Whirlpool washer dryer not spinning one item
Hi. I've been wanting to use the Drain/Spin programme to spin-dry a bath mat (which I hand washed and squeezed out). On previous occasions I've done this successfully, but now it won't spin up to the selected speed (600), perhaps only reaching 100 rpm. There's almost no visible wobble in the drum which may have indicated an unbalanced load. If I empty the drum and use the same settings it spins up okay. Draining seems unobstructed, and no error codes are displayed. Do these machines have a sensor for unbalanced loads which can become over-sensitive? It's coming up to 7 years old. Thanks for any advice.
  • Colin Goble Jan 24, 2013
    Thanks, Brian. I've since found similar suggestions to yours, so I'll definitely try it next time. Must have just been lucky before!
    Problem Solver:
  • 13 Answers
That is normal for front load washers. It doesn't have a sensor to detect unbalanced load. The computer can detect through the motor that load is not equal so that it will not kick in to high spin and shake the machine to pieces. Put in some towels or something else with it to balance it out and it will spin. I have owned a laundromat for 10 years and I have speed queen horizon machines and they are the same way. People are always washing rugs in them and they do the same thing. Just be sure to clean the button trap on the pump at least once a year
Posted on Jan 22, 2013
  • Brian Reynolds Jan 22, 2013
    Thanks, Brian. I've since seen other suggestions like yours, so I'll be sure to try it next time. Must just have been lucky before!
  • Washing Mach... Master
  • 17,130 Answers
In fact there are sensors that can detect higher vibration and there by control the speed. It must be seen if this is available on your model. Please check the capacitor to the motor, couple a similar one and see if the speed improves. Also check for free movement with your hand , if not you need to reset the drive assembly.
finally check on the motor, check the drive.
Posted on Jan 21, 2013
  • 1294 Answers
SOURCE: "Test" displays no washing done!
Your test mode is on, maybe accidently. Press "start", "cancel", "on" & "off" together for 10 secs, you will see d/off come on the display. Do the same & the test mode comes on again.
Rate pl.
Posted on Dec 02, 2007
SOURCE: Doesn't spin the clothes dry on the final spin but spins at high revolutions without a load of clothes
I have read that if the pump is not draining the tub completely, there is an interlock that prevents the high speed spin from engagin. I have had debris caught in my pump several times (kids!!) with similar issues. There is a trap on the line leading from the tub to the pump which is "supposed" to capture debris, but it doesn't work all that well. Check your pump.....
Posted on Dec 23, 2007
docjohn174
  • 943 Answers
SOURCE: frigidaire affinity front loading washer won't drain
HI .THANKS FOR YOUR QUESTION. THE PROBLEM IS WITH THE WATER PUMP.REMOVE 2 SCREWS AT BOTTOM OF FRONT PANEL . PUMP ON RIGHT .REMOVE HOSES AND CLEAN OUT THANKS THE APPLIANCE DOC.
Posted on Oct 04, 2008
SOURCE: front loading washer won't spin
my amana washer wont spin and does not drain
Posted on Sep 12, 2009
techbuster
  • 5081 Answers
SOURCE: Whirlpool front load washer getting an error code of "F6"
f 06 is a in issue with the motor control board, check the wiring harness attached to the board.
Posted on May 21, 2010
Spin is not fast enough for bath mat even with other items in washer. How do you activate spin indepedently?
Hello, Welcome to FixYa. I think what you're referring to..."tub mat will not spin fast enough to dry"... is not an intended function of the washer. I don't know if you purchased these machines yourself or have access to the owners manual/operation guide, but if you do you can verify what I'm telling you. Front load washers ( any washers really, but top loads are a little more forgiving ) are not intended to wash bath mat's or any single items. If washing a single item one must either select a "no spin" or add another garmet/item of equal size or mass to balance the weight of the load, otherwise the unit will not spin to it's potential...if at all. This is an exert from the Kenmore/Whirlpool operating manual... 1. To load washer Open the washer door by pulling on the handle. Sort laundry according to color and type of fabric. Place a load of sorted clothes in the washer. Do not overload washer. Overloading can cause poor cleaning. The washer can be fully loaded, but not tightly packed. Washer door should close easily. Mix large and small items. Avoid washing a single item. Load evenly. Wash small items such as infant socks in mesh garment bags. It is recommended that more than one garment bag be used and that each garment bag be filled with equal amounts of material. Hope this info helps clear this up for you. Let me know how that works, but that should fix the problem. Good luck. Thank you for choosing FixYa to day for your inquiry. Regards, Macmarkus :)
Mar 04, 2011 | Kenmore HE2 Plus Front Load Washer
Washer won't spin and empty the water out of the
Shirley, it may be the drain pump is obstructed or possibly the lid switch is broken. If you washed bath mats or rubber backed rugs recently i would go for the pump. If you washed a semi bulky item with a tendency to float I would go for the switch.
