Question about HP Pavilion 515n (DC471A#ABA) PC Desktop
How do I increase FSB past its factory preset in my HP Pavilion 515n pc?
  • HP Master
  • 27,725 Answers
Some people, when their computer reaches the point that it can't run the programs it once used to, decide to toss their machine and invest in a new one. Others squeak out some extra life by overclocking their processors. While this is ideally done with hardware, for pre-built HP computers you will have to use a software option. With this minor exception, the process is still a breeze.
Download and install CPU overclocking software, such as ClockGen, SetFSB or SysTool (see Below). http://files.extremeoverclocking.com/file.php?f=189 http://www.softpedia.com/get/System/Benchmarks/SetFSB.shtml http://www.techpowerup.com/systool/ While all these programs more or less work the same, for this guide we will be working with ClockGen. Boot the CPU overclocking software. Do not be alarmed if your computer momentarily slows down, as the software is reading your CPU's clock speeds. Click "PLL Control" or the equivalent in your overclocking software. This will show you several sliders for your front-side bus (FSB) and, in many cases, your PCI cards. Adjust the FSB slider. Be sure to do this slowly, as the processor will likely fail if there is a sudden speed change. For best results, use the arrows to slowly adjust the settings by one-to-two megahertz at a time. Click "Apply" frequently to set the speeds. Hope this helps.
Posted on Jan 21, 2013
frankzjm
  • 191 Answers
SOURCE: HP pavilion 515n runs real slow
you may consider follow:
1) you need to make sure your system slower than before the reason that should be excepted some windows system file damage or never clean disk fragile files and clean temp files
2) your PC max ram size is 1G (two sockets), now you have 256M+512M two ram sticks, so you can replace the 256M with 512M ram stick, you should make sure new ram should be same model as your original one.( your ram model is PC2100)
is this helpful or fixed your slower running?
Posted on Feb 15, 2009
saumyar
  • 174 Answers
SOURCE: loud fan noise
have one very similar, they only have a fan in the power supply, and a small, small fan on the CPU. If it's the fan in the power supply making the noise, some people would say replace the whole unit, some would say replace the fan. I would replace the fan, but if you don't want to take the risk of getting electrocuted, that's probably a great idea. A power supply can be found somewhat cheaply, but one that fits those cases might not be quite as easy.
Posted on Jun 09, 2009
  • 33 Answers
SOURCE: what replacement backup battery does the pavilion
Hi, most motherboards that I have fixed etc... have used the 3.0V CR1620 Button Cell Battery which is easily available and cheap!
Posted on Jan 05, 2010
SOURCE: I need the wiring diagram for replacing the power supply for a HP Pavilion 515n
You don't need a wiring diagram. Just pay close attention to where things are plugged in while the old power supply is still in the computer once you remove the case. There are only a few connections and some of them will only fit in the correct slot on the motherboard. For example, the main power to the motherboard will be the largest connector, then you will have a connector to the hard drive, the dvd/cd drive, etc. What you could do it take a piece of masking tape and and fine tip marking pen such as a Sharpie and write where that wire is being plugged into the motherboard. Then when you remove it and put the new power supply in, just refer to where the plugins go based on what you marked on the old plugins. There will also be some plugins that go nowhere. They are there for future expansions and upgrades that you might do.
Posted on Mar 14, 2012
alxz
  • 89 Answers
SOURCE: My HP Pavilion 515n pc will not restart without pressing the F2 key, why?
Message was "press F2 to continue". This happens when there are errors in the boot up process like:
CMOS settings incorrrect
Date/Time incorrect
Missing drive
First to replace should be the CMOS battery inside the computer.
Posted on Nov 26, 2012
I have a hp pavilion 515n desktop computer and was wondering how to get the password for the wifi.
Hi Ettajean,
The wireless password can be located either on the wireless router itself (if it's being provided to you by your ISP), or you'll need to log into your router to view/change your wireless password.
If you've connected to the wireless router before and simply need to recall the password, you can view it inside of Windows:
http://www.microsoft.com/surface/en-ca/support/networking-and-connectivity/how-to-find-your-wireless-network-password
If you can post the model number of your router, I can provide you with some additional direction.
Hope this helps!
Mar 01, 2015 | HP Pavilion 515n (DC471A#ABA) PC Desktop
Jan 20, 2013 | Computers & Internet
Date/Time incorrect
Missing drive
Nov 25, 2012 | HP Pavilion 515n (DC471A#ABA) PC Desktop
I cant get a microphone to work on my computer
Download bios update from the HP support website. Install it on your computer. That should work.
However, if you could give me more information, I will be able to help you more.
BIOS UPDATE .
Dec 19, 2010 | HP Pavilion 515n (DC471A#ABA) PC Desktop
Does the HP Pavilian 515N have a restore to orignal settings installed on the harddrive?
Generally HPs do have a factory restore. START, search for RESTORE and it should find the utility if there is one.
Aug 04, 2010 | HP Computers & Internet
How do you get the roller out?
I dont know if I have U correctly here.. but if I think what ur trying to ask here.. then click the following link for detailed instructions.. http://tinyurl.com/RollerOut
Jan 29, 2010 | HP Pavilion 515n (DC471A#ABA) PC Desktop
What replacement backup battery does the pavilion
Jan 05, 2010 | HP Pavilion 515n (DC471A#ABA) PC Desktop
Loud fan noise
Jun 09, 2009 | HP Pavilion 515n (DC471A#ABA) PC Desktop
Can this HP access internet wirelessly?
you need to add a wireless card inside your computer or else you can stick in an external USB wireless in one of your USB slots. then you will be good to go.
Jan 27, 2009 | HP Pavilion 515n (DC471A#ABA) PC Desktop
How can I find out if my HP 515n already has card for wireless?
To see what is installed on your windows XP machine.
Right click on "My Computer". Left click on "Manage". When the window pops up left click on "Device Manager".
This list will show you what hardware is detected by the Operating System.
Hope that helps.
Please rate me.
Thank you
HP Pavilion 515n (DC471A#ABA) PC Desktop Logo
126 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
