Question about Dryers
We need to know how to remove the access panel, the push to start button will only work if we hold it in. It is a kenmore elite electric dryer model 11064994300. Thanks!
    New Friend:
  • 5 Answers
Have u takin the back panel off I think u can get to all of it from there
Posted on Jan 21, 2013
catriver
  • 878 Answers
SOURCE: My Dryer will only work if I hold start button, when I release start button the dryer stops.
Anra, this is a classic symptom of a failed even heat board. I've seen a lot of these failures out there. Easy to change out. Check out this link. Catriver..post back http://www.repairclinic.com/0080.asp
Posted on Mar 26, 2007
jsrock516
  • 5911 Answers
SOURCE: kenmore elite he3 electric dryer
If you get a series of four rapid beeps when you push START in an attempt to start your dryer, your door switch (interlock) is defective.  I have experienced this problem before and it is a fairly simple problem to fix.  The easiest way to tell is to open the dryer door and push the door interlock in by hand.  Hold it in while pushing the START button.  If the dryer starts, then all you have is a simple problem of the door not closing properly.  If the dryer still does not start, however, replace the dryer door interlock.  The interlock should also make a definite "click" while pushing it in.  If it does not, the switch is worn out.  Some dryers have an upper and lower door interlock.  If yours is equipped with two interlocks, make sure they are both functioning and that the door is latched properly.  I have experienced problems where dryers doors with two interlocks would close at the top, but not at the bottom.  The dryer would not start as a result.  If you can provide me with your model number I can get a part number and price for you.  I can also tell you where you can get the part and provide instructions on how to replace it.  Let me know.  I hope this helps you.
Posted on Oct 31, 2007
SOURCE: removing front panel on kenmore dryer
I was able to fix my dryer on my own. the problem was, i was instructed to access an area that wasn't correct for the needed repair.
Posted on Mar 10, 2008
SOURCE: Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
Posted on Jan 26, 2009
maddogsteve1
  • 18 Answers
SOURCE: dryer won't stay on unless I hold the start button down. When I let go of the start button, it stops.
most likely the evenheat board is bad, but it could be the motor relay, get under the console and check the trouble shooting wiring diagram. there are several checks you can do to narrow it down.
Posted on May 25, 2009
Remove front panel
I have this same problem. The Sears Service Technician just left and said that my main panel needs replaced to a cost of $532.88! Needless to say I will be buying another dryer and it will not be a Kenmore....
Jul 05, 2013 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Dryer won't run
make sure the lint is removed they may be some in the blower wheel if there isnt the run windeings are bad in the motor
Apr 22, 2010 | Dryers
Control Panel Kenmor Elite HE4
that sounds weird to have all those lights on...
first thing is to try and remove the "lock"light...
push and hold the button, for 5 seconds, below the "lock" light,
that should get the control back to normal operation. then if you still cant get the unit to turn on, try to unplug the dryer for a few minutes.
if you still cant get it to turn back on, call sears "customer service" and complain since your machine should not have failed at this early in its life.
Sep 15, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer model number 110.66912691 not heating.
Check the house electrical panel for tripped dryer-circuit breaker-pair. Push off, then on. If immediately re-trips, the dryer has a dead short circuit in it. If they hold, then retry the dryer. If it now works, ok! If not, recheck the breakers as above. If tripped again, there is a likely short in the dryer's heater assembly. The drum must be removed to access the heater.
Aug 24, 2009 | Kenmore 62602 Electric Dryer
Must hold start button to run. no heat
disconnect power and remove lid. Test the door switch w a volt meter do so opening and closing the door not pushing switch if circuit stays open try pushing switch with finger. If pushing closes circuit then adjust switch.If circuit stays open replace switch. If switch operates with no problems then it is the motor. Check all connections and vacuum lint from motor
How old is this dryer?
Dec 30, 2008 | Kenmore Dryers
Dryer died
Hi! kiatt28
According to the manufacture (Whirlpool manufactures this model for Kenmore) PF is Power Failure, they do not recommended replacing the control. Have an electrician check the wall receptacle or breaker panel. I suspect you have a loose connection, sometimes it is just time to replace the receptacle.
InMrFixIt
Aug 09, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE5 Electric Dryer
I have a Kenmore HE5 Steam: after a power failure last week, now when you turn the dryer on and push"start" the cycle stops emediately and flashes PF...
May 07, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer stops
your motor switch is gone you can either change the switch or motor you could try tapping the switch sometimes it will free the contact this switch is on the motor
Dec 09, 2007 | Kenmore 659 Electric Dryer
Kenmore elite he3 electric dryer
Oct 31, 2007 | Dryers
Dryers Logo
52 people viewed this question
Top Dryers Experts
