Question about Dell Inspiron Computers & Internet
Lap top to slow to starting
When i turn on takes 10-20 minutes and keep frozen after that is runny ok.
    New Friend:
  • 8 Answers
This mainly happens when ur windows is regularly updated but the main reason is that u might not be clearing the temporary files which increase the booting time..For this-
Go to START>RUN
*Type there 'TEMP'(not case sensitive) and in the window that appears, select all files and delete them.
*After this, in the RUN dialog box type, '%TEMP%' and select all the files appearing in the window that appears and delete all the files.
Performing this task regularly would surely make a change...
Posted on Jan 21, 2013
3 Suggested Answers
nonontech
  • 4737 Answers
SOURCE: my toshiba lap top keeps displayin the message
It seems your system is infected by virus... you need to run a virus scan with an up to date antivirus.. boot into the Safe Mode with networking and see if you can give a try with this or not.. Good luck.. nonontech@gmail.com
Posted on Apr 29, 2010
Testimonial: "very help full thank you x "
Flyback
  • 12 Answers
SOURCE: slow start up
Slow startup is caused by programs that initialize during startup. THings like MSN messenger, any VPN software, or just about anything that runs in your system tray (down by the clock)  try removing things from your startup folder and setting programs not to start when windows starts.
You can also shut down these programs from the run menu by running the msconfig command...but I suggest you research what you're turning off before you try that...as you could disable wanted processes,
Hope this helps.
Posted on Oct 12, 2007
Jam to runny fruit going to the top
Not enough sugar.
Too much liquid.
Not boiled long enough.
Not enough Pectin in the fruit, so you need to add it.
Fruit will always float to the top. Strawberry jam suffers with this a lot.
You can fix by re-boiling and adding pectin.
Some links for you
5 Ways to Thicken Homemade Jam ' Kitchn
www.thekitchn.com/5-ways-to-thicken-homemade-jam-234749
  1. Cached
Sep 2, 2016 - Just wait. You've followed the recipe to a T and even tested the jam for thickness by smearing a bit of the cooked jam on a cold spoon straight from the freezer, but it still looks runny in the canning jars after processing. Add chia seeds. Cook it again. Add pectin. Cook it in a low oven.
How to Fix (or Remake) Jam or Jelly That Turns Out Too Soft or Runny
www.pickyourown.org/how_to_fix_runny_jam.htm
  1. Cached
  2. Similar
If your jam or jelly turns out too soft or runny, don't despair, and don't throw it away! It can be fixed! Here's how! If the jam is too thick, before you put it in the jars, just heat 1 or 2 cups of grape juice (or any other fruit juice of similar or neutral taste, like apple or white grape) to boiling.
Jam Making 101: The Secrets to Getting Jam to Set Like a Pro ...
www.seriouseats.com/2014/08/jam-making-101-pectin-sugar-gel-point.html
  1. Cached
  2. Similar
Aug 25, 2014 - If the jam is still too runny, just keep cooking it and performing the frozen-spoon test every 5 minutes until you achieve the consistency you want ...
Jam too runny Google Search
Aug 14, 2017 | Cooking
Need admin password for my acer lap top
Open it and remove the coin chaped batter to for some minutes to clear the hardware password.
If it is Windows login admin password it wants, just reinstall Windows.
Jan 15, 2014 | Office Equipment & Supplies
How to fix frozen mouse on Toshiba Lap top
I am not sure if you are using the built in keypad mouse or an external, if you are using an external and you are having issue, you might be having problem with the update driver if you installed SP1 on your computer, the first thing to try is another USB mouse, than can work 10 seconds after plugin it in, and you do not need to reboot.Tony
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Feb 10, 2013 | IBM ThinkPad T20 Notebook
Trio t2810c screen frozen
Look at the top of the unit. There is a small silver dot. This is the reset button.Push on it with a pin head or a stylus. It will return the screen to the main menu. Hope this helps.
Dec 25, 2011 | Mach Speed T2800 MP3 Player
I have a Tv Philips model 32PW6506/01 few minutes after that is between 10 and 20 minutes go stand by, then if I press p + start and after 10,20 minutes and goes into standby ...If anyone knows about...
Good day!
Usually that problem is cause of the failing capacitors on the power supply section.
You have to do is open the back cover of your TV and look for the actual image of the capacitor with in the power supply section if it is leak/bulged on the top.Please replaced it with the same type,ratings and value.
Thank you and good luck.
May 08, 2011 | Philips 32PW6506 32" TV
My lap top is hp pavillion dv6000 . after 5 minutes I turn it on the fan starts working and about 25 minutes later it turns off by itself as a kind of protection because it gets hotter
Is this Question or Solution?? and about fan.. Usually when you switch on you pc all the hardware gets initialized and after a while when CPU fan or Power supply fan functions on the basis of inside temperature.As per the temp it will become slow sometime stop and again will start??
Sep 18, 2010 | Computers & Internet
My toshiba lap top keeps displayin the message "the installed program cannot start . click the ok button to turn off the computer . nothing has been installed . cannot load the lap top .
Apr 29, 2010 | Toshiba Satellite A200-0ET00X Notebook
Blue screen with HP Logo is frozen on my lap top screen
try contrl alt del at same time hold for 5 sec if that does not work take batt out hope this helps
Oct 16, 2009 | HP Pavilion dv9000z Notebook
On hold for geek squad at NY Midtown store for over 22 minutes
Complain LOUDLY and REPEATEDLY to a supervisor and never take it back to the Geeks!!!! Not only are they slow, they're expensive too!!!!
Jul 07, 2008 | HP Pavilion dv6000z Notebook
Slow connecting to the wireless network
HELLO. TELL ME THE COMPUTER YOU HAVE ON THE SAME WIRELESS NETWORK.! AS YOUR NEW LAP TOP.!!! IS IT A HOME TOWER.? OR DESK TOP.? OR A NOTHER LAP TOP.? AND TELL ME WHO IS THE ROUTER MADE BUY.? WHO IS THE SERVICE THAT IT CONECT'S TO.? TELL THESE THING OK.?AND WE WILL GO FROM THERE. OK.!!!
Mar 03, 2008 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
Computers & Internet Logo
21 people viewed this question
Alun Cox
