Question about Generic Hisense 42" Class LED-LCD 1080p 60Hz HDTV,1.5" ultra-slim F42K20E
Hisense lcd problems color spots - Generic Hisense 42" Class LED-LCD 1080p 60Hz HDTV,1.5" ultra-slim F42K20E
Hisense tv flashing 6 red lights
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Feb 24, 2015 | Hisense Televison & Video
What causing this problem
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Dim screen
- Slow start
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Sep 23, 2014 | Hisense Televison & Video
Where do I find the manufacture's firmware file for a Hisense 50" LCD smart tv model 50H5G
You have the link to the official website of Hisense. So not sure why you had a problem. I am assuming you purchased the TV in USA.
If that is not the case then you may have to go to the Hisense support website in your country. The firmware can make a difference to the local TV type e.g, PAL or NTSC.
If you are in USA then try once again. Type the model of your TV in the field and download the firmware zip file and install as in instructions provided. Hisense Firmware
You can change country by going down the page at the bottom of the Hisense USA site. It is possible no firmware update was available for your country. This means you have to call local Hisense support and restore the original firmware file.
Sep 11, 2014 | Televison & Video
How To Solve HiSense LCD TV Model F40V87C With Distorted Display Problem
You need to re set that model. Un plug all and and just set the tv without recorders or phone or skype. NOTHING ELSE. Then wait a bit and add one by one to see what is causing that - it could be cable or sattelite dish? - as i said start with fixing the tv.
Aug 13, 2014 | Hisense Televison & Video
Horizontal lines LED hisense tv
- Flickering screen
- Dim screen
- Slow start
Apr 05, 2014 | Hisense Televison & Video
TV issue
There are many causes for spots on top of an LCD rear projection tv, you are probably in the first two cases, both require part replacements and repair job.
If the spots are faint blue, green or pink shadows, then it can be a problem with the anti polarization panel placed on top of the LCD.
Similar spots (colored shadows) may be caused by a problem with the light engine, in that case the fix will be expensive.
If the spots are bright lights, like an aura, that is a problem with the color wheel.
Problems on the light tunnel can cause static gray shadows.
If the spots are static dark stains than that is lcd liquid, the LCD panel must be replaced.
Oct 15, 2008 | Televison & Video
Hisense LCD Tl2020
I, also, have the Hisense LCD 1504 and cannot turn it on with the original remote. I have to use the ON button on the side every morning. You have to hold this button in for a while then wait a while and presto, the blue button shows on the front and the picture comes on. If it fails to work the first try, just try try again. It does work for me this way. We had this same experience with the TV in our room at a Hotel where we were on vacation and the TV worked fine when we turned it on using the side ON button. It just takes a while for the picture to appear. Hope this clue will help someone.
Sep 16, 2008 | Hisense LCD1504 15 in. Television
My LCD has green spots
i have the same problem in black color but its not my screen i belive its only in vista
Apr 20, 2007 | Vizio L32 32 in. LCD HDTV
Generic Hisense 42" Class LED-LCD 1080p 60Hz HDTV,1.5" ultra-slim F42K20E Logo
22 people viewed this question
Top Generic Televison & Video Experts
richie46
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Generic Televison and Video Expert? Answer questions, earn points and help others