Get me a model number and I can help you with dis-assembly if you'd like further help!
Jun 11, 2010 | GE Spacemaker Washer and Dryer Electric...
How can I spin dry bath mats??
you gotta add a few more items like some towels, try it
Feb 12, 2010 | Electrolux EW1000i Front Load Washer
Washer won't spin. Washed bath mats (small) and
Read a post from someone else on this - turned out it works fine, just wouldn't work with the small wet load. I added towels to the bath mat load, washed them, it spins fine. Washed clothes & that worked fine too. Yay!! Not broken. Just not found of small loads of bath mats!
Jan 22, 2010 | Frigidaire ATF6000ES Front Load Washer
The machine stops after the wash cycle and won't finish.
The code is UE
load too small.
• Load is out of balance.
• The washer has an imbalance
detection and correction
system. If individual heavy
articles are loaded (bath
mat, bath robe, etc.) and the
imbalance is too great, the
washer will make several
attempts to restart the spin
cycle. If an imbalance is still
detected, the washer will stop
and the error code will be
displayed.
• Add 1 or 2 similar items to help balance the load.
• Rearrange items to help balance the load.
please rate this help to keep the service online
Aug 20, 2009 | LG Washing Machines
Calypso washer - LD Code - clothes still wet
harborstuff,
The code on your machine stands for 'Long Drain'. Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. I would bet that the bath mats left a bunch of stuff stuck in the recirculation pump hose, or pump itself, and the water cannot be drained fast enough. Check the intake and exit hoses of the recirc pump. It's easiest to get to the pump through the front panel of the machine(click here). Looks like this: click here. Hope this helps.
(Definitely get under there and check to make sure the pump hoses are not clogged. At $129 it's an expensive fix for a $10 bath mat that clogged up the hose with fuzz. 'know what I'm sayin'' :o) )
-samson39
BTW, I have the maintenance manual & have experience at replacing the recirc. pump, control board, motor board, touchpad, & lid switch so far.
Jul 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool washer lxr9245eq1 doesn't spin dry completely
Try this... while in in spin turn your spin selector switch and listen if motor spins slower or faster.. at fast spin open your lid quick to see how fast its spinning.. check and make sure your drain line is cleared and the water flow out fast...and if its spinning too slow problem is in the gearbox area..
Jan 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Clothes come out soaking wet
Is the Delicate or Hand Washables cycle selected?
Spin speeds can vary by the cycle that is selected. Your washer is designed so that in certain cycles, such asDelicate or Hand Washables cycles, the spin speeds are slower. In these cycles, more water is retained in the load at the end of the cycle to keep delicate fabrics from shrinking and wrinkling. Select the appropriate cycle based on the fabric being washed.
Was an Extra Low, Low or No Spin option selected?
Select the highest spin speed for the fabric being washed. If extra low spin or no spin was selected, the washer may not remove enough water from the load.
Were you washing one bulky item, such as a rug or large blanket?
Consider adding more items to help balance the load during spin. Select $FL-drainspin cycle and restart the washer. Your washer is designed to detect an unbalanced load and automatically lower the spin speed. Unbalanced conditions are more likely to occur with a single, bulky item.
Are excessive suds present?
Use only HE High Efficiency detergent. Using non-HE detergent or more than the manufacturer's recommended amount of detergent can cause excessive suds. The excess suds can cause the washer to run at a reduced spin speed, which will result in very wet loads.
See also: Why HE High Efficiency detergent is required.
Is the drain hose kinked or is the drain clogged?
Make sure the drain hose is not kinked. Straighten the hose for adequate water flow. Remove any blockage from the drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose. See the Installation Instructions for details; find them by entering your model number in the Manual and Literature search below.
Is the end of the drain hose more than 96" (244 cm) above the floor?
The drainpipe (standpipe) height requirements are: 96" (244 cm) maximum and 30" (76.2 cm) minimum. Your washer will not be able to adequately pump the water out of the washer if the drainpipe (standpipe) exceeds 96" (244 cm). In this case, the water may flow back into the washer. See the Installation Instructions for details; find them by entering your model number in the Manual and Literature search below.
Is your outlet voltage low?
Check electrical source or call an electrician.
Dec 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dec 18, 2007 | Frigidaire GLTR1670A Front Load Washer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
