I have oil coming from under my 2003 ge profile washer agitator. How can I fix this?
Leaking oil into the washer drum, ruining clothes.
    Sergeant:
  • 291 Answers
The oil is coming from the transmission and it means the transmission assembly must be changed. There is no way to fix it other than replacement. Sorry. It's a big job, but there are plenty of videos on line now that show step by step how it's done. Let me know if you are interested in doing it yourself.
Posted on Jan 20, 2013
huuum
  • 750 Answers
SOURCE: Maytag Atlantis black oil like residue and can't remove agitator
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
this is a very common happening and it means
This usually means that a seal is degrading or dissolving.
This washer is a top loader, Right!
I believe it calls for HE ( High Efficient) laundry detergent.
If we use to much of either it will cause this !
This usually happens due to using to much detergent or bleach.
You said, Black oil like residue discharged from washer during use. Stain clothes, almost impossible to remove. Loosened nut on agitator but it will not budge, and am afraid of damage if I try to pry between agitator and bottom of drum.
Please remember to leave a rating before you go!
Thank you
Posted on Sep 28, 2008
SOURCE: clothes stuck under the agitator
The clothes do not go under the plate they spin out of the top and fall over the side, this is because socks and underwear are either overloaded or spun out, this can be solved by reducing the load size and also spinning small clothing items on lower speeds, but the solution above is very helpful for getting the clothes out, but you will need a long pair of needle nose pliars to pull the clother out of the bottom of the tub. This problem presented itself by a "LD" error (long drain) Thanks tzweeb and I hope this helps others
Posted on Jan 09, 2009
kram26
  • 544 Answers
SOURCE: washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
Posted on Mar 29, 2009
SOURCE: GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
Posted on Apr 15, 2009
SOURCE: GE Profile Washer leaking underneath during spin cycle
its your outer tub it has a hole in it
Posted on May 13, 2009
Grease leaking into drum under agitator cone
Remove the agitator cone. There will likely be a removable plastic piece with an O-ring. Oil could be leaking out of the O-ring into the washer, and water could be leaking into the bearings. If there is damage to the O-ring replace it, or if there is a bunch of schmag that is compromising the seal, clean it out, and re-install everything. This solved the problem in my washer; hopefully it works for you.
Sep 28, 2009 | GE Washing Machines
Leaking grease
All washer machines have a "transmission" - just like a car these units have oil in them and when the seals that protect the oil from going to our clothes is breake, oil finds its way to your clothes.
Transmission needs to be replaced.
Aug 18, 2009 | GE Profile WPRE6100G Top Load Washer
How do you remove the nut under the agitator? Ours is leaking gear oil from bearing under agitator. Have the agitator off. GE WBSR3140DW
theres nothing under your agitator, first take cover off your agitator there should be a small bolt
holding it down, take that bolt out then grab agitator from bottom and pull up it should come off easy.
Jun 09, 2009 | GE WBSR3140DW Top Load Washer
Washer will not agitate or spin
HI,
thanks,
Mar 29, 2009 | GE Profile WPRE6100G Top Load Washer
Leaking oil from the bottom of the machine
Hi, Your problem is quite terminal, but easy to fix. You will need to replace the gearbox in the machine will cost around £150.00.
Mar 07, 2009 | GE Profile WPRE6100G Top Load Washer
Clothes coming out with stains they didn't have - looks like oil/grease
Front load greasy residue ,
Due usually to much detergent in each load, use smaller amounts.
To much detergent degrades the rubber seals and gaskets and rubber seal also in some front loaders around the door too!
Over the life of a front loading washer the seal/gasket degrades
largely due to the chemicals in the detergent as well as bleach.
Most gaskets/seals get hard and brittle therefore the over the life of a front loading washer
the seal/gasket degrades largely due to the chemicals in the detergent as well as bleach.
....please rate this ....thanks
Sep 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
GE Profile washer
suspect gearcase ask for estimate first..could be more than new washer
Jul 09, 2008 | Washing Machines
Leaves
with the exeption of something you mistakenly left in your clothing and wound up in the washer, not likely stains are from there , most of the time they do come from the dryer, try grabbin an old white rag nad runnig it around hte fron of hte dryer drum and then tyr the rear where the drum meets the back bulkhead. usually leavs brownish streks smome what curved 2-3 inches log. its from hte felt hte supposed to seal the drum. its either wearing thin, or a glide has worn away causing the issue
Mar 22, 2008 | Whirlpool LSR7333 Top Load Washer
HELP GREASE RUINING CLOTHES IN WASHER
over 5 years or cost over 250?
 throw it away, and get a Whirlpool
Oct 21, 2007 | GE Profile Prodigy WPSE4200A
Washing Machines Logo
Top Washing Machines Experts
