Question about Video Game Consoles & Games
I have lost 4 games from spintop games from my computer and wish to restore them,; would you advise me how to do this.
The above games were erased from my computer during repairs and I would like to now how to retrieve them. They were purchased some time ago and I don't have the emails that were sent, but I do have the order nunbers and the activation codes for them
SOURCE: activation
that's fine. thanks
Posted on Jan 02, 2009
yooperbud
  • 8637 Answers
SOURCE: Wish to activate webcam for a newly purchase HP dv-7 Pavilion PC
Normal 0 Probably has corrupt driver.
Try disconnecting the Camera from the USB port and reinstall the CD software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Posted on Jan 30, 2009
  • 59 Answers
SOURCE: dishwasher purchased 8 years ago, $200 repair 4
For what you pay for dishwashers its normally better to replace them
Posted on May 01, 2009
  • 4 Answers
SOURCE: I have microsoft home edition CD & activation code,but lost KEY
76445-OEM-0011903-00109
Try this and let me know whether it works or not
if this is not rhe key then i'll serch another for u.......
Posted on Jul 15, 2009
ZJLimited
  • 17970 Answers
SOURCE: 1998 chevy cavalier,2.2lit. standard tranny.
This code is for FTP (Fuel Tank Pressure) being too low. This can be caused from a defective gas cap. I would start here then work my way to the fuel pressure tank sensor. Check this information and visit the link in the last lines. The solution isn't just delete the code, need to check the sensor and fix the problem, if not, the code pop-up again.
P0452 - Evaporative Emission Control System Pressure Sensor Low Input
An excessively low voltage from the sensor is sent to ECM.
The EVAP control system pressure sensor detects pressure in the purge line. The sensor output voltage to the ECM increases as pressure increases. The EVAP control system pressure sensor is not used to control the engine system. It is used only for on board diagnosis.
Symptoms: Engine Light ON (or Service Engine Soon Warning Light)
Possible causes:
- The EVAP control system pressure sensor circuit is open or shorted
- EVAP control system pressure sensor may be faulty
Possible solution:
- Retight gas cap - Replaced EVAP Control System Pressure Sensor
Check this procedure to diagnostic and solve it: DTC P0452 Diagnostic
Hope this helps.
Posted on Mar 16, 2011
Erase my photos by mistake from my phone
So which kind of phone are you using?
If you are using an iPhone, I can help you figure it out.
Way 1: retrieve pictures from iPhone with iTunes backup file
1. Connect the iPhone to the computer with a USB cable.
2. Open iTunes.
3. If you have a new or erased iPhone, iTunes will prompt you to restore from backup.
4. Otherwise, Control-click on your iPhone under DEVICES in the left menu.
5. Select Restore From Backup...
6. Choose the backup you wish to sync and click the Restore button.
Way 2: recover photos from iPhone with iPhone data recovery program.
Read more: how to retrieve deleted pictures from iPhone with Macgo Mac iPhone Data Recovery
May 10, 2014 | Cell Phones
I need the unlock code for the PC game,Sniper Ghost warrior
http://www.spintop-games.com/
u can use above link
Feb 27, 2011 | Computers & Internet
My Ps3 wont load the dashboard help
Please try the following solution to fix your PS3. Please note, option 5 will erase your hard drive so any save games you had will be lost.
Step 1.
Turn your Playstation 3 off into standby mode (red light on)
Step 2.
Press and hold the power button. The Playstation 3 will beep when you first press it, then beep again 5 seconds later and then beep once more and turn off back into standby mode (red light on). You must now release the power button.
Step 3.
Press and hold the power again. The Playstation 3 will beep when you first press it, beep again 5 seconds later then there will be 2 quick beeps together. When you hear these 2 quick beeps release the power button.
Step 4.
Your Playstation 3 will now start up with a screen asking you to connect a controller via USB. Connect your controller and then press the PS button.
Step 5.
A menu will now be displayed on screen. Select option 3 "Restore File System". This will then ask you to confirm that you wish to go ahead with the system restore. Accept whatever the Playstation 3 says.
The Playstation 3 will now go through the system restore process and re-install the system software back to out of the box status. If it still does not work try the above but choose option 4. If that does not work try option 5 as a last resort, this will erase the hard drive.
Once you have completed the above, the Playstation 3 should restart and spring back to life again!
I hope this helps all of those out there who are suffering this problem.
Jan 28, 2011 | Sony Playstation 3 (PS3) Console
When i power on the ps3 it dosnt go past the first 'wavey' screen n dose not go to my home screen just stays on the 'wavey' screen
This is a problem with the Playstation 3 software becoming corrupt. It is very easy to fix if you follow my simple steps.
Please note, using option 5 will erase your hard drive so any save games you had will be lost. All your on-line trophies will be preserved.
Step 1.
Step 2.
Step 3.
Step 4.
Step 5.
The Playstation 3 will now go through the system restore process and re-install the system software. Once you have completed the above, the Playstation 3 should restart and spring back to life again. If it does not, do the above but choose option 4. If this does not work do the above again and choose option 5. Option 5 will format your hard drive.
I hope this helps and thank you for using FixYa
Lost password
If you have lost Windows login password, then I would advise a full system recovery.
You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
Thanks and regards,
Jitha
Nov 23, 2010 | Acer Aspire 5315-2153 Notebook
My ps3 erased itself. I lost my friends list and memory.. Any advise?
You should be able to retrieve your trophies when you sign in.As far as friends list and Actual memory,if you did a system restore or deleted an account then that is lost.
Mar 19, 2010 | Sony Playstation 3 (PS3) Console
Have simple tech 320bg , backed up files using the onboard software.... files show up and I can actually move them back up to new computer but.... can't read file (ext = NBP/NBZ file) also looks like I...
Sorry, best I can do is advise next time don't use the backup/restore s/w that came with the drive. I own the same one and found Windows Backup works flawlessly. In fact, if files are still on orig computer, re-back-them-up using Windows Backup and restore to new machine same way.
Apr 24, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Ben 10 DS Lite Game
Sorry man but if there erased you cant get them back
Jan 05, 2009 | Warner Bros. Interactive Looney Tunes Duck...
Video Game Consoles & Games Logo
35 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
