I removed my SD card from my laptop after downloading my pictures. When I placed the SD card into the the camera, it wouldnt let me take pictures and a message on the display screen says: SD memory card locked". Please help, thank you!
SOURCE: Sony Cyber-Shot DSC-w5 "MEMORY Stick LOCKED" ??? please help!
take your memory stick out of your camera and theres this sliding thing on the back...slide it so that its not on the lock side? does that make any sense? well..good luck!
SOURCE: "Turn the power off and on again" error message
I just had the same problem and I didn't know what to do and I found this post it was somewhat helpful. After I read this I disassembled the camera and I pulled out the lens cover up a bit its held by this white plastic inside be careful not to pull to hard because it looks like it could break easily. After I got the lens cover a little bit above the lens itself I powered it up and the lens MOVED! I tested it again and it worked. So I placed the lens cover back over the lens. And it all back together. It was a really quick fix it took me less than 10 minutes. I hope this is helpful to anyone that gets "Turn off the power off and on again" error.
SOURCE: unable to see pictures on my sony dsc t70 memory card
Try connecting MS directly to the PC (Via an adapter, if necessary)
SOURCE: Nikon D40X quit working - memory card access lamp flashing??
As per the Samsung digimax range, internal memory seems to be faulty. Insert an external memory card and try to power up the camera.....
SOURCE: My camera screen is black. I have charged it and
if there is no picture at camera mode so in this case your camera ccd ic is out of order please go to your nearst sony service centre & fix this problum
I solved it! My SD card has a little tab on the side the sided to "lock". I must of moved it by accident. Found the solution on ehow.com
Thank you!
