Question about Water Heaters
Vaillant Eco max boiler not working with the thermostat controller
Hi, we have a vaillant ecomax condensing boiler positioned in the loft. We had a vrt340f thermostat controller on the wall below the loft hatch. This was working ok until the batteries ran out. We replaced them but since then the boiler seems to be ignoring the controller & only operating to low temps. The green light on the receiver was flashing suggesting a radio fault but nothing had been changed from before other than the batteries. I've had someone out to look at it & after reprogramming it which didn't work it was replaced with a salus rt300rf controller. Now after 2 days this also doesn't seem to be working. The set temp is 20 but it has gone to 18.5 degrees without coming on & then after increasing the set temp to 21 it has now gone up to 23 degrees! Is this new controller compatible or what else could be wrong? Thanks
  • 3 Answers
SOURCE: boiler light wont ignite
more likely the thermal coupling is u/s get new one fitted
Posted on Dec 02, 2008
SOURCE: the code E 13 comes up on the panel and it cuts out
Maximum temp exceeded on ntc1(thermistor),,,either clean out heat exchanger,power flush of my first option replace thermistor...
Posted on Feb 02, 2009
  • 30 Answers
SOURCE: vaillant 831 combi boiler timer help
check to see the time clock is set with the clock symbol. there are three settings on analog clocks I , O and clock the I setting is constant running, the O setting is off and the clock setting is timer.
also try setting the thermostat up higher to see if the boiler fires.
Posted on Mar 30, 2009
  • 4 Answers
SOURCE: vaillant eco tec pro 28 every time cold tap is
try reducing water pressure to cold tap and see what happens
Posted on Aug 04, 2009
mrhotandcold
  • 248 Answers
SOURCE: Vaillant boiler no heating or hot water
refere to manual check for override switch loss of pressure no problem re-pressurise and check for leak top of rad valve good place to start
Posted on Oct 11, 2009
Vaillant eco PRO 28 gas boiler stopped working
You need to replace the thermal couplerhttps://youtu.be/jDvo4yJ1OdE
Nov 26, 2016 | Water Heaters
Vaillant Gas boiler/furnace not firing up
There is a thermocouple heat detecter in the pilot flame clean it 240 sand paper is ok. replace if not working.
Oct 22, 2014 | Water Heaters
New Vaillant 360 eco plus boiler, takes almost 3/4s an hour for rads to come up to a decent temp. Hot water is fine. Called out install Engineer who is an excellent tradesman but he says everything
We have just had our old system boiler replaced with a vaillant ecotec plus 837 and sounds like a similar working operation to ours. At first I was a little concerned,but I was told by our installer that he was told by vaillant that these very latest boilers size the system on start up for about 10 mins, then take temperature to target flow which you set boiler at. So even by setting target flow temperature very high you still get the initial sizing cycle, which ours was about 30-35c temp. These boilers seem to run biased for efficiency as after a while they modulate the boiler burner down and the radiators run more on the side of warm than really hot like the old type boilers. You also get better efficiency as at lower temperature the boiler condenses better. You will also find you get a more constant temperature in your home rather than over shoots. I was concerned at first, shame there was no info/explanation in user manual as people do need to know that this is normal operation. We are used to ours now, took a month and by the way these boilers can make a creaking noise but was told this normal expansion/ contraction but annoying when sited in bedroom cupboard. Best of luck!
Oct 27, 2012 | Water Heaters
Vaillant boiler ECO Max 824E F 20 error
Did you bleed the air from the pump ? Sounds like a air lock
Jul 14, 2017 | Water Heaters
Hi my vaillant vcw gb 242 e is leaking from the
what do you mean from the radiator TEMPATUTE adjusting control ( thermosatic rad /valve) if so jurt replace valve
Aug 31, 2009 | Water Heaters
Vaillant combi boiler,dirty water comes out of hot and cold taps ,just been serviced by british gas,could you tell me the problem
Hi ,
Can you please tell me the model of the vaillant, and the approx age?
I can solve this problem
I await your reply
Thanks
Steve :)
Jul 16, 2009 | Water Heaters
Brand new valiant condensing boiler installed will not work
Valliant boilers have software that can be used to diagnose the unit. The software can be purchased at the plumbing supply house that the boiler was purchased from. You can also get tech. service by email as well. It sound like there is an issue with the electrical controls with it. Or the controls were wired wrong.
Technical enquiries 01634 292392 or technical@vaillant.co.uk
Apr 01, 2009 | Water Heaters
Vaillant 831 combi boiler timer help
Mar 25, 2009 | Water Heaters
The code E 13 comes up on the panel and it cuts out
Nov 11, 2008 | Water Heaters
Water Heaters Logo
187 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
