Question about Sharp R-1480 Microwave Oven
Sharp model R-1870 Carosel quits cooking at 59 seconds
Regardless of the setting the Sharp R-1870 stops at 59 seconds
  • 1 more comment
  • geneg935 Apr 26, 2009
    I have the same problem and have even called Sharp to see if they had had a recall or any other complaints for the same problem. The answer was no. It is interesting to hear someone else has this same weird problem with their microwave.
    I have the same problem joekochis's has with his Sharp model R1870. When I click where it says to click here for see manual it shuts the system down. I don't want to order a switch until I can check whether I can find the switch and how to install it. Thanks.
  • geneg935 May 11, 2010
    when i try to look at the service manual it shuts down the internet connection. I'm not sending $5 to someone for a switch if I can't see where it is susposed to be installed.
  • Sharp Master
  • 9,086 Answers
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample photo for a typical damper assembly.
We have the applicable service manuals for these models and have uploaded it to our site here and here to help you. You will need the free Adobe Reader to view or print it.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Posted on Jan 29, 2009
Microwave oven stops after 59 seconds
This is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding.
Sharp-made models stop after 59 seconds.
See the attached sample drawing for a typical damper assembly.
If a switch is all you need, we offer a universal type for only $7.50 postpaid which you can order here.
Oct 06, 2011 | Sharp R-1870 Convection/Microwave Oven
The microwave stops after 50-60 seconds regardless of the amount of time left on the panel
The PCOR30 microwaves are essentially a rebranded Sharp R-1870-series ovens.
The service manuals that cover these models are here:
http://www.microwavedisplay.com/r1874_sm.pdf
http://www.microwavedisplay.com/r1870_r1871_sm.pdf
http://www.microwavedisplay.com/r1850_r1851_sm.pdf
The above manuals will not have Sharp part numbers, not the Dacor part numbers, but they should work, and you can order them from
the Sears Parts Directimage-4235112-10659157 site.
But if you're leery or unsure, you can look up the Dacor part numbers in the part list here, then order by part number from the Pros here.
Jan 01, 2011 | Dacor PCOR30 Convection/Microwave Oven
My Sharp micro will stay on for 59 seconds and shut off no matter how long the timmer is set. Sharp model r 1870 It does this every time it is used . The control board has been replaced.
This is not a problem on the board, it is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding.
We have the applicable service manuals for these models and have uploaded them to our site here and here.
Dec 17, 2010 | Sharp R-1870 Convection/Microwave Oven
The microwave will only work for 59 seconds then it stops. It is working but only for 59 seconds. I am not sure about the convection oven was afraid to try it. The unit is in our fifth wheel RV. I can heat...
We have the applicable service manuals for these models and have uploaded them to our site here and here to help you.
Apr 18, 2010 | Sharp R-1870 Convection/Microwave Oven
It turns off precisely at each 59 seconds on all cycles Thanks !
On the hunch that you have a model R-1870, we have the applicable service manuals for these models and have uploaded it to our site here and here to help you.
Otherwise, you can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
William E. Miller
prototech@usa.net
Jan 15, 2010 | Sharp R-1870 Convection/Microwave Oven
Sharp Carousel II Convection Microvave R-3850
My sharp microwave convection oven (R-1870) runs for 59 seconds and stops. If I push start it runs for another 59 seconds and stops. How can this be fixedd?
Aug 29, 2009 | Sharp R-1870 Convection/Microwave Oven
Sharp r-1870 shuts off after 59 sec
Most computers will open this document automatically, but you may need the free Adobe Reader
William E. Miller
prototech@usa.net
Jul 13, 2009 | Sharp R-1870 Convection/Microwave Oven
Wow. I just read something ridiculous!
Well, never mind that, here's your solution:
This is a common problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
Jan 26, 2009 | Sharp R-1480 Microwave Oven
Sharp model 1870
The best place to order Sharp parts is Tritronics.
If you only need a switch, you can order one from us for $5 postpaid.
William E. Miller
prototech@usa.net
Aug 08, 2008 | Sharp R-1870 Convection/Microwave Oven
59 Second shut off
The damper is a door inside (on the right side in your model) that opens or closes depending on cooking mode. If the controller thinks that the door is not in the right position, it will shut down the cook cycle in 59 seconds.
See the attached sample photo.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We have a partial service manual at our site here.
You can usually find a Sharp exploded view by entering your FULL model number here: http://www.searspartsdirect.com
You can order Sharp parts there or from Tritronics at http://www.wehaveparts.com.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 26, 2008 | Sharp R-1870 Convection/Microwave Oven
Sharp R-1480 Microwave Oven Logo
400 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
