Today I sighened up for tim shrieves 30 day coaching course, but cannot find members login address
SOURCE: UPRIGHT FREEZER
Some units have a selector switch that says; reduce moisture/save energy. If you have this its obvious what to do. If you don't have one or are getting condensation anyway, check the door gasket. Make sure its getting a proper seal. The outside air has water in, aka, humidity. If the unit sucks air from outside, as it cools it will condense and make dropletts accumulate on the top. The drainage from the defrost may also be seeping in and cause the water too. Especially if its on the bottom. It may have a clogged drain line.
SOURCE: code came up when trying to set tim code " 5A6 "
The error your range is displaying is actually "SAB", which means it has inadvertently been set on "Sabbath Mode". This mode enables certain religious faiths to disable certain features of the range in order to honor the sabbath. Usually this disables the oven, but allows the consumer to still use the surface burners. You cannot defeat it by unplugging the range or turning off the breaker either. You will either have to wait 72 hours for the mode to clear, or figure out how to turn it off.
If the model number is correct, somewhere in the owner/operator's manual is a section that refers to "Sabbath Mode". Since all ranges differ in features, you need to refer to the operation section of your owner's manual to find out how to shut the feature off. According to page 17 of the Owner's Manual, to cancel the Sabbath Mode, you need to press and hold the CLOCK button for 5 seconds.
If you can't find this information, or no longer have an owner's manual, you can download or print a copy for FREE at managemylife.com. Just enter your model number under the "Manuals" link and you will find it listed in .pdf (Adobe) format.
If you have questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
SOURCE: i get weak coffee i
clean with CLR and then water rinse....use DRIP fine grind
1 tablespoon per cup..........remember strength is the coffee and the amount of water.
SOURCE: want to disable day tim running lights
Here is a link for you on how to disable the DRL.
Good luck and thank you for using fixya.
http://www.s10forum.com/forum/f62/ahl-and-drl-how-tos-34645/
SOURCE: Can I sign in with my member number? My email/password don't work!
well here goes change your password but use your original email address try that
