Question about Toshiba 57H82 57" Rear Projection Television
How to fix fuzzy pic & red,blue,green lines on your screen?
I have a toshiba 57h82 and my tv turned really double or triple focus the colors lines red,blue & green comes all the time , i tryed to touch focus but it comes back as error what should i do plus i have fuzzy pic is this tv worth fixing?
  • gmalayman Feb 05, 2009
    Same problem. Here's what a repairman told us:
    this sounds like a convergence circuit going bad. a repair cost would range 300-400. this is a good model and worth a repair.
    as far as a new tv i will tell you i work on more of the newer tv`s than the older ones. but if you have to buy a new tv then stick with a name brand. like sony or toshiba, panasonic.
    Problem Solver:
  • 105 Answers
Typically this is due to a convergence chip failure. This repair can be done pretty easy with the proper instruction. Have a look at this video to help determine if you truly have a convergence problem.
Posted on Apr 17, 2012
  • jjlynch Apr 17, 2012
My Phillips projection hd tv is blurry, cleaned the lenses but still have fuzziness. tried to focus the 3 bulbs in the back, they look ok on screen but anything that black or blue is extreamly fuzzy. please help
Posted on Apr 18, 2010
    Genius:
  • 2,920 Answers
I would call a repairman and have him come out and fix it.if you like the tv then its worth fixing if you dont then dont invest any money in it. but if it were me id have a repaiman come and fix it
Posted on Jan 26, 2009
  • 112 Answers
If you use a scart lead, I would suggest trying another one.
They always play up.
Other than that, it would probably be best to buy another tv.
I had one the same as yours.
Most `trading post` and `used electrical stores` sell them for £200 bucks.
good luck
I'm getting a double image of everything on the screen in a hazy blue colour. I tried configuring the colour within the menu but the cross simply won't line up. touch focus seems to work with the...
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Aug 11, 2011 | Toshiba 57H81 57" Rear Projection...
I have a Toshiba 57H82 rear projection tv. It has colored wavy lines on the screen and no picture.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 19, 2011 | Toshiba 57H82 57" Rear Projection...
Colors in left upper corner like a rainbow and fuzzy warped picture with lines that will run thru the picture from time to time, majic focus does not clear this up and I can not get the color set...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 06, 2011 | Hitachi 50SBX78B 50" Rear Projection...
Toshiba TP50G50 Theaterview picture is double with red color only
Your alignment is off. Go to the set up menu then convergence. hit right and you will be in the convergence menu. select the color that is not in alignment. The green line does not move. if blue and green are lined up the line will be cyan. if red and green are lined up the line will be yellow. when all three are lined up the color will be light. Best of luck!
Nov 16, 2008 | Toshiba TP50G50 50" Rear Projection...
Green bowed bands
replace convergence ic
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 27, 2007 | Toshiba 57H82 57" Rear Projection...
Green flashing screen
Dec 26, 2007 | Toshiba 57H82 57" Rear Projection...
Aging 43H7143
Dec 24, 2007 | Toshiba 43H71 43" Rear Projection...
Yellow hue
1)Please verify your model # from back of set......
2)Reduce the color to minimum or tune in a black & white chan.
you should see gray, not yellow hue
3)Remove lower front grill cover & access panel.....locate the
focus / screen control block...turn blue screen control slightly
CW......red,green and blue must mix to equal gray
4) reset color to normal level.......reassemble
Dec 22, 2007 | Toshiba 57H82 57" Rear Projection...
Toshiba 57h82
your convergence amp ic's./if you want to cheat/align the other two colors and manualy move the green yoke rings on the green picture tube neck so the green cross aligns with the red and blue.,they shuold form white when all three are aligned,on top of each other.
Sep 13, 2007 | Toshiba 57H82 57" Rear Projection...
Toshiba 57H82 57" Rear Projection Television Logo
971 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
