Question about Panasonic KX-TG2740 Cordless Phone
Kxtg270s lights flashing on home unit. Nothing works.
Philips htl2100/12 soundbar doesnt respond to remote control after plugging in
My soundbar won't power up. So I pull the battery out of remote, press a few buttons, put the battery back in and all of a sudden the device can be powered up and controlled. Until next time it stops responding. I replaced that original battery with a new one but the problem still persists.
Dec 10, 2013 | Philips SoundBar DVD Home Theater with...
Green timer light won't stop flashing on mitsubishi ws 73711.
the green light blinking is normal if set has been unplugged--when set is plugged back it should blink for about 70 seconds and then go out--then you can try to turn it on---it is the DM unit inside the set booting up.
If the light just blinks and never stops you have likely bad caps in the DM unit---there are kits available for that.
The other possible reason is that so called reset switch may be bad--fairly easy way to find that out and it is more common than you would think, let me know if you have questions.
SD TECH
May 06, 2012 | Mitsubishi WS-73711 73" Rear Projection...
TomTom Go 630 malfunction
re install/repair the software
May 04, 2009 | Tomtom Go 630 GPS Receiver
Sony DAV-C770 Red Light Flashing but nothing is on!
power supply or power amplifire unit problem.give it to repair proffesional.
nuwan.
Jan 19, 2009 | Sony DAV-C770 System
Operation light and timer light blink 5 times?
I don't know if this is the proper technical solution or not but my unit was having the same issue. I cleaned it checked fuses made sure the cover was properly in place and nothing worked. As a final thought I went to the home fuse panel and tripped the breaker for the unit, waited about 30 seconds and turned it back on. I did this with the unit set to off. When I came back and turned it on, it is working properly with the operation light solid red.
Dec 13, 2008 | Fujitsu 18C1 Air Conditioner
Remote stopped working
already tried a new remote and new batteries. bose says the ir bulbs need replacement so i'm taking it in. shucks.
Dec 23, 2007 | Bose (321GS) System
Canon EOS 1000F in-built flash unit
Set camera body for Internal Flash for Pop-Up Flash.
Set camera body for External Flash for parked flash on Hot Shoe.
atdlee@netzero.com
Nov 08, 2007 | Canon EOS-3 35mm SLR Camera
Nothing works, only flashing program light and time
listen to this! we called Cuisinart at 1-800-726-0190 and they are going to sihp us a replacement coffee maker and all they are going to charge us it the price of shipping. good news since spending so much for a product. great customer service.
May 28, 2007 | Cuisinart Thermal DGB-600 Grinder
Panasonic KX-TG2740 Cordless Phone Logo
82 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
