Question about Alpine MRD-M500 Car Audio Amplifier
Alpine amp mrd-m500 reads 0 amps and no sound
5 Suggested Answers
Cerfer39
  • 709 Answers
SOURCE: alpine mrd-m500
Hi SPDGOD,
Could not find exact, but close manual.  It is the MRP-M450 mono block amp from alpine.
Go to this url and view in Adobe. Print it if you need to
http://vault.alpine-usa.com/products/documents/OM_MRP-M450.PDF
Posted on Oct 19, 2007
  • 631 Answers
SOURCE: alpine mrd m500 amp is not pushing my 12 in infinity sub
If you have a dual voice coil sub, make sure that you have the positive and negative terminals connected properly. If you have ONE of the coils wired backwards, it will cause the speaker to produce little or no sound.
Have you set the gains properly?
Are you sure the amplifier is receiving a strong signal from the head unit?
Have you tried it with a different speaker?
Posted on Jul 19, 2008
  • 152 Answers
SOURCE: Alpine MRD-M500 Amplifier
That is a code to inform you of an issue, and to help direct you to a particular area of concern
HOT & E-1 = both for heat issue
E-2 = for a voltage issue
E-3 = for a current issue.
While yours is a current issue, that reflects a problem with your input or output signal pairs. You should disconnect the subs at the amp, then operate the unit as normal to see if the code reappears. This is the start of your process of elimination, where as you will be able to determine the general location of the issue, weather it is before - internal - after the amp, hence If after the subs were disconnected, the code did not return then it would be obvious that you should focus on the subs and their signal pairs. troubleshooting in small increments until the issue is discovered.
Hope this helps...Good luck
Aduz
Posted on Mar 27, 2009
  • 21 Answers
SOURCE: amp powers up and reads 14.4 volts... 0 amps.
Check to make sure amp is not in safe mode, you can turn this on and off in the menu.
Posted on May 24, 2009
Ok i got a mtx 12' 500 sub matched to a alpine mrd-m500 mono amp. The deck powers the 4 speakers, as i turn the volume up on my deck (alpine cde 100) the sub/amp cuts out at around volume 20-22 and E-3...
Sorry,after rereading your problem,I gave a wrong answer.Do you have the deck sub RCA pre-amps connected to the amp,then the wires from the amp to the sub?If you do,you need to check what the sub and amp are rated as such as,peak or rms.They are 2 completely different meanings.Greg
Feb 11, 2011 | Alpine MRD-M500 Car Audio Amplifier
Can i use a MRD-M500 for voice on my tweeters
not a good idea-its made to run bass- plus its a mono amp- so you would lose stereo separation-but if your mind is set on it....do what you gotta do and good luck
Jan 09, 2010 | Alpine MRD-M500 Car Audio Amplifier
Amp powers up and reads 14.4 volts... 0 amps.
May 19, 2009 | Alpine MRD-M1000 Car Audio Amplifier
Aduz
Mar 27, 2009 | Alpine MRD-M500 Car Audio Amplifier
How to get amp status to come up on the screen of alpine d 310
you have to have an alpine kce-510m amp link module. You must also have a compatible amp, such as mrd-m300, mrd-m500, or the mrd-m1000. The amp link module plugs into the (ext) plug on the iva-d310 and the other end of the cable into an alpine kce-060m y-cable. The shorter of the y-cable plugs into the amp with the lowest id #.
Feb 11, 2009 | Alpine IVA-D310 Car DVD Player
How to unlock my alpine mono power amplifier mrd m500?
Hi. If you shorted (touched) the speaker wires together, or let them touch the chassis of the car, then it may have locked out. Just turning the amp off and back on will fix this, so it sounds like you have done damage to it. Most amps have a speaker relay which gives a click sound when you turn on. If there is no click, then it may have a power supply failure.
Mark
Oct 24, 2008 | Alpine MRD-M501 Car Audio Amplifier
Alpine mono power mrd m500 amp
Try switching the lowpass filter down to 80hz or lower, then adjust the bass boost to your liking.
Jun 28, 2008 | Car Audio & Video
Alpine mrd-m500
Hi SPDGOD,
Oct 19, 2007 | Alpine MRD-M1005 500W x 1 mono subwoofer...
My amplifier is plugged but doesn`t bring a sound why?
If your are certain that you have a signal going to the imputs of your amp and you are certain that the speakers are OK and you have not turned the gain control all the way down then that just leaves a fried amp. Good luck.
Mar 31, 2007 | Alpine MRD-M500 Car Audio Amplifier
Alpine MRD-M500 Car Audio Amplifier Logo
76 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
