Question about Casio QV-R41 Digital Camera
Camera is blocking card
I have checked out what was suggested but the camera is blocking the cards. It Works on its own memory just not with the cards, so fault in camera itself. Havn't a CD for it so is there a page to download so I can format or fix camera online
  • Jeannette Darlington Jul 19, 2007
    It is a Panasonic Card and the camera wont allow for the card to be formatted.
  • 374 Answers
What does your camera do when you try to format the card? Casio only recommends using Sandisc, Toshiba and Panasonic memory cards. I dont believe that there is a firmware upgrade available for your camera that would fix what is going on. Try formatting your memory card first and hopefully that will make it able to save on your card instead of internal memory.
Posted on Jul 19, 2007
My camera doesn't see SD 16GB anymore. Worked fine until a few days ago. SD works fine on PC
Try inspecting the memory card slot, eventually with a magnifying glass. Sometimes just a little bit of dust, a small paper or other debris, can block data transfer. Be sure al contacts on the card, but also in the camera are clean and shining. Never use sharp tools in or around a camera. Don't scratch the contact points.
And to make sure you can put pictures on a memory card, there must be space. If possible try to format the card in the camera. Just to make sure the camera sees the correct file system on the memory card.
Dec 15, 2013 | Panasonic Lumix DMC-FZ28 Digital Camera
No display on lcd no picture
The shutter is jammed closed. This blocks the light from reaching the image sensor. This problem can generally be fixed without parts, price will be $100-150 for labor from a professional. Depending on the purchase price of the camera, you may be better off getting a new camera.
Jul 12, 2007 | Samsung Digimax 530 Digital Camera
How to resolve camera problem in sony k660i
Try to remove memory card and battery and wait for 15 minutes to reset the phone. Check you memory card for errrors. now insert batttery and switch on if camera works fine then inserrt scanned memory card into the phone.
If there are still issues then you might have to checck for hardware issues of the camera or fault in the software which must be reinstalled.
Sep 16, 2010 | Sony Ericsson K660i Cellular Phone
I didn't drop my camera or even touch it and it started saying lens error and automatically shutting down. How do I fix this?
Remove the battery and also the memory card and keep aside. after about 30 minutes reinsert the battery and hold down OK button, then switch on to see if the camera resets with the lens correcting. If the fault does not clear, repeat once again but hold the lens on the palm and tap softly to reset the mechanism from any blocks.
If none of the above works you will need help to open and check.
Aug 27, 2010 | Canon PowerShot SD1400 IS IXUS 130...
Fuji FinePix F470 works perfectly unless a memory card is present
Some cameras are very sensitive when it comes to memory cards for some odd reason. I would try a different make of sd card.
Oct 13, 2009 | Fuji FinePix F470 Digital Camera
Camera does not recognize memory card
It appears the SD card the retailer sold is not compatible with the camera. Put in a different memory card and camera works fine.
Dec 28, 2008 | Nikon COOLPIX L18 Digital Camera
The camera's card blocked
problem is the memory card reader pins might be bent. i normally replace the main board to fix this issue. cost can go from 75.00 and up.
Oct 22, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Memory Card Error
format the memory card by using low level format in your camera itself.
it must work. check out and reply the rating
Dec 27, 2007 | Pentax Optio M40 Digital Camera
Memory card??
May be you should see the settings of your memory card, may be its lock! try to configure in it!
Apr 06, 2007 | Nikon Coolpix 4600 Digital Camera
Casio QV-R41 Digital Camera Logo
62 people viewed this question
Top Casio Cameras Experts
pontelemon
pontelemon
Ron Grant
Level 1 Expert
Are you a Casio Camera Expert? Answer questions, earn points and help others
