Question about Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum
No water spray
The water spray is only barely coming out. I've checked for clogs and made sure the tanks are all set up properly
  • Bissell Master
  • 18,394 Answers
One of the main problems you get with not spraying properly is the heater blocked
Posted on Jan 20, 2013
Delphi51
  • 33 Answers
SOURCE: Sprays soap, but not water
My Bissell is quite fussy. Sometimes I have to wiggle and push down the tank before the water will start to flow. The water doesn't flow properly if the soap container is low - I fill it with water when rinsing. It has a viewport with a red cross that turns when the water flows. Sometimes just removing that and the white filter below (and putting them back) makes it go. Mine is easy to take apart - 6 screws in the base unit and the top comes off. There are two water tubes going into the handle hinge under where the water tank goes - very easily squished or damaged. Last time the water stopped flowing, I ran it with the cover off and just fiddled around with the tubes and away it went. Maybe it is spraying soap only. The water flows up through the handle to the finger valve and heater. Some people say the heater in the upright/handle gets plugged. I haven't had that apart, but it should be easy to bypass the heater.
Posted on Sep 11, 2007
reddevil6
  • 1673 Answers
SOURCE: Bissell 7920 ProHeat Problems--No solution spray
Is the smart mix valve turning and stopping where is is supposed to, if it turns all of the way around, then it is broken inside the top cover. Try replacing the smart mix bottle insert and cap asm part #2101795 . Make sure that the rubber gasket is on the valeve asm. at thebottom of the smart mix bottle. If not, it has to be on the valve.
Posted on May 20, 2008
  • 17 Answers
SOURCE: Nothing spraying out of bissell powersteamer
Here is how to fix it
Posted on Feb 08, 2010
heatman101
  • 43501 Answers
SOURCE: Bissell, ProHeat, ProTech won't spray water.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
895r
Posted on Sep 30, 2010
small6363
  • 18394 Answers
SOURCE: my bissell spot lifter model 1716 won't spray water at all, how do i fix this?
ok - this works even though it probably isn't the "best" solution. Unclog the input and output nozzle ares with a pin. The input area (behind the solution) was my clog problem - I put 2 or 3 drops of CLR into the hole, waited 5 minutes, then primed the trigger. This unclogged it! Fill the tank with a 1:1 ratio of white vinegar and warm water. Insert tank into unit and spray out the contents into the sink. This will eliminate any leftover CLR residue and clean the nozzle thoroughly. For the intake (suction part of the tank) I just rinsed through the lines with the vinegar mix and it seemed to unclog the rest. These things are a pain to take apart and if you break any pieces you'll be stuck - replacement parts have been discontinued for older models.
Posted on Sep 20, 2012
When button is pressed, water does not come out of the holding canister. still seems to have suction, but water doesn't come out to rinse/clean carpet.
Please check the following with liquid in both tanks.
- Check to see if the machine will spray through the hose with the setting on tools. If it does, the pump is fine. Continue troubleshooting.
- Check for debris on spray tips. Clean them with a soft brush (on old tooth brush works well). The spray tips may be lifted out for easier access.
- Ensure the tank lid is properly attached to the bottom of the tank. To attach this properly, remove the Water Tank from the machine. Hook the front window onto the lip of the bottom container and then allow the window with lid to cover the complete tank. Secure the latch on the back of the bottom tank to the back of the tank lid. THE TANK LID CANNOT BE ATTACHED PROPERLY IF THE BOTTOM TANK IS ALREADY INSTALLED IN THE MACHINE.
- Check the bottom of the Water Tank and the Formula Tank to make sure each has a red auto-load gasket attached. Make sure the Water Tank and the Formula Tank are seated properly. Depress the x on this gasket to ensure this depresses and release back out. Liquid from the tank should dispense.
- Remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.
