Question about Boating
Minn kota talon cable broke - Boating
5 Suggested Answers
Editor925
  • 285 Answers
SOURCE: Removing Prop
There should be a retainer nut accessible at the rear of the prop (in the center of the prop. Remove this and the prop should slide off.
Posted on Mar 15, 2009
  • 10 Answers
SOURCE: Where can i get a circuit board for my minn kota
http://www.northlandmarine.com/MinnKotaQuickRef.htm
You need your serial number of the trolling motor, length of shaft, and thrust poundage.
or you could call Minn Kota direct and give them the same information at 800-227-6433.
Posted on May 02, 2009
SOURCE: How do you program extra Minn Kota® CoPilot Replacement Transmitters?
According to my user manual
To learn the ID number of additional remotes, follow these steps:
1.) Press and hold the LEARN button located on the side of the receiver (receiver will emit a continuous tone). A small blunt object must be used to depress the LEARN button (pen or screwdriver).
1.) Press any button on the remote (receiver will beep 4 times confirming that it has "learned" the ID number of the remote and that the programming is valid and complete).
Posted on Jun 04, 2009
SOURCE: I need Minn Kota Power Drive operators Manual
I'm installing a Minn Kota Power Drive 70# on my Crestliner Fishhawk. I understand the 24 volt system. however the boat has 2 black, an orange and a red wire running to the batteries. I know black to neg. but where do the orange and red wires go.
Posted on Jun 28, 2009
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    WHO STOCKS A 2991251 CABLE FOR A MINN KOTA
    Sherry, I think there may be a new Minn Kota part # . Check the attached links. Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    Minn Kota Power Drive Non Auto Pilot Coil Cord Assembly 2991283
    Minn Kota Trolling Motor Part COIL CORD STRN RLF PD48 54 2991283
    http://minnkota.com.au/wp-content/uploads/2014/07/55-PowerDrive.pdf
    Can get replacement parts for my Minn Kota trolling motor FAQs
    Apr 13, 2016 | Minn Kota Boating
    HAVE A NEW MINN-KOTA TALON. FIRST TRIP OUT, EVERYTHING WORKED AS ADVERTISED. SECOND TRIP, ALSO OK. THIRD TRIP -TALON WANTS TO KEEP DEPLOYING CONTINUOUSLY INTERMITTENTLY. CAN ONLY GET MOTOR TO STOP...
    I have had two of the earlier model Minnkota Talons and both have done the same thing you described by not shutting off when deployed. I would have to hit the up button to stop it. MK knows of the issue and I was told there are upgrades to fix the issue. It is either the board or the clutch. My second Talon is in the shop now for the free upgrades. MK customer service has been great.
    Jun 11, 2011 | Sport & Outdoor - Others
    My Johnson Escape boat w/ Minn Kota engine stopped running
    I've had the same problem. It steams from the control panel. I took and ran a seprate ground wire directly to the motor. This is simple to do and takes 15 minutes. Starting in the battery compartment feed cable into the split-loom and continue feeding until reaching the control panel. Pull an extra 5 foot of cable and open dry hatch in rear by motor feed cable around and out to motor connections., Good time to replace rotary switch and circuit breaker. These also are trouble-some parts.
    Aug 01, 2010 | Minn Kota Boating
    Minn kota will turn on and off with remote, but will only turn 1" to each side.
    take off the top cover on the head of the motor and see if there are any restrictions to the movement of the cable. it may be the cable itself is rusted internally and may need replacement. call min kota on the 800 number on the motor for prices for any patrs you may need.
    May 28, 2010 | Minn Kota Riptide Sp Saltwater 70 Bow...
    Broken plastic on minn kota steering cable
    Hi!
    Here's a schematic:
    Edge 40
    My guess is you need key# 80 (part# 2232360 cable drum pulley)
    Good luck in your repair!
    Mike
    Sep 19, 2009 | Minn Kota Edge 40 Freshwater Bow Mount...
    I cant adjust foot tension on minn kota edge
    Hi!
    Flip the foot pedal over and tighten the set screw where the cable enters, this should help out.
    Here's a schematic:
    Edga 40
    Best of luck!
    Mike
    Jun 06, 2009 | Minn Kota Edge 40 Freshwater Bow Mount...
    Overheated Minn Kota Endura28
    This sounds like a fairly big deal. You need to check it water got into the motor. Turn it upside down and see if water comes out of the handle end of the motor. This may be a shop deal.
    May 31, 2009 | Minn Kota Endura 30 Freshwater Transom...
    How does the minn kota 65 all terrain run on 24
    You should only run the motor with a 24v battery or two 12v batters 'jumped' out. To jump the two batteries, connect the positive on one batter to the negative on the other battery and hook the trolling motor battery cables up to positive and negative terminals that are NOT jumped out as you would normally. Don't run this with 12v as you will have serious problems if you do. They do not make a 65lb thrust in 12v - too much pound thrust to run off of 12v.
    Feb 22, 2009 | Minn Kota Endura 30 Freshwater Transom...
    Boating Logo
    346 people viewed this question
    Top Boating Experts
    Steve
    Steve
    ray gallant
    Andrew Taylor
    Andrew Taylor
    Are you a Boating Expert? Answer questions, earn points and help others
