Will not power up. when plugged in the pwr led lights up, but when i press pwr the led dims and lights back up.any suggestions
5 Suggested Answers
suxia
  • 143 Answers
SOURCE: pwr s/w- pwr led- hhd led were disconnected how
here is guide PG 174 may be useful but it almost show nothing about leds and connections try find colors in connectors and it may help. It is official support page if find more will post.
Posted on Aug 06, 2009
  • 3 Answers
SOURCE: where do i plug hdd/led pwr/sw pwr/led?
Cklick on this picture and you will know...You have to connect all three to "Front Panel" connector the way it shows on this picture...
http://img33.imageshack.us/img33/9223/11frontpanelinstall37sc.jpg
Posted on Jul 17, 2010
CreativeTECH
  • 1719 Answers
SOURCE: where do i plug in
Front Panel Connections of DFI AM35-EC Motherboard
DFI AM35-EC Manual (Refer Page 14)
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Posted on Jul 01, 2011
  • 669 Answers
SOURCE: _motherboard_wiring_diagram speaker,pwr sw,reset sw,hdd led,power led wire connections
Here is a link to the user manual, i think page 16 is what you are looking for.
http://download.ecsusa.com/dlfilepcc/manual/m957g/957G_10A.pdf
Posted on Feb 14, 2012
How to make the led brighter
To fix the dim brightness level, remove the battery and pull the plug out of the mains power. Leave it disconnected for at least 5 minutes then plug it back into mains power. You should find the brightness has retuned to normal. I have 3 of these Clock Radios and the picture attached shows the comparison between dim and normal. For some unknown reason they intermittently decide to dim themselves. This may be why Sony included a dimmer in the next model up ICF-C318. Anyway I hope this helps
Jan 18, 2014 | Sony ICFC218 Clock Radio
Infocus 5700 will not power on
Try re-installing the driver for the projector. It might help.
Jun 29, 2012 | InFocus ScreenPlay 5700 Multimedia...
Dim green light on power supply blinking
If the Power supply LED dims and flickers its either your motherboard circuit has been cut or there is a short in the laptop. The AC adapter is not the cause.
Try this:
Remove the battery, then press power button to drain all the current, then re-install battery and plug to adapter.
If that doesn't work, then it's most likely the motherboard.
Mar 19, 2012 | ASUS (X83Vb-X2) PC Notebook
I need help connecting the power on cable and led cable as well as the hard drive light cable. for my emachine w3644
These cables are attached in the lower right corner of the motherboard. There are two rows of pins there. Probably 10 pins in all. They should be marked with letters something like hdled (hard drive LED), pwr (power light) pwr sw (power switch) spk (speaker) etc. Anyway, if you can't find markings, hooking the little plugs up to sets of the pins one plug at a time will tell you which works.You can't hurt anything by trying various combinations
Feb 13, 2011 | E-Machines Computers & Internet
I have 3 wires on my pc and i dont know where to connect them on my motherbaord - the wires have writen on them "HDD LED" "PWR LED" "PWR S/W" can any1 help me?
Hi Dan,
The wires are from the front panel. HDD LED which causes an led (usually red) light to turn on when the Hard Drive is active. The PWR LED turns on an LED light (usually green) when you turn on your computer. The PWR S/W turns on your computer when you press the on button of your computer. The front panel connector riser is usually located on the bottom right of your computer. They fit on little pins. Unfortunately there is no standard, so connections vary. Sometimes the pins are labeled on the motherboard. . Check your manual. For more info do a google search for "Motherboard front panel connectors". Hank
Mar 12, 2010 | Intel Computers & Internet
Pin placement for ms 6741 mb
the manual for your motherboard can be downloaded here:
http://www.msi.com/index.php?func=downloadfile&dno=3812&type=manual
On page 2-17, the pin-outs for those connectors are specified in detail. They are part of the JFP2 header:
PIN SIGNAL DESCRIPTION
1 HD_LED_P Hard disk LED pull-up
2 FP PWR/SLP MSG LED pull-up
3 HD_LED_N Hard disk active LED
4 FP PWR/SLP MSG LED pull-up
5 RST_SW_N Reset Switch low reference pull-down to GND
6 PWR_SW_P Power Switch high reference pull-up
7 RST_SW_P Reset Switch high reference pull-up
8 PWR_SW_N Power Switch low reference pull-down to GND
9 RSVD_DNU Reserved. Do not use.
-Jon
Sep 01, 2009 | MSI K8MM-ILSR (MS6741030) Motherboard
Forgot password in safe@office 500
Please try the following, if issue persists please contact the support team:
To reset the box to defaults, please do the following:
* Unplug the power cord.
* Hold the reset button on the back of the box.
* Plug in the power cord while holding the button until the pwr/sec led is steady red.
* Leave the reset button for 3 seconds.
* Press the reset button again for 10 seconds until the pwr/sec led starts blinking red.
* Reconfigure your box and install certs.
Jul 15, 2009 | Check Point Safe@Office 500 Router...
Please offer advice if you can.my job is seriously on the line. My Lacie D2 external hard drive power failed today while in use on a Mac using pro-tools music software I foolishly had not backed up some...
You don't mention if there is any clicking coming from the drive - so I'll suggest this...
Crack open the enclosure and remove the drive (this will void your warranty,) find matching I/O and PWR cables and just connect the drive to your Mac. If you hear clicking - then your dive is mucked up. If you can READ from the drive, the enclosure has an issue and should be addressed to the manufacturer for replacement.
Dec 02, 2008 | Computers & Internet
I have a e-machine. Model w3619 a friend sold to me. He unplugged the two power leads that lead from the power button on the front panel from the motherboard.Where do i reconnect them?
The correct wiring plan for this computer is as follows:
Pwr Led Pwr Sw N/C
X X X X O
X X X X X
HDD Rst N/C
Note : N/C = no connection, top row has no pin, bottom row has a pin but not connected.
when you plug in the Pwr Led and HDD connectors, a light should come on, if it doesn't , turn off the pc and turn the connector round on the pins, re -power on your pc.
Nov 30, 2008 | E-Machines (308714) Motherboard
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