If the machine continues to not spray, check the following:
REMOVE THE COLLECTION TANK:
• Make sure the unit is set to water rinse
• Remove the smart mix bottle and fill it with water only
• Place the smart mix bottle into the collection tank reservoir
• Run the unit and try to spray. If the machine sprays, you will be able to see the water level decreasing in the smart mix bottle and you will need to replace the bottom tank. It is possibly warped.
Nov 22, 2010 | Bissell 9200 Upright Vacuum
Hey there, a friend of mine has a bissell pro heat 2x turbo, that is spraying no water on the floor setting, the pump works i assume, as the machine vibrates when the trigger is pulled, how would i...
Check the following with liquid in both tanks.
Nov 22, 2010 | Bissell Vacuums
Bissell proheat 2x not spraying water
Nov 03, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
The machine is not spraying water or cleaning fluid out bissell pro heat 2
Sep 27, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell will spray water when set to water rinse, but as soon as it is set to light, normal, or heavy cleaning, there is no spray. I have tried priming but to no avail. I put plain water in the solution...
If these suggestions do not resolve your issue, contact BISSELL Consumer Services.
1-800-237-7691
Mon-Fri: 8am to 10pm ET
Sat: 9am to 8pm ET
The Bissell is not dispensing water or cleaning solution.... The silver & black spinner does not spin
Check the following with liquid in both tanks.<br /> <br /> - Check to see if the machine will spray through the hose with the setting on tools. If it does, the pump is fine. Continue troubleshooting.<br /> - <b>Check for debris on spray tips</b>. Clean them with a soft brush (on old tooth brush works well). The spray tips may be lifted out for easier access. <br /> - Ensure the tank lid is properly attached to the bottom of the tank. To attach this properly, remove the Water Tank from the machine. Hook the front window onto the lip of the bottom container and then allow the window with lid to cover the complete tank. Secure the latch on the back of the bottom tank to the back of the tank lid. THE TANK LID CANNOT BE ATTACHED PROPERLY IF THE BOTTOM TANK IS ALREADY INSTALLED IN THE MACHINE. <br />- Check the bottom of the Water Tank and the Formula Tank to make sure each has a red auto-load gasket attached. Make sure the Water Tank and the Formula Tank are seated properly. Depress the x on this gasket to ensure this depresses and release back out. Liquid from the tank should dispense.<br /> - Remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.<br /> <br /> If the machine continues to not spray, check the following:<br /> <br /> <b>REMOVE THE COLLECTION TANK</b>:<br />&bull; Make sure the unit is set to water rinse<br />&bull; Remove the smart mix bottle and fill it with water only<br />&bull; Place the smart mix bottle into the collection tank reservoir<br />&bull; Run the unit and try to spray. If the machine sprays, you will be able to see the water level decreasing in the smart mix bottle and you will need to replace the bottom tank. It is possibly warped.<br /> <br /> If your machine continues to not spray, contact BISSELL Consumer Service at <a href="http://www.bissell.com">www.bissell.com</a>
Aug 25, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
My Pro heat 2x by Bissell does not put out or **** up water Brand is Bissell. Model is 8920 12 amp
If these suggestions do not resolve the issue contact BISSELL Consumer Services at...
1-800-237-7691
Sat: 9am to 8pm ET
Aug 15, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
We cannot get the water and soap to dispense in out Bissell steamcleaner
Check to ensure there is liquid in the water tank and the formula bottle.
Note: This machine will spray with liquid in the Water tank only if the machine is set to the Water Rinse setting. On any other setting, you need to have liquid in the formula tank as well.
If no: add liquid to the Water tank and the Formula tank.
If yes: check each of the following....
-If everything is seated and attached properly, prime the machine by turning off the power, waiting one minute, and then turning the power back on and depressing the trigger on the handle.
- If priming the unit fails to fix the problem, remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.
Aug 13, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissell steam cleaner will not spray any water
Jun 15, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have the Bissell heat pro 2x 8920 and the water doesn't come out. The soap just mixes with water tank and the carpet stays dry
Jun 14, 2010 | Bissell 8920 ProHeat 2XTM Upright Vacuum
Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum Logo
22 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
