Question about GE Nautilus 24" Built-in Dishwasher
Dishwasher leaking my GE Natulus dishwasher is leaking from the bottom seal, Is the two pieces that are at the very bottom that hold the motor where the seal is? I'm not seeing a seal. I'm not sure if that is where it is leaking. I've got the thing torn apart so it is difficult for me to say where it is leaking. I'm going to give it a whirl. Don't know if the repair is worth the trouble. The GE dishwasher is only 7 years old. What is the avg life of a dishwasher. I'm sure it's not top of the line, it was installled with the house new.
  • Anonymous Jan 27, 2009
    my dishwasher is also about seven years old and came new with the house. It leaks underneath and the water comes out the bottom left front-side. We looked for a seal which we could not seem to find. Please advise us about fixing this as it really works well otherwise. I just dont want it to rot the floor.
    Thank you
    Jennifer
  • Anonymous Feb 03, 2009
    my ge dishwasher does the same thing - leaking from the bottom left corner of the door - someone told me to repl the seal - just didn't know what to do
There is a front door seal that may be the issue. It seals along the door sides/top and continues under the door to seal the bottom surface when closed. Mine pulled out of the seal channel under the open door where you can't see it without a small mirror. The seal took a "fixed set" out of the channel so now it will not stay put. It requires replacement.
Hope this helps.
Posted on Feb 09, 2009
My GE dishwasher is leaking out the bottom of the front door. Everything seems to be sealed properly. I took the inside of the door off and couldn't find anything obvious. Is it possible to be overflowing...
You most likly need a new bottom door seal. Usually 3 screws down each side of the door and then two screws hold the bottom door seal in place. The bottm door seal can look fine but if its leaking out the bottom front this is the problem 99 % of the time, Unless someone is using dish soap to preclean the dishes or using regular in the dishwasher.
Mar 20, 2010 | GE 24 in. GSD3330C Built-in Dishwasher
Kenmore Dishwasher leaking from bottom but not while draining....
Leak is associated with the water pump, either a hose or seal
Sep 29, 2009 | GE 24 in. GSD4020Z Built-in Dishwasher
Danby DDW396: pump leaks when in use.
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Jan 11, 2009 | Danby 22 in. DDW396 Free-standing...
We have a GE Dishwasher Model # GSD 2000 Z02AD - water leaks
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
Door gasket or seal
Water-inlet valve
Hoses
Jan 06, 2009 | GE 24 in. GSD2230Z Built-in Dishwasher
Ge nautilus leak left side
If your dishwasher leaks, check these: Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Oct 05, 2008 | GE Nautilus 24" Built-in Dishwasher
Leaking from rear in cabinet
  • Lower rack
  • Spray arm
  • Spray arm support
Sep 30, 2008 | GE Nautilus 24" Built-in Dishwasher
Caloric Dishwasher DUS203190A
Hi thanks for the question On a ge dishwasher , more often than none it leaks from the motor seals If thats what the problem is you will see it leaking from the motor shaft , It could be leaking from above the motor if it si from the tub ,Replace the part that joins the motor to the tub if its motor seals .Replace motor seals
Sep 07, 2008 | GE WHRE5260E Top Load Washer
Leak from dishwasher
I currently had the same problem with mine and the culprit was the boot that screws on to the spray arm which serves as the seal from the spray arm to the motor.To find out spin the base of the spray arm loose and take off the screw tightened clamp that holds the boot to the motor. Mine had dry rotted and leaked very badly.The part as only about $10. Hope this helps
Aug 04, 2008 | GE 24 in. GSD4060JSS Built-in Dishwasher
Leaking water
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Water-inlet valve
Hoses
Jun 30, 2008 | GE GSD1180X Dishwasher
GE Nautilus 24" Built-in Dishwasher Logo
373 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
