this question
Top Polaris Winter Sports Experts
Larry Fostano
Larry Fostano
Bill Boyd
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
